Technical What am I missing?
Discussion in 'Traditional Hot Rods' started by NB141FD, Nov 5, 2023.
  1. NB141FD
    NB141FD
    Hoping to find someone who has installed a Limeworks steering wheel and can tell me what I am doing wrong. This wheel is second hand with no instructions. I ***umed the wire running in the steering shaft would attach to the horn ****on and activate the horn when pressed. As you can see from the picture, when I wire it as stated, the circuit is complete as soon as I attach the horn ****on to the wheel and the horn sounds. Is there supposed to be an isolator somewhere in the mix to prevent the horn from activating until the horn ****on is pressed?
  2. jaracer
    jaracer
    I think there is supposed to be a little piece that goes in the center of the steering shaft that the wire attaches to. Then when you depress the horn ****on it touches the center piece completing the ground for the horn. It won't work the way you have it unless you like the horn blowing all the time.
    LAROKE, 05snopro440 and hrm2k like this.
  3. Dak Rat
    Dak Rat
    from NoDak
    I always use the '40-'47 pick up horn wire and metal cup, it goes over the Hex nut and the spring pictured seats on the shoulder. The "cup" has a spring loaded br*** contact that the horn ****en grounds out on and the horn relay does the rest. Sorry I don't have a picture to show you.
  4. hrm2k
    hrm2k
    The horn ****on is a ground
    lothiandon1940 likes this.
  5. olscrounger
    olscrounger
    ^^^ this--wire is supposed to have a contact that sits at end of column then metal on horn ****on contacts to ground/blow horn--I have a wire somewhere with the correct contact--will look-look em up Carpenter and others show them
    lothiandon1940 and 05snopro440 like this.
  6. NB141FD
    NB141FD
    Thanks for the quick replies. Dak Rat are those horn 'cup's available anywhere? Olscrounger thanks for the info let me know if you find a source for the contact.
  7. 302GMC
    302GMC
    from Idaho
    Wire goes to the GRD on the relay ...
  8. Oneball
    Oneball
    05snopro440 likes this.
  9. 38bill
    38bill
    from Minnesota
  10. NB141FD
    NB141FD
    Wonder where I can get just the contact wire. $50 is a little steep for a wire and a spring.
  11. NB141FD
    NB141FD
    302 GMC thanks for the response the wire in my picture comes from the ground pin on the relay. The horn works fine it’s just the wiring at the ****on that had me lost.
  12. Happydaze
    Happydaze
    Is that actually a horn ****on or just a cover/ cap? As it is it appears that the locating lugs go straight to earth and the wire is connected directly to the lug plate. I'm not seeing anything that makes the connection when required. I wouldn't be surprised if the wheel comes with a cover / cap but a horn push is an upgrade.
    Chris
  13. pprather
    pprather
  14. NB141FD
    NB141FD
    Thanks Phil, that looks like it might work plus it has a base to support the wire as it exits the steering shaft. Kind of surprised that no one has chimed in who has actually installed a Limeworks steering wheel like this.
  15. pprather
    pprather
    I used the Limeworks kit to connect horn on my Limeworks wheel and column. The little piece you need is very small.
    If I remove my horn ****on, I may be able to get a photo, tomorrow.
    Does your Limeworks column have the "brush" (horn mire housing) installed at the bottom? If not, you will definitely need the Limeworks horn kit.
  16. NB141FD
    NB141FD
    Thanks pprather, my setup is an F1 steering column with the ground wire coming up through the steering shaft to the horn ****on. I would appreciate a pic of your wiring connection at the top of the steering shaft. From what I can see of the Limeworks horn kit I can't see what supports the spring connector at the top of the steering shaft.
  17. 05snopro440
    05snopro440
    With the way other drivers are these days, it may be necessary.
  18. Dak Rat
    Dak Rat
    from NoDak
    The Carpenter piece is what you need. Its the easy way to get the job done. The wire exits the steering box at the bottom thru the existing end plate.
  19. pprather
    pprather
    This is the top piece of the Limeworks horn kit:
    https://www.limeworksspeedshop.com/Retro-Horn-Kit-p/rhk1001.htm
    The white plastic piece sits on the very top of the hollow column shaft.
    Then the spring and horn ****on are installed.
    When you push the horn ****on, it contacts the wire end, completing the horn ground circuit.
    I hope this helps.
    Happydaze likes this.
  20. pprather
    pprather
    @Dak Rat confirms that the Carpenter piece should work.
  21. NB141FD
    NB141FD
    Thanks pprather, your picture didn't come through. I'll call Limeworks this morning and see if they will sell me just the wire and contact switch. I don't need their shaft bushing and contact since my ground wire is already in my steering column.
  22. Happydaze
    Happydaze
    The $50 is for the full kit. The wire with the plastic bush is also listed separately for $15 or so.
    Chris
  23. pprather
    pprather
  24. NB141FD
    NB141FD
    Thanks for the info Chris and pprather, I'll call them this morning.
  25. pprather
    pprather
    Desoto291Hemi likes this.
  26. nobby
    nobby
    nylon - top hat
    with outer bore of 1/2'' on the long inner steps edge
    the nut is 1/2'' unf
    use a full nut
    press nylon top hat into full nut
    steel round stock press into nylon
    drill hole through,
    catch wire with screw
    beep beep
    or
    Indicator Switch|Steering Column Switch For Cl***ic Car Tractor for sale | eBay
    hi-lo and flash
    indicators - turn signals
    and horn
    multi function doofer 20 quid!!!
    and its fits inch and a half column tube
    then you can hi - lo dip on the indicator stalk and flash
    so you are not diving for the hi-lo foot switch on the floor - total agro
    and do the turn signals - ideal
    and you have completely swerved the wire up the hollow column fiasco total agro, ideal
