Hot Rods What’s the value on a 51 merc motor
Discussion in 'The Hokey Ass Message Board' started by oldsman41, Jul 14, 2021.
  1. oldsman41
    oldsman41
    Looking for flatty for an a v8 project prices are quite high to me has anyone bought a flatty lately so I can get ballpark value now
  2. F-ONE
    F-ONE
    from Alabama
    $ 75.00 to $10,000.
    Often times, a good running engine comes attached to a car.
  3. SEAAIRE354
    SEAAIRE354
    Depending on who you go to and the level of build. It’s anywhere from 5to 9 thousand dollars to rebuild one. The last one I did was $2500 25years ago. Cores are getting tougher to find.
    VANDENPLAS likes this.
  4. tubman
    tubman
    Actually, more than most flatheads. There is a good chance that it will have a usable 4" stroke crankshaft. If in turnable shape, the crankshaft alone is worth around $400. Other than that, you are facing the problem most flathead buyers do. Unless you do your due diligence and make the right arrangements with the seller, there is a good chance you will end up with $30 worth of s**** iron. Flathead blocks are notorious for cracking and funding a crack-free block is quite difficult these days. I sold my second to last good 8BA block to a guy who had dis***embled and checked five engines without finding a good one. Either buy a block that is tested and certified good, or get a money back guarantee and have it checked yourself. In my opinion, a tested good bare block is currently worth in the neighborhood of $1000.
  5. oldsman41
    oldsman41
    Yeah I just want a good motor so many guys putting newer stuff in them I thought it would be a little easier to find one that’s affordable.
  6. tubman
    tubman
    Hopefully, you'll get lucky. In my neck of the woods, people are pulling old SBC's for the LS/LT motors, but the flathead guys are keeping theirs.
    It won't hurt to keep your eyes and ears open.
  7. oldsman41
    oldsman41
    Yeah like the saying goes. If it wasn’t for bad luck I’d have no luck at all.
  8. Dangerousdan
    Dangerousdan
    from Arizona
    I can remember when I bought mine for $150.00. Sweet
  9. alchemy
    alchemy
    Last summer I bought two mostly complete 59A engines that had been inside a garage for at least a couple decades. I spent $200 if I recall. Neither one is locked up, but they probably each need a rebuild.
    Desoto291Hemi likes this.
  10. F-ONE
    F-ONE
    from Alabama
    Sometimes I wonder if usable blocks are unnecessarily condemned. I understand it. It's a big risk.
    Bruce Lancaster would voice the same sentiment specifically about pan rail cracks.
    Of course, this is if you have a running engine....Bruce's sentiment was mainly about "fatal" cracks discovered in a overhaul. The engine was running and running pretty good before the overhaul....The symptoms that required the overhaul was wear, not "crack" related....so why is it now junk? It was fine before....
    Desoto291Hemi and arkiehotrods like this.
  11. oldsman41
    oldsman41
    Yes I found one that’s in a running car the guy wants 1500 bucks for it. If I don’t find anything else that is why I’m asking here thought I would get more responses
  12. flatheadpete
    flatheadpete
    from Burton, MI
    I traded a set of billet wheels for one in 1999....ugly wheels anyways.
  13. RidingMechanic
    RidingMechanic
    from Cincinnati
    I have had decent luck locally finding 1 or 2 Merc motors a year, plus several 8BA. 59ABs in good shape are getting harder to find. Lots of them are "gee, it turned over when I pulled it out" but it's been sitting in the weather for years... Mercs with good bores generally sell for 1200-1500 and they're pretty complete. If you want to spend time chasing down leads on FB and CL, you can get one for a third of that.
  14. Rand Man
    Rand Man
    Check the HAMB cl***ifieds. I have a Merc core engine and a complete flathead car available.
  15. Squablow
    Squablow
    If you can hear it run and the compression checks out I'd say that's a very good deal for a '51 Mercury motor. I'd doublecheck to make sure it's got the 4" stroke of course, as anything could have been swapped over the years, but if it's not smoking or chugging, no reason not to just clean it up and use it. I'm looking for an engine for my someday '34 Ford build and that would definitely get me interested.
  16. Affordable flathead is an oxy*****. You pay so much to get so little.
  17. oldsman41
    oldsman41
    The car is at the weekly car show, the guy wants to put an olds motor in it, so I think I will check it out
  18. Bearing Burner
    Bearing Burner
    from W. MA
    Don't buy anything that doesn't have the heads off so you can check for cracks. Usually you goes through 4 blocks before you find a good one.
  19. Boneyard51
    Boneyard51
    There’s a guy in Tennessee Facebook marketplace that has a good , checked block, another late model engine that hasn’t been opened and early engine and a **** load of parts, starters generators pumps transmission, for $1000!
    Bones
  20. oldsman41
    oldsman41
    Thank everyone good leads and info
    Boneyard51 likes this.
  21. tubman
    tubman
    As Clint Eastwood said, "Are ya' feelin' lucky?".
    Boneyard51 and Desoto291Hemi like this.
