What about a s10 (4 speed)?
Discussion in 'The Hokey Ass Message Board' started by low budget, Jun 24, 2009.
  1. low budget
    low budget
    from Central Ky
    I have a chance to buy a early 80s s10 with a factory 4 speed behind a 2.5.
    I havent looked underneath it at the trans yet and Im really not sure I would know what I was looking at if I did, so here goes.
    Are these comparable to the t5 or are they something diffrent?
    stronger? weaker?
    I would like to have it in my 55 chevy if it will work and hold up behind a v8, but that is a diffrent question.
  2. if I remember right, those had a pretty steep first gear to help out that anemic TECH4- but the jump from 1-2 was ridiculous. Almost like a granny gear.
    I bet it's a Turd-O-Matic.
    lol--but I'm using a saginaw 3 sp in my '58- so i can't really say anything I guess
  3. bobscogin
    bobscogin
    It's essentially the same as a T5 but without the overdrive 5th. Same lack of strength issue. If you just want a 4 speed with 1:1 4th gear, there are much better choices that are stronger and easier to install.
    Bob
  4. 4cfed
    4cfed
    from wisconsin
    ran a s10 4 speed in a s10 powered buy a 305, headers, sir gap intake 600 carb, small cam, held up just fine, and smoked the tires for days
    if i remeber right you need the bell housing orr a 305/ 350 2wd chevy/ gmx truck, along with flywheel, clutch and pressure plate
  5. low budget
    low budget
    from Central Ky
    Thanks guys, I think I will p*** on it.
  6. Snarl
    Snarl
    If it has an integral bellhousing, it's actually an Isuzu 4spd and not what you are looking for.
    Separate bell means it's a T4. Similar to the T5, but I wouldn't bother with it.
  7. J Man
    J Man
    from Angola, IN
    If it is going behind a V8 you would be better off with one from a full size truck or a s10 with a 4.3
  8. bobscogin
    bobscogin
    Full size trucks and S10 with 4.3L V6 used NV3500, not T5. The 4.3L V6 in Astro Vans used a T5, but it had a Ford mounting pattern.
    Bob
  9. low budget
    low budget
    from Central Ky
    What about a 3/4 ton 84 chevy 4x4 with a 5 speed? will it have a bulldog type ****** or just regular first gear? (found one in the paper thats going to be sold at a auction saturday)
  10. J Man
    J Man
    from Angola, IN
    If I read it right he wants something to hold up behind a V8, that is why I suggested the other trans.
  11. bobscogin
    bobscogin
    Got it. Thought you were referring to the T5. The Getrag/NV boxes are stronger than the T5. Whether are not any of the truck transmissions would be suitable for use in a '55 Chevy is a matter of taste, but I don't think I'd do it.
    Bob
