Event Coverage What are YOU doing to get ready for the 2015 Meltdown Drags?
Discussion in 'The Hokey Ass Message Board' started by Okiedoker, Sep 30, 2014.
  1. Zettle Bros.
    Zettle Bros.
    Steve got the hood and roof straightened, primed and sanded last Sat. on the Falcon.
    Tickety Boo and powrshftr like this.
  2. wrenchbender
    wrenchbender
    That's what I would say too when you are still setting at the line and Scott's crossing the traps lmfao
    30dodgeboy likes this.
  3. I thought I heard him hollerin, "Did I win?... Did I win?" after that one.... :p
  4. right on brother...
  5. ..,laughing so hard I can taste my spleen!
    enloe likes this.
  6. haaaaaaa haaaaaaa haaaaa haaaaa hssssa haaaa. Get the paddles, I'm going into cardiac arrest!
  7. rawcjw19
    rawcjw19
    What line lock is recommended? where do I get one? Do you just wire them up to a toggle switch
  8. .., you put your right foot down, you pull your right foot up, you put your right arm up and you shake it all about, you do the Okie Dokie, and you burn your tires out, that what its all about, hey..,
  9. Hurst & B&M have them, and they come with easy instructions, or you can private message Racer X/The History Channel for the full tutorial.., make sure you pack a lunch on option B.
    30dodgeboy, 55belairx2 and II FUNNY like this.
  10. rusty1
    rusty1
    ...did they have line-locks in the 60's
    II FUNNY likes this.
  11. II FUNNY
    II FUNNY
    Yes, about 1965 hurst had one...I have the original article on them at home. When I get a chance I will post it....the new hurst ones have the same vintage switch that they originally had.
    Tickety Boo and beebee78 like this.
  12. saltflats
    saltflats
    from Missouri
    There was word that the Jegs ones are **** or that is what I read in one of the southeast g***er build theads.
    I have hurst on both my cars because I don't make the horse power to do a burnout without one.
  13. powrshftr
    powrshftr
    Hurst,B&M,I believe Biondo,and a few other manufacturers all sell a kit,and it requires putting a solenoid in-line with your front brakes,so that when you apply the front brakes,the hold the ****on,then release the pedal,the power to the solenoid holds pressure in the front brake lines only.
    This allows you to do burnouts without cooking your rear brakes.
    Scott
  14. Tickety Boo
    Tickety Boo
    from Wisconsin
    When you first use one (watch your r.p.m.s) once the tires break loose it is easy for
    flywheel inertia to zing past rev limit.
    Dropped a valve one time (broke the retainer):oops: on a burn out. Thought I had my burn out
    routine down that hot day, but when It got cool that night (about 4th round) the motor made
    a lot more power zinged past my 8000 chip.:rolleyes:
    May have similar conditions this year when night racing.
  15. saltflats
    saltflats
    from Missouri
    Just a dumb question
    If one was to run a duel point dist with one point set would it make a difference witch ones one would leave out?
  16. Salty, if you need the other set of points, I'll send you the $6.27. ;)
  17. I thought the rolled sprag transmission bomb issue, was from doing high rpm burnouts, starting in low gear, and mainly with Torque ****es and over speeding a drum, or sprag etc.
  18. I'm pretty sure, the whole line loc thing, actually started out with Hursts, "Hill Holder"/"Roll Control" set up to help the hippies from burning up the clutches in their VW's, in the mean streets of San Francisco's hills.
  19. saltflats
    saltflats
    from Missouri
    Well Ric the ones I was looking at were $32.99 ****t what if one wanted to use said dist to trigger a 6AL box.
    Ric I am simple minded so the less I have to **** with the better I will be and the ones around me. I am not a violent person but one of my buddies always said he wanted to be around when I loose it.
    69fury likes this.
  20. 69fury
    69fury
    from Topeka
    I've still got points in my mill triggering the 6AL box- works great-points last forever since they don't have to handle much current-rick
  21. 55belairx2
    55belairx2
    Now THAT was some funny sh*t!!! Score one for the Salt Miser!
    powrshftr likes this.
  22. 55belairx2
    55belairx2
    Yeeeeeheeheeheeeeeee!!!
  23. rawcjw19
    rawcjw19
    Thanks, figure I may as well plumb one in now. I was wondering how I was going to get my big *** feet in there to do a burnout. Channeled model A,s look cool but sure aren't roomy
  24. 55belairx2
    55belairx2
    One thing to remember is that the line loc, when engaged, only holds the same amount of break pressure as was being applied by the brake pedal when the line loc was set. In other words, setting the line loc doesn't automatically lock the front brakes. If you are only applying slight pressure to the pedal when the line loc is set, it will hold the same amount of pressure when you let off the pedal. This is useful when staging a stick car and your feet are busy with the clutch and accelerator. If you want the front brakes locked when you set the line loc, apply lots of pressure to the brake pedal or pump it a few times before hitting the line loc ****on.
  25. sonic03bluegt
    sonic03bluegt
    from sc
    I did some ch***is work, engine, trans, gear, gauges, wiring, wheels/tires, interior, aluminum, body work and paint getting ready for the meltdowns! I can't wait, I have been wanting to go for several years but even more excited now that I have my own car to bring
  26. bigslim55
    bigslim55
    That's A Sweet Ride...! Can't wait to see it in person...! Lil over 2 months, can't wait...!
    Jimbo...
    sonic03bluegt likes this.
  27. powrshftr
    powrshftr
    Damn that car looks good!!!!!!:D
    Scott
    beebee78 and sonic03bluegt like this.
  28. is it a Mallory or Accel, or factory Mopar, or 409?
  29. My little bro is all grow'd up and now teaching guys on the HAMB how to properly finesse the line loc.., I couldn't be prouder, sniff.
    Tickety Boo, 55belairx2 and powrshftr like this.
  30. powrshftr
    powrshftr
    I may have to stay after school for extra help....I have about as much finesse as a bull in a Frickin china shop!lol!
    If Marc's performance last year was any indication,he could be putting on a driving clinic this year!:)
    Scott
    beebee78 and 55belairx2 like this.
