Hot Rods What about carbs?
Discussion in 'The Hokey Ass Message Board' started by Rod'den, Mar 4, 2010.
  1. Rod'den
    Rod'den
    I have a 30 Tudor w/350, 30 over,miled cam. Wondering if edelbrock 600 cfm or road demon junior 625cfm which one would be better for reliability and dependability. Anyone had any experience with either one please advise.
  2. Deuces
    Deuces
    I like the Holley/Demon style carbs... The gaskets interchange with each other come rebuild time. :)
  3. you are going to get a lot of opinions for and against both...here is mine: i like the Edelbrock on a mild street driven motor.
  4. mac762
    mac762
    A 600 Holley would be fine. I don't imagine a Road Demon any real improvement over the old standby. If you have a little more money to spend a 600dp would be a lot more fun. Contrary to popular belief a dp is not any more fuel hungry as long as you aren't out stepping into it at every stop lite. 30cc's isn't much more fuel.
    I have a 60 over 350 with a mild cam and my 650 dp gets way better performance and gas mileage over the quadrajet (750) or my 750 VS Holley. I wish I had a 600dp to use but I don't.
  5. 4 pedals
    4 pedals
    from Nor Cal
    Eddy's are usually pretty good to slap on and run. Demons I've dealt with have needed more tuning, but are more tunable.
    Devin
  6. mac762
    mac762
    Don't get the Edelbrock. Holley's are not rocket surgery and perform much better.
    I am a diehard Holley fan if you can't tell.
  7. Rich Rogers
    Rich Rogers
    Ok. don't buy the Holley. Just kiddin here. They're both good carbs but I've had better luck setting up and tuning the Edelbrocks by far. The Holley probably would give a little better performance until the power valve blows but the Eddy you can take out of the box and run and fine tune as you go. I guess I like the Edelbrock for the money and ease of working on it
  8. junkyardroad
    junkyardroad
    from Colorado
    Edelbrock for sure. Mine was bolt on and go, perfect mixture, only adjustment was idle speed. I won't use Holleys anymore.
  9. Zookeeper
    Zookeeper
    I like Holleys so much I slapped two of 'em on my motor.
