Westleys Bleche-Wite for whitewalls
Discussion in 'The Hokey Ass Message Board' started by brianangus, Jul 25, 2010.
  1. Racewriter
    Racewriter
    I've used it for years, and it works great. I use it to clean blackwall tires, too.
  2. tommy
    tommy
    I don't have any whitewalls anymore and still use it.
    Use it with a stiff bristle brush and you won't need any tire dressing. I don't like shiny blackwalls.
  3. noboD
    noboD
    The Coker WW cleaner works REAL good. Wesley's dries out your tires. I also like Lestoil for really dirty tires, it softens rubber too.
  4. rd martin
    rd martin
    from indiana
    the simple green wont leave all the black residue that the westleys does.
  5. oldandkrusty
    oldandkrusty
    I've used Bleche Wite to clean the white convertible top on my '63 Dodge and have never had it do anything bad to the paint. And, as I can't figure out how to get the BW on the top and then off again without getting on the paint, I think that the warning is, perhaps, prompted by an overzealous law department. Remember, if you do something stupid, there is always an attorney to make someone else pay for it!
    Nevertheless, I have never had anything but good luck when I use Bleche Wite. Good stuff...
  6. low-n-slo54
    low-n-slo54
    15 yrs now and no problems.
  7. BloodyKnuckles
    BloodyKnuckles
    30 years and still the only cleaner I use.
    ******Knuckles
  8. skyrodder
    skyrodder
    I have used it for years, but just the other day i cleaned my new bias ply with them and ALOT of white residue washed off, i mean the water was WHITE, i think i will stick to simple green on these tires
  9. flatoutflyin
    flatoutflyin
    Never had a problem on tires or wheels, and it a good garage floor degreaser.
  10. finkd
    finkd
    YES,Ithink everyone has prolly used it, you must understand that labels like this are made for people that want to file a claim or sue, because they can, it is just covering the manufacturers ***, so people with a big iQ but low on daily common sense can understand, use spairingly and with caution. Oh and also don't try to bleech you **** cavatiy or your teeth with it, just incase they didn't make that clear as well................
  11. 55vicky
    55vicky
    I had been working with whitewall for several years and i do not recomen it bleach drys up rubber the best thing is SOS soap pads (steel whool) that works the best.
  12. chaos10meter
    chaos10meter
    from PA.
    I use only clear water and a wad of cotton.
    It doesn't clean **** but has never stained my paint or alum.
  13. cleatus
    cleatus
    from Sacramento
    Pretty much any detergent (Westleys, Simple Green, Comet, etc.) will dry out the rubber.
    After you do the clean up, let it dry and then rub in some ArmourAll to keep the rubber from drying out.
  14. Rudebaker
    Rudebaker
    from Illinois
    I've used GUNK Engine Brite on my white lettered and whitewall tires for years. Works good, gets the black clean as well and doesn't hurt aluminum, paint, etc. Spray it on before you wash the car and then hit it with a pressure washer, any tough spots are quickly taken care of with SOS or more GUNK and a stiff brush. Usually the SOS pads are only needed the first time on used tires. I bought some Westley's when I got my Stude, it didn't work any better than the GUNK and smelled su****iously like Hydrochloric (aka Muriatic ) Acid. I'll stick with GUNK.
    I've been told Armor All wasn't recommended on whitewalls. Anybody have any info on that?
  15. Use it on almost everything I clean and never had a problem, tires, wheels, running board rubber. Just clean it and rinse it down good, it cleans very good.
  16. wizzard23
    wizzard23
    I use simple green on our Diamond Backs as recomended by the manufactuer. Works great and smells wonderful too! They do not recomend protectants such as Armorall.
  17. BigChief
    BigChief
    There is no HCL in Bleche-White.
  18. HRod 50
    HRod 50
    This thread is great but it is so funny. Some guys swear it's very good other complain it isn't worth buying.. Here I am changing out my "Sclames" cause I think you guys know something. You all can't agree on anything! :p...Hahahahah..
  19. bobscogin
    bobscogin
    Most likely sodium hyperchlorite. I've used it and noticed that it dissolved / removed the boundary layer of white rubber on the whitewall. That's why they come out so clean and fresh looking.
    Bob
  20. fastrnu
    fastrnu
    from shelton,wa
    apply the 12% rule. Should work out OK
  21. chopolds
    chopolds
    from howell, nj
    Used it exclusively on my 55 Olds, with 4 1/8" white walls for over 30 years...3 sets of tires. Wore them out before they "dried out"!
    Not a fan of abrasive cleansers. While they do a good job on extremely dirty whites, as a last resort, I've also noticed that they seem to scuff up the nice, shiny white wall surface. The scratches will then attract and hold dirt more than a smooth shiny surface. My olds' whites are still as shiny as they were when new.
  22. carnut341
    carnut341
    I've used Westleys for over 35 years on the widewhites on my 53 Ford and never had a problem. It's never harmed the red paint on the wheels or the chrome on the hubcaps.
  23. 296 V8
    296 V8
    from Nor~Cal
    Simply put soapy water (sponge) were you don’t want it.
  24. Ford52PU
    Ford52PU
    from PA
    It's a floor wax, no it's a desert topping!
  25. KING CHASSIS
    KING CHASSIS
    That is how I put it on the white walls on my '65 Rivi. Then rinse well with hose and different towl.
  26. Badfella
    Badfella
    Try buying some "Eraser sponges". Super fast, easy and awesome results with less h***le.
  27. Graystoke
    Graystoke
  28. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
    bleache white and sos pad works wonders!
  29. wally bell
    wally bell
    from VA.
    Yup !!!! Westley's
    It's still the best !
  30. BigChief
    BigChief
    Nope. No chlorine "bleach" in it either.
    -Bigchief.
