Hot Rods What are you guys using for steering wheels in your Model A's
Discussion in 'The Hokey Ass Message Board' started by scoop, Nov 25, 2021.
  1. scoop
    scoop
    My wife is driving me nuts, I have 51 Dodge steering wheel, I thinks it's cool but it is large. What are you Model A guys using? I have a GM column but I can work with other brands.
    dana barlow likes this.
  2. -Brent-
    -Brent-
    What is the era of your build?
    Tim likes this.
  3. denis4x4
    denis4x4
    from Colorado
    Speedway 13” race car wheel
    2Blue2, Joe Blow and stillrunners like this.
  4. Robbie Horn
    Robbie Horn
    from Axtell
    It’s a GM steering wheel cross dressed as a Packard steering wheel but indetifies has a Model A steering wheel. 81A5583B-FF18-4F12-9C08-D011FF3FCB3F.jpeg
  5. scoop
    scoop
    Late 50's
  6. scoop
    scoop
    That is a confused steering wheel!
  7. kb cookout
    kb cookout
    4 spoke, on a stock A column and still using the horn rod / light switch
    later kb
      354.4 KB
    Packrat, Hnstray, WalkerMD and 9 others like this.
  8. 34Phil
    34Phil
    -Brent-, Hombre, 2Blue2 and 5 others like this.
  10. AHotRod
    AHotRod
  11. scoop
    scoop
    I showed my wife a picture of one,nope!
  12. jaracer
    jaracer
    Fairly flat Bell style from Speedway Motors.
    Hombre, 2Blue2, mad mikey and 2 others like this.
  13. Lloyd's paint & glass
  14. Tim
    Tim
    from KCMO
  15. Canuck
    Canuck
    Flat 4 spoke on a 70s GM column. Found the tilt wasn't really needed, ended up using it in the neutral position. Larger would have looked better but would have been too close to door. Dash is 34 Chevy Master,
  16. Joe Blow
    Joe Blow
  17. Chicster
    Chicster
    65 Corvair van
    Packrat, curbspeed, Driver50x and 8 others like this.
  18. cabong
    cabong
    When I bought my chopped '30 coupe, it was not drivable. Not because it didn't run, but because you couldn't get it it, no less drive the ******. The wheel and column were near verticle, and with the 3-speed floor shift, there was no room for legs or feet. Problem solved... 1953 Ford column including shifter and wheel. Even the big wheel is okay, as it feels like 1955, and isn't that what it's all about. E-Brake is stock, and fine. Any guesses on the gas pedal. It's something I always wanted to do... Dash uses Mustang GT gauge cluster with concave gl***. I painted the orange needles white to look old. The bezel was a pain, but worth the work. None of the spacing is concentric, although it doesn't show. We machined the bezel, then had it nickel plated, which looks much better that chrome.... It is a blast to drive, and it usually takes about half an hour to get back into the correct century. The dash cover is made from the upholstery out of my buddies Henry J, and was the original stuff. The seat is similar, but uses an 1955 aftermarket Ford pickup seat cover for the insert material. Ironically, people ask when I'm going to paint the critter. I tell them, it already is. Others ask about fancy wheels.... I tell them it has fancy wheels. Fronts are '40 Ford, and rears are wider, from a '40 Ford pickup. They usually turn a walk away, shaking their heads..... Oh well !! Model A Dash panel 003.JPG Model A Dash panel 012.JPG
  19. Michael Ottavi
    Michael Ottavi
  20. catdad49
    catdad49
  21. GordonC
    GordonC
    The one I originally had in there but needed just a bit more knee room so had to go to a dished one.
    hfh, akoutlaw, Hombre and 2 others like this.
  22. dana barlow
    dana barlow
    from Miami Fla.
    Steering wheels canbe a cool add,but also tell a lot,just by the look!
    Like if they are tiny go cart size= One of 3 things; #1 driver maybe a big guy that can't fit behind a bigger wheel*.
    #2 the rod builder didn't put the column in the right place an too lazy to move *it!
    #3 =under 13 in. =bad control of any hotrod with more then 50HP,and looks like it!>as in cartoon! So fail at engineeing skills. "Booo-Whooo my car steers hard",an often have more things wrong as well..
    I used a stock 30A wheel to start with in 1959 {I had a 30 box in my 28,for a time in my rod,both the box an wheel were not in super shape from 59 to 62,so they got replaced by a F1box an aftermarket wheel,then a Vaga Box n custom column,that I still use.
    Years later I was given a nice woodwheel 14in. that was same color wood,like my wood trim in my ****pit,by a Buddy"JJ" who had got it for his rod,but found out it didn't fit his. Seem to fit my own OK.
  23. 5window
    5window
    Traditional style Le Carra on a modified Chrysler Tilt-N-Scope column
  24. el Scotto
    el Scotto
    from Tracy, CA
    A guy walks into a bar with a steering wheel in his pants.
    The bartender says, "Hey, you know you've got a steering wheel in your pants?"
    The guy says, "Aaargh! I know. It's driving me nuts."
  25. Must be your first wife! ;):D
  26. el Scotto
    el Scotto
    from Tracy, CA
    I've used '40-47 Ford truck steering wheels in the last two Model A roadsters I've built. Good look and feel for the period correct car. Don't like anything that looks too modern.
    Old pic but only one I have handy at the moment...
  27. Cut it down. Cheap steel speedway 15" doner wheel for the rim, weld to your inner steel structure and blend the two together with epoxy. Did this on my GMC
    skip65 and dana barlow like this.
  28. scoop
    scoop
    Yep, 41 years. Good cook!
    Jrs50 and cactus1 like this.
  29. scoop
    scoop
    What's the diameter on that?
  30. scoop
    scoop
    Good one!!!!
