Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. I pulled the speedometer out of Old Blue this afternoon for access to the other gauge ***embly, and we had the speedometer rebuilt in 1989 and apparently 15 year old Andy thought only 2 out of 4 nuts were enough to hold it in. Gee, I can’t wait to see what else I did!!
  2. guthriesmith
    guthriesmith
    Lol…19 year old Jeff didn’t own a welder so used bondo to fix rust. So, 52 year old Jeff gets to fix that right later with less time and energy.
    enloe, orbitup, scotty t and 8 others like this.
  3. atch
    atch
    Andy, fwiw let me tell you a quick story:
    A few years ago I decided that the 283 in Clarence was so tired it needed to be replaced. I went to my friend, a lifelong machinist and parts house owner, to ask what it would cost to bring him the bare block, him to bore it and supply/install pistons & rings. He told me he would NOT tell me since I could go to Summit or Jegs and order up a new crate 350 for less than what he would charge me. That's why Clarence got a crate 350 from Summit the next week.
    The 283 had sentimental value to me and still resides under a bench in my shop. The engine was in a 1966 Impala that my grandmother bought in the fall of 1965 and has never been out of my family.
  4. I don’t blame you one bit. I would keep that 283 forever. That is such wonderful story, I get super sentimental about things like that.
  5. Black_Sheep
    Black_Sheep
    My BIL finally returned my wheel cribs so I’ve spent the last couple evenings changing oil, looking things over, checking for loose hardware, etc… While it’s convenient I’ll do a little undercarriage cleanup and the truck will be ready for the road. We’ve had some nice rain this week so the road salts should be washed away, time to throw in some fresh fuel and go cruising…
  6. TA DAD
    TA DAD
    from NC
    enloe, pila38, chevy57dude and 12 others like this.
  7. Cosmo49
    Cosmo49
    After discovering I had a bad starter and not a failed battery I got her to start. Alarmed by the amount of moisture coming out of the tailpipes I checked the plugs. Water/coolant came pouring out of #5 spark plug hole. Going to do a deep dive tomorrow, a little down about the situation but it's just a mechanical thing that needs to be found out. Hoping for the easier cracked head than block.
    enloe, saltflats and osage orange like this.
  8. More pics please! Looks amazing.
  9. Black_Sheep
    Black_Sheep
    Thanks, there’s a link for my build thread in my signature…
  10. 1971BB427
    1971BB427
    from Oregon
    Had a little free time yesterday, so since my '39 is still waiting for spring to arrive I did a small change to my steering column. It's been a little too high ever since I finished the car a couple years ago, so I tackled the job of lowering it.
    Did a little work to open up the penetration at the floor about 1/2", which is still covered by the rubber seal once I lower the column mount at the dash. Built some 1.25" spacers to let the column drop about 2" at the wheel. After bolting in the spacers I made a new cover to go between the column and the dash to cover up the taller mounting hardware. Only took a couple hours, but now my tilt column is in the middle of it's range and not at the lowest point all the time.
  11. seb fontana
    seb fontana
    from ct
    Trying my Neway valve seat cutter on a cut down Crosley block, seems to do ok but I have issue seeing with My Head and the Bridgeport Head trying to occupy the same territory.o_O Magic marked valve at seat area and couldn't get a readable seat contact pattern like they do on Utube.:( Maybe using wrong marker?
    pila38 likes this.
  12. 34Larry
    34Larry
    Just ate a big lunch, answer is:..........Stay'n awake.
    saltflats and swade41 like this.
  13. 57 Fargo
    57 Fargo
    Logistics of getting the two vehicles I bought this week home, both are 3 hours away in different directions….
  14. Or get a tether for your gl***es!
    seb fontana and osage orange like this.
  15. Last edited: Apr 13, 2024
  16. seb fontana
    seb fontana
    from ct
    I would most likely trip over the tether. Wife suggested some type of beeper finder thingy.
    '28phonebooth likes this.
  17. jimmy six
    jimmy six
    On March 9th I posted the engine was back in our roadster for Bonneville 2024 and the puzzle on where everything goes was to go would begin. 1 month was all it took, it only needs coolant, fuel and it will be for ready testing.
    The exhaust system received an inner and outer coating for this year which should bring the under hood temperature down. IMG_6442.jpeg IMG_6443.jpeg
    swade41, Oneball, 61Cruiser and 10 others like this.
