Hot Rods What are these tools?
Discussion in 'The Hokey Ass Message Board' started by Frank Davis, Sep 16, 2018.
  1. Frank Davis
    Frank Davis
    I have a couple of tools that are unknown to me and everyone I have asked....maybe someone on this site can help me identify them. odd tools 1.JPG odd tools 2.JPG odd tools 3.JPG odd tools 4.JPG
  2. iwanaflattie
    iwanaflattie
    Flux capacitor lagging measurer
  3. Fortunateson
    Fortunateson
    Those were stolen from the Manhattan project!
  4. upspirate
    upspirate
    If there is a sight gl*** at the bottom of the spark plug tool, it was probably hooked up to compressed air and the valve was used to similate a combustion chamber to see if the plug would break down when the valve is opened. The bracket would be grounded, and a plug wire would be hooked to a coil. We had a tester that would do the same thing and also test coils in marine motors cl*** in high school
  5. Chuck Craig
    Chuck Craig
    from Ocala FL
    Looks like parts to a spark plug cleaner that uses compressed air.
    Unkl Ian, upspirate and Hnstray like this.
  6. Frank Davis
    Frank Davis
    Yes, it has a sight gl*** opposite of the spark plug location....upspirate, I think you are on to something......I have had several folks suggest that it is some sort of spark plug cleaner, but the sight gl*** remains crystal clear......and the other tool?
  7. The other tool might be a ball joint gauge.
    Had something like this at a dealer I worked at on the “ old tools shelf” you are missing some rods and bell cranks and such that sit in the hole on the arm that swings and the black base should have markings on it
  8. Bleach
    Bleach
    I don't think that it could be a spark plug cleaner. The gl*** would fog up quick from the sand blasting it. I think it's from a spark plug tester. It looks remotely like it could be from something from this.
    upspirate likes this.
  9. upspirate
    upspirate
