Technical What are these called?
Discussion in 'The Hokey Ass Message Board' started by flynbrian48, Jul 18, 2018.
  1. flynbrian48
    flynbrian48
    Ok, not these, but the little cages tat go in the holes in the body they push into. Push pin clips? Trim pin pusher inner holders? I need to know what to search for to buy some for my '51 Pontiac wagon.
    Hnstray and chryslerfan55 like this.
  2. Hnstray
    Hnstray
    from Quincy, IL
    Barrel clips...is what the old timers called them.....at least in my neck of the woods.
    Ray
    54vicky likes this.
  3. flynbrian48
    flynbrian48
  4. jimmy six
    jimmy six
    I don't know if you get to the back of the but if you can they are tin nuts. 3/8" nut driver usually screws them on. The ones that go in holes and you push the trim on were called Tinnermens by old body guys I knew but that may have been who made them...good luck.
  5. saltflats
    saltflats
    from Missouri
    Like these?
    Hnstray likes this.
  6. deathrowdave
    deathrowdave
    from NKy
    Correct answer barrel nuts ! Under the “ Standard Parts “ info if working on a Ford and looking for correct part number
  7. Hnstray
    Hnstray
    from Quincy, IL
    Awwww "nuts" .........:D
    Ray
    54vicky likes this.
  8. 54vicky
    54vicky
    that is what some say when pushing emblem etc and you break emblem or one of the legs.:DI used much worse when I did so
  9. alanp561
    alanp561
    Scotch and water on the rocks?
  10. jeepsterhemi
    jeepsterhemi
    Clip, snap-on barrel type....
