Wet Sandblasting???
Discussion in 'The Hokey Ass Message Board' started by rustyironman, Sep 25, 2011.
  1. A long while back, I heard about an attachment that one could do wet sandblasting using a pressure washer.
    Yeah, I know **** rusts after you sandblast it if one gets it wet, so part of the point is moot. But it would be handy for gl*** work or say stripping ****ty pot metal, fibergl***, etc.
    Anybody every use some setup like this? Does it work?
  2. eaglebeak
    eaglebeak
    I've seen wet sand blasting used on an old building downtown. The reason water was used was to keep the dust down.
  3. boldventure
    boldventure
  4. pugh433
    pugh433
    from toledo
  5. Northern hYDRAULICS HAS A WANd, MUST HAVE 4,000 pound pressure washer
    works great, real messy :eek:, i did some old pitted constructuion equip
    dry blasting is good to get resin out of fibergl***, used to do custom boats:rolleyes:
  6. cryobug
    cryobug
    I do it. After it dry's it just takes a dusting to remove the flash rust. It is nasty but a faster way to do it. It is also imposable to recover and reuse the sand.
