Technical What are these called? '33 Plymouth front suspension
Discussion in 'The Hokey Ass Message Board' started by 53 hemi, Aug 24, 2022.
  1. 53 hemi
    53 hemi
    What are these hangers called? I've seen them for sale in the past but I'm having trouble sourcing them now.
  2. dwollam
    dwollam
    Stock '33 Dodge/Plymouth spring hangers.
    Dave
  3. wheeldog57
    wheeldog57
    Spring perches?
  4. No shackle? Are they mounted at the rear of the spring?
  5. They are front buggy spring mount, the rear part is a shackle mount. I found the 40's Jeeps ones are cheap and about the same. Also note they are left and right sided.
    The front is just a heavy ass black bolt. If your bracket is toast you can fab one up. or get the jeep ones.
    I think Onix or something like that sells the jeep ones.
    https://www.kaiserwillys.com/category/suspension/shackles-parts
    Not that one end is shackled and one is fixed.
    Tman and chryslerfan55 like this.
  6. On my wife’s sedan
    9326B48F-2A66-4E00-AF49-9C5BA089349C.jpeg 79B8E4E0-B024-4EAC-84E6-CFAF434DD309.jpeg
  7. Totally forgot they mounted like that.
    Seems like the front mount could be easily fabricated
  8. FYI, if you dont want to run the stock shocks, the '37/38 have a lower and upper tube shock mount. similar to an F100 shock mount.
  9. almost 1/4" steel, sand blast the frame. then make sure the bolt holes are not oblong shaped. I doubt ther are rusted away, this is not a Ford Frame, its boxed in some sections.
    Tman and anthony myrick like this.
