Technical What’s this Ford grill?
Discussion in 'Traditional Hot Rods' started by 65standard, Nov 6, 2023.
  1. 65standard
    65standard
    F75F0372-E89F-4409-9170-41A5187D3EA5.jpeg This is just sitting in a field. Any idea what it’s from.
    Stogy, 41 GMC K-18 and Nailhead A-V8 like this.
  2. '29 Gizmo
    '29 Gizmo
    from UK
    Grill is model A. The hood is not
    Spooky, Stan Back and Stogy like this.
  3. Nailhead A-V8
    Nailhead A-V8
    link to your 3 W recreation doesnt work
    Spooky and Stogy like this.
  4. 41 GMC K-18
    41 GMC K-18
    This should be more than obvious, that its a Ford, Model A radiator "shell", not a "grille"
    Just making a clarification.
  5. The37Kid
    The37Kid
    1931, Should be inside safe from the winter. Bob
  6. Rex_A_Lott
    Rex_A_Lott
    As stated, 31 A model grille shell. Appears to be the stock radiator. The grille shell is stainless steel, can be made to shine like new money. The radiator is copper/br***. Take it home if its available, even if you dont want it, somebody is looking for one Good Luck.
  7. Stogy
    Stogy
    He doesn't have a build Thread but a number of posts piece it together...you are right though a lot of profile links are dead...and then the redx's...:oops:
  8. 65standard
    65standard
    Thanks everyone. I wasn’t sure if it was a car, truck, or tractor. I’ll save it.
  9. 65standard
    65standard
    161CCAC8-DEC4-4313-AD35-832E52FF139B.jpeg 674AA684-396D-4E30-B889-366447A8A2AB.jpeg My 3-window looks like this so far.
  10. dwollam
    dwollam
    '31 car. Pickups and trucks are different.
    Dave
    Stogy and 41 GMC K-18 like this.
  11. 56don
    56don
    Maybe its just me, a cynical old man...but I find it hard to believe anyone on the HAMB does not recognize a Model A radiator shell. They are probably the most prolific ones ever made. But, now you know..;)
    Just Gary, Tman, J. A. Miller and 4 others like this.
  12. HOTRODPRIMER
    HOTRODPRIMER
    31 Model A, the insert on top is painted, the 30 is smooth at the top, both are stainless steel, HRP
    Cyclone Kevin, Spooky and 41 GMC K-18 like this.
  13. Stan Back
    Stan Back
    Ah, come on. That one's on one year only and not all of them.
    51504bat likes this.
  14. Budget36
    Budget36
    I had a “feeling” it was Model A, but no real knowledge. I can tell the difference between a 55 and 56 Chevy PU though;)
  15. The37Kid
    The37Kid
    I sort of agree, but then again everyone saw one for the FIRST TIME. No longer are there fields or woodlands filled with old cars of the 1930's. It was Great fun to spot them in the Fall as the leaves fell and the hidden treasures could be seen.
  16. pprather
    pprather
    Thanks for the photo update on your rod build.
    41 GMC K-18 and Cyclone Kevin like this.
  17. To me it looks like a modern rad filler neck…
  18. TwistedMetal
    TwistedMetal
    from Wisconsin
    Nice build, what's the story with the body? Brookville panels?
  19. 65standard
    65standard
    Yes. I’m using brookville panels. I made the frame from 11ga cold rolled. The ch***is is ‘41 ford pieces.
    patsurf and Nailhead A-V8 like this.
  20. Tim
    Tim
    from KCMO
    Yeah I would have guessed model A pretty quickly but it does read off like it’s for a truck or four door. Most 30-1 cars I see don’t run a 30-1 grill where 28-9 have a higher chance of running a stock grill shell.
    add a painted insert and I could see the confusion. I wouldn’t feel bad about asking about it.
    Budget36 likes this.
  21. X38
    X38
    Painted insert is stock on 31's.
    hotrodjack33 and INVISIBLEKID like this.
  22. clem
    clem
    Car , - but you can use it on a truck or tractor if you so wish……….
    Stogy likes this.
  23. -Brent-
    -Brent-
    1931 Model A shell, like the others said. Looks like a good wall hanger.
