Technical What are these wheels?
Discussion in 'Traditional Hot Rods' started by anteek49, Dec 5, 2013.
  1. anteek49
    anteek49
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    Value ? not much $5 each maybe. Ford or Jeep would be my guess.
  3. Hnstray
    Hnstray
    from Quincy, IL
    '40s Lincoln or late '40s/early '50s Chrysler NY/Imperial........is my thought.
  4. metal man
    metal man
    I'm not real sure what those are,might be Mopar. I'm not aware of Ford ever using clip for the hubcap. Without knowing what they are, and they need sandblasted,etc., I would tend to agree with John ^^^.
    Someone here will know what they are.
  5. F-6Garagerat
    F-6Garagerat
    40's Lincoln used the clips and some of the later F series.
  6. anteek49
    anteek49
    Might be late '40's Lincoln; I had a convert.
  7. kruzr
    kruzr
    I would say early Chrysler products, But there is no hole for locating pin on these wheels so that leaves Chryco out, had a second look ,noticed no hole.
    Aren't all early Fords 5 on 5 " bolt pattern with bigger center hole.
    Need to measure them a little more.
  8. manyolcars
    manyolcars
    Jeeps never had hubcaps so they are not jeep.
  9. adam401
    adam401
    40 Lincoln according to*****ty photo on my*****ty phone
  10. 1953naegle
    1953naegle
    53' chevy had that style of rim and had clips in the middle. I can measure my mine to see if it's a match. What's the diameter of the recess with the clips around it?
  11. HammerDown
    HammerDown
  12. kruzr
    kruzr
    Ok. I agree Lincoln, I see measurement 5x 5 1/2" .
    Chev Pontiac had clips but bolt pattern was 4 3/4" .
  13. 3wLarry
    3wLarry
    from Owasso, Ok
    With the 5 on 5 1/2 bolt pattern part of his statement...can't be Chevy...it's 40's Lincoln.
    kidcampbell71 likes this.
  14. 55willys
    55willys
    center hole also too small for Jeep
  15. edwardlloyd
    edwardlloyd
    from Germany
    so worth more than 5 bucks a piece then.
  16. F-6Garagerat
    F-6Garagerat
  17. 1941ihkb5
    1941ihkb5
  18. iwanaflattie
    iwanaflattie
    Ryan is gorgeous btw
