1952-59 Ford Well I decided to go Gasser with the '53 Mainline
Discussion in 'Off Topic Hot Rods & Customs' started by texas_rat_trap, Jul 27, 2011.
  1. texas_rat_trap
    texas_rat_trap
    I am pretty close to the point of no return.... Last weekend I pulled the 223cid out & all the front suspension off, so those parts are gonna be for sale pretty soon. I gotta work saturday and its a honeydoo weekend also, so next weekend I will be cleaning & boxing the frame & cutting out the crossmember and installing this engine crossmember
    Here are some pic's of the progress I have more to upload tomorrow.
    355cid SBC
  2. bulletproof1
    bulletproof1
    from tulsa okla
    looks good..are you going straight axle?
  3. texas_rat_trap
    texas_rat_trap
    Thanks,
    Yep, goin' straight axle. I'm still trying to decide if I want to go with the Speedway axle or another dude that builds nostalgia race cars... determining factor is $$$$.
    -TRT-
  4. 53vicky
    53vicky
    gonna be bad***!!
  5. raybug
    raybug
    needs a ford motor:D
  6. firerod63
    firerod63
    Did that front end have the Aerostar conversion in it?
  7. texas_rat_trap
    texas_rat_trap
    No, they're heated springs.
  8. JeffB2
    JeffB2
    from Phoenix,AZ
  9. dwaynerz
    dwaynerz
    no matter the power, thats a lot of air under those tires. but yeah, a ford in a ford would have been better
  10. vein
    vein
    Are we going to have more pics as progress goes along? looking forward to see more!
  11. texas_rat_trap
    texas_rat_trap
    Yeah I'll have some more pic's. Didn't get to work on it a whole lot this weekend, cuz I had to work on saturday & had to install a water heater today. But I'll get it done one way or another.
  12. texas_rat_trap
    texas_rat_trap
    Project update pic.'s.... Removed the crossmember, No turnin' back now
  13. texas_rat_trap
    texas_rat_trap
    I was thinking I could box it like this... except for the front needs to be extended a little and rounded or bull nosed. Also thought I may be able to use the top shock mounting in stock location.
  14. bluejester
    bluejester
    from ohio
    I hate fords with chevy motors. Everyone says its easier but it isn't, it is just as easy as putting in a ford motor, g***er will be cool though despite motor suicide lol
  15. Retro Jim
    Retro Jim
    Instead of doing all that 'box welding in " of that heavy steel , why not just cut the frame off at the firewall area and just weld in 2 box rails . That would be a whole lot easier than doing all that welding PLUS it will really cut down on all that extra weight up front which you really don't want anyway . Then you can set you engine anyplace you want very easily ! You really don't need any of the original frame anyway , right ? You can also get the new frame rails farther down into the original frame as well to give you that extra strength when the front end comes down ! It will also be nice and clean in the front end area as well !
    That sure beats boxing in that front end and having to do all that extra welding ! Will also make it easier to make a tilt front end as well !
    BTW , there is a guy on the HAMB that will make you a straight axel for your g***er . He make the to either use Ford or Chev late 40's spindles too !
    That is what I am going to do to my 50 Ford !
    Just a thought !
    Jim
