Technical What Are These?
Discussion in 'The Hokey Ass Message Board' started by Speed Gems, Mar 24, 2022.
  1. Speed Gems
    Speed Gems
    Looking online just now I seen this video of a Flathead with what looks like two canisters one going to each head. I can't post video from Facebook on the H.AM.B. so here's a screen grab.
    tractorguy and NoSurf like this.
  2. Beanscoot
    Beanscoot
    An "air burping" setup?
    What does it say on them?
    tractorguy likes this.
  3. NoSurf
    NoSurf
    The one on the left says "french roast".
    And the right says "espresso" something.
  4. redo32
    redo32
    The one on the left says... French Roast.
    too slow
    Speed Gems and NoSurf like this.
  5. oldiron 440
    oldiron 440
    If they where running a tank instead of a radiator wouldn’t they need expansion tanks?
    Or maybe they were using them for more capacity.
    Speed Gems likes this.
  6. Speed Gems
    Speed Gems
    It's been said that the only thing Flatheads were good for was boiling water so maybe he put coffee in them with a pet **** in the bottom to fill your cup.:rolleyes::D
    clem, Beanscoot and Petejoe like this.
  7. blowby
    blowby
    from Nicasio Ca
    Whatever they are, the compe***ion must have been leafing through the rule book.
    They may be the highest point in the cooling system. Burp..
    hrm2k and Speed Gems like this.
  8. Speed Gems
    Speed Gems
    Side view
    hrm2k likes this.
  9. Mr48chev
    I was thinking added capacity. Plus what appears to be a burp hose setup.
    El Mirage Garage, bchctybob and hrm2k like this.
  10. Speed Gems
    Speed Gems
  11. bob b.
    bob b.
    from peoria az.
    ice bucket
  12. blowby
    blowby
    from Nicasio Ca
    My first thought but how do they fill?
    Don't see the water pumps.
  13. squirrel
    Percolators.
  14. If no water pumps. Then maybe expansion tanks
    But why a radiator and no pumps
  15. DDDenny
    Those are 265 Chevy seed pods..........
  16. lippy
    lippy
    from Ks
    I had a friend who was always building gadgets he didn't need. Looks like one of his deals. :D
    Beanscoot and Speed Gems like this.
  17. blowby
    blowby
    from Nicasio Ca
    Model Ts didn't have pumps. Thermosyphon cooling. The way the water goes in the bottom and out the top, might be a version.
    But it may have pumps, I just can't see them or a belt in the photos.
    anthony myrick likes this.
  18. mgtstumpy
    mgtstumpy
  19. Speed Gems
    Speed Gems
    @mgtstumpy I didn't want to spoil the fun already but after I found the page I was on I went back and read some of the comments and they are called "Swirl Pots".
    49_Baldwin-Mercury-Spcl-DV-17_PBC-e001.jpg 49_Baldwin-Mercury-Spcl-DV-17_PBC-e002.jpg
    Just Gary, NoSurf, aircap and 3 others like this.
  20. 19Fordy
    19Fordy
    That rubber elbow coming off the head looks like a weak point in the system.
    Would be better if a 90 degree alum elbow was welded to the water inlet on the head
    and then joined to the water pipe by a small piece of rubber hose
  21. stuart in mn
    stuart in mn
    I was just scrolling down to the bottom of the thread to suggest swirl pots, but you figured it out already. :)
    BJR and Speed Gems like this.
  22. TCTND
    TCTND
    Since it all goes into the header tank anyway this is essentially 15 pounds of nonsense.
  23. Speed Gems
    Speed Gems
    If you read the section "Bill Pollack on driving the Baldwin special" It says they cut down the impeller on the water pump, I ***ume he means the fan, the water circulated naturally. Hot water up, cold water down. http://www.tamsoldracecarsite.net/BaldwinSpecial3.html
  24. Don't kno whut thay ar, but thay make it idol funnie
  25. Speed Gems
    Speed Gems
    Back up for any more info. on these. It looks like there was an article on the Baldwin Special in the Jan. '52 issue of MOTORSPORT magazine, unfortunately I have Dec.'51 and Feb. '52.:rolleyes:
    Hollywood-East likes this.
  26. BJR
    BJR
    Do they swirl the other direction in the Southern Hemisphere?
    NoSurf, Just Gary, Speed Gems and 2 others like this.
  27. Speed Gems
    Speed Gems
    I guess I'd have to ask the guys on the Australian Flathead FB page.:D I was wondering if they would work well on the street or just for compe***ion? They would look cool on an Hot Rod with no hood at the local car show or in the parade.
