Were is the serial number??
Discussion in 'The Hokey Ass Message Board' started by ifihadthetime, Aug 21, 2007.
  1. ifihadthetime
    ifihadthetime
    I have a orig. 32 frame,but i can not find a serial number on it? Looked on the k member and on the left hand frame rail in front of the firewall ? Any suggestions...
    Thanks Randy
  2. Swifster
    Swifster
    Randy, it will be on the left front rail. Rust and wear can hide what was at best a minimal stamping. Use some sand paper and gently work down the rail from the firewall forward. It'll be there.
  3. F&J
    F&J
    I just found 2 of mine. The front one is right next to the driver side firewall "foot". and it is stamped very close to the inside edge of the rail.
    The front number starts with *18- . Then there is the middle number which is 2/3rds the way back of the flat area of the frame and that one does not start with the *18- . It will only have a * plus the sequence number which is the same as the front but without the 18- . Both of these numbers end with a *. And both are on the drivers side rail.
    The rear number is supposed to be on the rear spring crossmember and also does not have the 18-.
  4. ifihadthetime
    ifihadthetime
    thanks guys, i will keep on looking,this frame has been blasted just within the past year,and who knows how many times before!
  5. FritzJr
    FritzJr
    The stamping is very light. On both of my frames I have only been able to find the forward number. The number is on the top rail near the inner edge. It is about 4 inches ahead of the large hole where the cowl bolts on, or about 3 inches behind the hole where the steering shaft goes through the side rail. The number is *I8 - xxxxxx* or I suppose it could be *B - xxxxxx* if you have a "B".
