Technical What’s the trick to pumping fuel in old car without spilling it
Discussion in 'The Hokey Ass Message Board' started by slim38, Apr 12, 2023.
  1. ken bogren
    ken bogren
    Did you also have to replace the fitting on the tak were the vent tube connected?
  2. BamaMav
    BamaMav
    from Berry, AL
    Only problem I have is getting the nozzle turned right to go in my filler neck. It sits a few inches down under the door on top of the fender, so you can’t just stick it in like you can where the fill neck is on the side. We don’t have those goofy sealed boots, there would be no way they would work on my car.
    rodncustomdreams likes this.
  3. mohr hp
    mohr hp
    from Georgia
    Yes, I put a larger hose ****** in the tank too. It's all about airflow out of the tank as the huge volume of fuel flows IN. And yes, that's the painful part, you gotta weld the tank.
    guthriesmith likes this.
  4. 1971BB427
    1971BB427
    from Oregon
    I'd agree that this sounds like an improperly vented tank. On both of my hotrods I have fuel cells and my vent lines leave the tank with 3/8" line, and go a good 9" above the tanks, and then have a 360 degree loop bent in the vent lines. Then they go down below the bottom of the tanks and end with a vent filter to keep bugs and debris from getting into he end of the vent. They fill effortlessly, and never shut off until fuel level gets high enough to reach the end of the nozzle.
  5. jaracer
    jaracer
    Yes they do and that's the biggest problem. I fill the tank slowly and rarely fill it full. Both my 57 T-Bird and 64 Chevy truck are prone to major splash back.
    slim38 likes this.
  6. This is the issue I deal with ('41 Merc & '51 Chev). The hose nozzle does not reach the filler neck deeply enough to have the splash-back boot do it's job; plus, the necks and vents on the vintage cars are not conducive to a fast fill. You will always find me bent over the fender with my ear as close as possible listening for the whistle to change pitch all the while squeezing as slowly as possible. After all that, I go in to tell the attendant there is an environmental spill under my car.. The tribulation of owning a nifty car I guess..
    -Dave
    p.s. The nozzles back in the day did not have those blasted chunks of advertising plastic on them which allowed you to insert the hose all the way into the filler neck.. Progress!
    slim38 likes this.
  7. Rocky
    Rocky
    Classified Editor
    I've found mine fills with no drama if I point the front of the car downhill. Most stations I can put the nozzle on the 1st click. My problem is when the tank reaches "full". It spews out about a quart from the vent. I always act like I don't see it and drive off.
  8. Even 'back in the day' some cars were a pain in the ***! "53/'54 Plymouths come to mind... Some OEM designs just don't breathe well. Now, your Tesla is just plug and play, so drive it instead!
  9. rockable
    rockable
    The real trick is this, "for every gallon of gas that goes into the tank, a gallon of air must exit." Those old tanks don't have a separate vent, so the air must exit the filler neck and when it can't do so fast enough, there is blow back from the pressurized air in the tank. So, either add a vent or go slow. Those are your 2 options.
  10. tim troutman
    tim troutman
    on my 40 ford coupe I owned couldn't hardly get gas in it. took a coat hanger & ran it up the vent tube to clean it out after that no problem. Your experience may vary. 2 photos of my 40 sedan fill neck. But 20230413_212140[1].jpg 20230413_212224[1].jpg as others have said the air has to go out as the gas goes in
    slim38 likes this.
  11. 48 Indian Rag
    48 Indian Rag
    from conn
    As Algoma56 stated above if you have the stream wash against the side of the fill pipe it tends to dissipate the bubbles? and it's less likely to spit back at you and the side of the vehicle
  12. nochop
    nochop
    from norcal
    Sometimes you gotta pull the foreskin back and watch what’s going in……
  13. Bandit Billy
    Bandit Billy
    Oy gevalt!
  14. Roothawg
    Roothawg
    My 56 F100 is getting the top fill filler. I am done with gas running out on the fenders.
  15. Lingwendil
    Lingwendil
    My 71 Maverick used to spit up all over my leg when the tank was full, it was frustrating if you didn't time it just right.
  16. I have a 5-gal can of toluene to add to the tank of a particular car I have when I want some extra high-octane smack. The spout on the can is normally flush but it can be pulled out but only 3" or so. I haven't bought a special funnel in a while. I just cut the bottom off a plastic one or two-liter juice or whiskey bottle to make a temporary funnel. I wrap an oil rag to hold it snug at an upward angle while I carefully pour the big can with both hands into the "funnel".
    I probably use funnels more than I used to because one is so easy to make. It's also easy to make a scoop the same way.
    slim38 likes this.
  17. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Ger a hearing aid they are cheap ones now easy to use.
    Listen and watch
  18.
  19. Mr48chev
    My experience says yes and even pumps that are new rather than three or four years old pump faster. Old cars weren't designed to handle the volume that the new pumps put out.
    Yuppers, air has to be able to get out as fast as gas goes in.
    The stock tank and filler neck on my 48 was the worst though, that one was a pain in the **** to fill 30 years ago because you had about 5 inches of drop and a level filler hose for a foot and then a 90 into the tank. Plus no vent hose.
    I've got one of these Perko tank vents on the back of my Bayliner with a 350 in it and a 60 gallon fuel tank and the chrome part that shows is about an inch long. That would let a guy run a 5/8 vent hose up to a discrete spot.
    Marine supply stores usually have an ***ortment to pick from Amazon.com: Perko 0506DP4CHR Chrome-Plated Fuel Tank Vent with Black Polymer Splash Guard for 5/8" Hose : Automotive
  20. 1946caddy
    1946caddy
    from washington
  21. FishFry
    FishFry
  22. manyolcars
    manyolcars
    On the 65, check the breather hose on the gas tank. Theres probably a better name for it. small hose at the front of the tank
  23. manyolcars
    manyolcars
    My 39 Ford pickup took forever to fill so I welded a vent tube to the filler neck. It goes into the tank and turns up to the top of the tank and works right now.
  24. clem likes this.
  25. slim38
    slim38
    from Sudan TX
    Someone mentioned parking downhill and that got me thinking. We only have one gas station in my town and it’s sloped fairly steep. I always face the store uphill. I fueled both cars downhill and it made a huge difference. Thanks guys.
    clem and SS327 like this.
  26. 427 sleeper
    427 sleeper
    Nothing... It's Diesel. :D:eek::rolleyes:
    SS327 likes this.
  27. BJR
    BJR
    I knew a guy that had a 5 skin!:eek::p
    mohr hp and nochop like this.
  28. David Gersic
    David Gersic
    from DeKalb, IL
    I have a 37 Chevy. Tank is in stock location, but the filler was moved to above the fender, with a modern inlet and cap. Flow in to the tank is ok, but the auto shut off doesn’t always trip quick enough. I stuff paper towels around the nozzle to catch the splash back. Usually works. Keep some cheap hand sanitizer in the trunk, it helps take the smell of gas off my hands.
    slim38 and 427 sleeper like this.
  29. nochop
    nochop
    from norcal
    Yikes…..we don’t need to know how you found out
    BJR and Lil 32 like this.
  30. Dan Coburn
    Dan Coburn
    from Kelso WA
    Hmmmmm no vent at all on the 41 except for the cap. I wonder what it's gonna be like filling up. I'm guessing very slow and possibly messy......
