Technical What’s a good blasting media for an aluminum intake?
Discussion in 'The Hokey Ass Message Board' started by Budget36, Apr 15, 2023.
  1. Budget36
    Budget36
    I have one that is grungy from gas stains, etc. I’d like to clean it up with ease and not elbow grease.
    I’ve used sand before, but looks kinda rough when done.
    I was thinking gl*** beads but don’t know how much would be needed (never used gl*** beads).
    I have 30/40 gallons of crushed walnut shells (Was a thing long ago) would that be a good option?
  2. '29 Gizmo
    '29 Gizmo
    from UK
    Baking Soda. Its very mild on aluminium parts but is extreemly good at cleaning the surface
    Deuces, Truckdoctor Andy and Budget36 like this.
  3. SS327
    SS327
    Gl*** beads has worked for me in the past. I have heard of some using walnut shells but I have no experience with that.
    Deuces, rockable and Budget36 like this.
  4. Budget36
    Budget36
    How much is used/needed in a cabinet
    Thanks
  5. Budget36
    Budget36
    I had no idea. Can you give me a recipe for use?
    Thanks.
  6. Jmountainjr
    Jmountainjr
    I like used 80/90 gl*** beads for aluminum followed up with some Gibbs. But if you have the walnut shells try it. Might be a bit slower but still should work.
    Deuces, Desoto291Hemi and Budget36 like this.
  7. SS327
    SS327
    In my small HF cabinet I kept about 15 - 20 pounds in it.
    Deuces and Budget36 like this.
  8. Budget36
    Budget36
    May as well try the shells. After 40 years I need to use them for something!
    Deuces, Desoto291Hemi and SS327 like this.
  9. clem
    clem
    Wouldn’t 40 year old walnut shells go soft ?
  10. Friend of mine used walnut shells on aluminum
    Parts looked great
    Budget36, Deuces and Desoto291Hemi like this.
  11. mad mikey
    mad mikey
    As long as the shells a good they will work. I prefer gl*** bead. We gl*** beaded tons of engine parts when I was a CAT engine tech.
    SS327, Budget36, Deuces and 3 others like this.
  12. I used baking soda on my Harley engine parts and they came out great. Harbor Freight has special soda blasting media made by Arm&Hammer. The baking soda from the grocery stores is too fine.
    1biggun, Budget36 and mad mikey like this.
  13. theHIGHLANDER
    theHIGHLANDER
    If it's more stains and grunge you might try paint remover. I have a 1bbl flathead intake that was nearly black in some spots and didn't want to blast it and change the surface. I slopped on some leftover paint remover from something else I was doing. Magic. Let it soak, keep it wet, wash away. Next I hit it with a mild acidic cleaner (diluted JD I think). Looks OEM and no blasted look. Worked for me.
    Budget36, Deuces and ekimneirbo like this.
  14. 325w
    325w
    When using gl*** beads to clean the intake be sure you seal the holes. The beads will stick to the gunk inside the runners know of a guy who blasted the intake. He never thought about the beads sticking in the gunk. Cost him an engine.
    rod1 and Budget36 like this.
  15. Also tape off the entire bottom of the manifold, only blast the outside of the manifold, not inside or under
    Budget36 and Deuces like this.
  16. 100% Matt
    100% Matt
  17. PackardV8
    PackardV8
    X2 !!!!!
    It's impossible to know for certain if gl*** beads, steel shot, sand, et al, are all removed from the interior of an intake manifold.
    Soda blast, tumbler or ultrasonic are safe methods.
    jack vines
    Budget36 likes this.
  18. I use ultra fine gl*** beads @ 40 psi. Works great. Been blasting aluminum for over 30 years.
    Vic
  19. Rickybop
    Rickybop
    They needed to clean the Statue of Liberty a few years back. They figured out that soda does a real good job without changing the surface. With the added benefit that if you do get it in some places it shouldn't be, it can be dissolved out. Also, counterintuitively, it actually leaves a protective coating that temporarily inhibits rusting. The parts can be left alone for a while until a good washing with water before paint.
    Probably shouldn't use your pressure pot system. Might clog up. I prefer a small safe and type blaster with the rubber hose attached to a footlong steel tube so I can manipulate and unclog.
  20. Rickybop
    Rickybop
    Btw, it can be used wet or dry. And it's a one-time deal. Can't be reused. Not much more to know, but read up a little bit. Lots of info out there. Have fun.
  21. Budget36
    Budget36
    These are in a big bag in a cardboard? Kinda barrel with a lid. Ill find out how well they’ve faired next weekend.
    SS327 likes this.
  22. Flathead Dave
    Flathead Dave
    from So. Cal.
    HAHAHAHAHAA
  23. Rickybop
    Rickybop
    Because soda is relatively soft, to effectively blast with it, you need a lot of pressure and CFM.
  24. Budget36
    Budget36
    That will rule out me using soda then. My large compressor is down, my home built one has a tired compressor on it. It’s “okay” for sand, so I’ll give the crushed shells a try.
    Rickybop likes this.
  25. mgtstumpy
    mgtstumpy
    I had my Edelbrock X1 wet blasted, looks like brand new.
    XXL__, clem and Budget36 like this.
  26. kabinenroller
    kabinenroller
    I used baking soda to boast some aluminum parts, it worked well except for one issue. I did it outside in the gr*** area next to my shop, everything was good until the next day when I noticed that the soda killed the gr*** right where I did the blasting. One of those O Sh*t moments.
  27. 1952henry
    1952henry
    Sounds silly, but years ago I cosmetically restored an original Holley for a GT 500. The throttle plate was aluminum, unmarked, but dirty and stained. I cut a slit in a length of plastic tube, slipped that over an air gun nozzle, leaving about an inch or two past the nozzle. The other end went into a box of A&H baking soda. Don’t remember the air pressure, but it sure cleaned up the carb base, and didn’t etch the aluminum like bead blasting would have. It looked brand new. The fella I did the carb for was quite pleased, as this was part of a high dollar restoration.
