Customs What am I doing
Discussion in 'The Hokey Ass Message Board' started by JimsF1, Dec 7, 2019.
  1. Looks like way more truck than I can swing.
    I had a '46 when I was in high school for a while. Like everything else time for bills meant that truck needed to go. They are neat old trucks.
  2. JimsF1
    JimsF1
    Hello Fordy
    The engine mechanic I'm working with is a flat head "Yoda" old dragster guy and though I didn't get it Exactly the way he wanted he did say that they realized it was better to ramp it up from the lifters to the piston chamber rather than relieve it.
    For those who disagree, I can ask him exactly what he said because I'm still learning and can be leaving something out.
    Though he can be found on the net because he does have a flathead engine business I would out of respect let him know about this conversation before giving out his info.
    kidcampbell71 and loudbang like this.
  3. JimsF1
    JimsF1
    Newest update family of the H.A.M.B.
    My engine guy has the engine and gave me an ataboy on my porting, polishing and oil port drilling and tapping.
    He is going to vat the engine and its parts then preform his super man X-ray vision on it and as long as all is as he suspected will bore the bores .125 over and mill the heads
    Meanwhile I am stripping the frame and going to blast and paint it.
    The cab will need some rust repair and the an interior paint job.
    JUNK ROD, loudbang and pcbart like this.
  4. JimsF1
    JimsF1
  5. JimsF1
    JimsF1
    Hello to all who check in
    A very sad day has arrived! My amazing condition engine is not so amazing after all
    Master Yoda ran the the block through his vat and then pressured up the block and found that which we hope to never find. "Crack"
    Now! I'm a skilled metal manipulator and have gone through many of your threads and will attempt to repair this crack but will also begin the search for a good block
    I'll get some pics out of the repair attempt.
    The question I have is. Are any of you running on a crack repaired block?
  6. J'st Wandering
    J'st Wandering
    Where is the crack? There are many cracked flatheads; some fixed, some ran with them. Your engine yoda will know if it can be repaired. No reason to toss the block if it is repairable.
    JUNK ROD and loudbang like this.
  7. JimsF1
    JimsF1
    Prepare for pics Wandering! And yes he did say he's seen these cracks fixed so I'll give it a try. I'm with you on the no reason to toss if repairable
  8. JimsF1
    JimsF1
  9. JimsF1
    JimsF1
    Here's what's happening
    I drilled where i thought the crack ends were
    Took a sharp point carbide and followed the crack about half the casting depth
    And cooked the crack run and let it cool slowly
    Next I'll re drill the ends
    Grove to nearly full depth'ish (yes I just created a word that until now didn't exist)
    Heat the seam back up and then start the brazing bonanza
    Set up for another slow cool
    And pressure test
    While all this is happening I'll be chanting "Please Please Please Please worrrrrrk!
  10. J'st Wandering
    J'st Wandering
    Wow, that is not a good crack. Good luck. I hope it works for you but you may want a "Plan B".
  11. JimsF1
    JimsF1
    Agreed, plan B already in process
  12. JimsF1
    JimsF1
    Take a look Gents
    Keep in mind as J'st Wandering said and any of you following have thought. Ready a plan B
    As you'll see and if you zoom in I have thoroughly followed the crack to each end where I've drilled through before the grind started
    Tomorrow I weld. Please send your gas-n-gears positive karma my way
    badgascoupe and loudbang like this.
  13. JimsF1
    JimsF1
  14. JimsF1
    JimsF1
  15. simplestone
    simplestone
    Who knows - It's worth a shot! Good luck on the mend!
    slv63 and loudbang like this.
  16. You are a very good groove maker.
    Good'ish luck'ish with it. ;)
  17. Beanscoot
    Beanscoot
    "You are a very good groove maker."
    Yes, a real groovy guy.
  18. JimsF1
    JimsF1
    Thanks Simple
  19. JimsF1
    JimsF1
    Thanks Shift
  20. JimsF1
    JimsF1
    Thanks Bean
  21. JimsF1
    JimsF1
    Hello H.A.M.B.'s
    I regret to inform you but plan B is now in action. Though the weld looked good I heard a loud "POP" so if any of you know of an old buddy near Tucson with a block to spare I'm looking.
    I'll keep you posted, mean while I'm going to go sulk in self pity for a spell (The mythical rare engine is still a myth) and then pull up my big boy pants and move forward
  22. greaser
    greaser
    Great effort to save the block, Jim! Sometimes you win...sometimes you lose, but nobody can say you didn't try.
  23. kidcampbell71
    kidcampbell71
    Hey Jim. Did you see @rfanuke 's post ? Has a bunch of flathead blocks. See if your machinist has a block crate or block plastic tote to ship. If so Greyhound Bus freight it .. both ways .. is cheap.
    Go to post #14 on the following thread >>>
    https://www.jalopyjournal.com/forum...ge-blocks-chevy-ford-flathead-others.1183864/
    EDIT : max ship weight Greyhound is 100lbs. Can ship tote there empty .. but have to find another way back. Maybe stick it in a seat !!! :)
  24. Tall t 26
    Tall t 26
    Awesome build. Working through the headaches!! Great pics. Nice truck. Thanks for sharing!
  25. kidcampbell71
    kidcampbell71
  26. terry k
    terry k
    from toledo oh
    Not to be a jerk, but why would you do all of the port and polish work before you hot tank and mag, the block . Most of these blocks have cracks somewhere.
  27. Beanscoot
    Beanscoot
  28. JimsF1
    JimsF1
    Thanks Greaser
  29. JimsF1
    JimsF1
    Will Do! Thanks Kid
  30. JimsF1
    JimsF1
    I appreciate you watching Tall t , keep looking I'm movin ford