  18. guthriesmith
    guthriesmith
    Are these two cars HAMB-friendly so we can talk about them here? If you already said what they were somewhere, I must have missed it. :D I’m just curious as the hunt and kill are some of the funnest parts of this hobby to me. The actual work part after that isn’t as exciting. :rolleyes:
    Quick question for you JD. How did you modify the intake to fit on the Jimmy, weld in aluminum or use epoxy to fix port mismatch? Roadster is looking good, you going to be at the May meet to give your grandson some seat time?
    osage orange likes this.
  20. 57 Fargo
    57 Fargo
    Yes they are both Hamb friendly, super excited about one of them! All will be revealed when the time is right!
    I don’t want to say anything until they are on the trailer!
  21. jimmy six
    jimmy six
    He’s not a club member and probably never will be. He doesn’t live in California. The intake is mine to know. It was a great idea 25 years ago and better ideas are out there today but at 80 I’m about thru with innovations. Thanks. My son and I might run November.
    SilverJimmy and Truckdoctor Andy like this.
  22. swade41
    swade41
    from Buffalo,NY
    On the 41 I decided to try the ol forearm burner again, I used it once on the Henry J with mixed results, finished with the old standby 2 person pump n hold.
    I figured if anything it could **** most of the air out of the system, instead it ****ed the life out of my grip. Lol
    Instead of bothering anyone I did the single bottle crack the bleeder and pump method to finish it up. I couldn't find my old bottle so I made a new one, took one of the security cameras and put it next to the bottle so I could monitor it on my phone while pumping the pedal.
    When I removed it the damn thing was pressurized and it shot brake fluid back out of the hose and all over the painted backing plate and back of the tire !
    Now that the bottle was covered in brake fluid I didn't want to take it apart and drill a vent, I mean I can easily tilt the bottle till the hose is out of the fluid so when I pull the hose it'll just drain down into the bottle. NOPE, ******* sprayed all over everything on that side, so I spent a few minutes spraying everything down with the handy windex.
    Now I'm the kind of guy that thinks these things become a challenge to my manhood or some ****, I'll show it I can out smart it ! I figure I can pinch the rubber hose to stop the flow when I pull it off the p***enger front, NOPE it starts spraying anyway so I put my thumb over the end, really sprayed when switching positions.
    I mean when it's spraying it's really shooting a stream like you were squeezing the mustard bottle when it all of a sudden becomes unclogged, Benny Hill could've used this as a skit. LOL
    So here I am with with my thumb capping the explosive line and thinking I only have one left, surely I can get it on the last bleeder since my hand is already soaked, what sense does it make to release it outside. I get to the driver side and quickly realize I'm holding the line in my left hand, but it needs to be in my right, what the hell let's go for it.
    You guessed it, **** everywhere, but I got it done, unscrewed the cap to release the pressure when removing it for the last time . I spent a fair amount of time spraying everything down with windex and cleaning all of the painted parts and covering the floor with kitty litter.
    Today I cleaned up all the kitty litter and went back to sanding the valve cover with 320, ready to start wet sanding with 400 now, screw those brakes lol
  23. fastcar1953
    fastcar1953
    Working on wife's nova again. Shifter and steering column. IMG_20240412_190755270.jpg IMG_20240412_190619741.jpg
  24. choptop40
    choptop40
    Got a pair of skirts for the Desoto..... 3CF2759E-60E3-44FD-A6A8-2110981099EA.jpeg 4F3E5B8A-A2BA-42E1-BEB6-C18E4BB15E16.jpeg
  25. saltflats
    saltflats
    from Missouri
    Crew chief for this car today.
    enloe, loudbang, pila38 and 9 others like this.
  26. choptop40
    choptop40
    That's Bbbbad..!!!
    mad mikey likes this.
  27. atch
    atch
    Will we see the Nova at cruises this year?
    Way cool; what engine does this have?
    enloe and guthriesmith like this.
  28. guthriesmith
    guthriesmith
    Today…working on taxes since I hate doing them and always wait until the last minute. But, hoping I can head down to Texas tomorrow to pick up the set of 15x8 slot mags that I have been looking for to match the 15x4’s. Looking forward to an older look on my slightly OT car. I already bought the wheels, just need to get them picked up and then dismount the ugly tires, polish them, and mount my slicks.
    enloe, Moriarity, Tickety Boo and 9 others like this.
  29. fastcar1953
    fastcar1953
    @atch hopefully yes. I only live a block away . It runs just need to put it together.
    I had it uptown last weekend. Driving while sitting on a milk crate.
    enloe and 427 sleeper like this.
  30. swade41
    swade41
    from Buffalo,NY
    Can't go wrong with slots, older photo but I think I've got 22 currently lol
    15x14's, 11's, 10's, 4.5's, 4's and 3.5's
    enloe, 1940Willys, loudbang and 7 others like this.
