Well shoot. Hard lesson learned.
Discussion in 'The Hokey Ass Message Board' started by Dynaflash_8, Jul 15, 2010.
  1. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    well i finally got to the point of being able to drive the ch***is of my 47 plymouth around the yard.
    Only problem is when i went to check the oil, it was a nice mess of oil and metal shavings :eek:
    ****:eek::mad:
    Pulled the head, all looked good
    Time to yank it and find out whats up.
    the cam wasnt damaged, thank god. Still had the parkerizing on it. Oil pressure had been good (40-50) pounds, motor didnt knock or anything. Just was kinda hard turning but i thought that was due to compression.
    heres the problem
    Mains are toast. Best i can figure is that the fella i bought the block from had laid the crank in the block without cleaning it out (machine debris from the .010 cut) and it hit the mains first. Didnt wipe out the crank or anything. May have caught it in time. Non the less, motor is apart and getting gone through.
    So who makes a decent bearing?
  2. temper_mental
    temper_mental
    from Texas
    That ****s at least you caught it befor it was a total loss.
  3. blt2go
    blt2go
    man that ****s. glad you are the type to check things before they go completely to ****. hope damage is minimal, good luck.
  4. modelacitizen
    modelacitizen
    Nice. you probably shut that thing down just in time. Also love the fact that you drove it like that.
  5. Old Skool Rodder
    Old Skool Rodder
  6. seatex
    seatex
    Huh?:confused: (I'm probably gonna' regret asking this>>>>>>>>>>>>>)
  7. rob-redm
    rob-redm
    Marty ! That ****s, glad you caught it early.
  8. OahuEli
    OahuEli
    from Hawaii
    "Clevite", as in bearings. Been around for a long time.
    Dynaflash I'm really glad your crankshaft didn't get hurt. And cool that you drove it bare frame!
    About 30 years ago, a similar problem occurred with a 289 I'd just rebuilt for a friend. Basic overhaul, cut the ridge etc. Two days after we got it on the road he calls me and says its knocking. Long story short, I didn't get the block clean enough; metal shavings from cutting the ridges got into in the oil gallery, then got pushed into the bearings and corduroyd the crank. Cost me a crank kit plus all the work to replace it 'cause I guarantee my motors. Talk about a lesson learned!:eek::eek:
  9. ironandsteele
    ironandsteele
    hope you can just replace em and slap it back together!
  10. use a dial bore gauge to check the main bearing housings !!!
    Clevite and Federal Mogul still produce good bearings for ya.
  11. That's ****s! Glad you caught it in time before it did some real damage. There's still two months until the Eastside vs. Westside Flathead Reliability Run on September 18th. Even though, your on the wrong side of the state :D we would still would love to see your car in Vantage. Hope you can make it.
  12. ponchopowered
    ponchopowered
    that ****s marty, hope your not gonna be pouring to much out of your wallet for that one. im trying to get the heads on the corvair rebuilt, so me and my lady can drive up there, if we do im speending a day at your place
  13. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    Hell yea! it was kinda scary. Steering, brakes, no throttle just a really high idle, holding onto the battery with my foot, all while sitting on a 4 inch wide piece of metal!
    http://www.youtube.com/watch?v=oTMdWuFisgw
    Oh have no fear, this car WILL BE THERE. :cool:
  14. HOTRODPRIMER
    HOTRODPRIMER
  15. CGkidd
    CGkidd
    Damn Marty you have the worst luck with engines. Glad to see you caught it early.
  16. MarkzRodz
    MarkzRodz
    Been there done that maybe 5 times in 30 years.
    Don't slap it together,,
    Get your goggles on and go to the carwash and blow everything out. I love the heated water ones.
    I'd blow out all the crank oil p***ages and all the block's oil p***ages that I could get to.
    Then use the compressor & air blow the same p***ages.
    Good Luck. The damage really looks minimal,,I'm sure you'll be fine.
  17. What the hell? You must have feet like a chimp! :D Good thing you checked your fluids!! It looks and sounds like you might be OK.
    Good luck!
