Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Almostdone
    Almostdone
    sometimes you’re the windshield, sometimes you’re the bug… a fortunate day!
    John
  2. swade41
    swade41
    from Buffalo,NY
    I pulled everything off the top of the blower to remove the restraints, then put it all back on, got to be able to see those new valve covers lol
  3. 1971BB427
    1971BB427
    from Oregon
    Been trying for years to figure out how to change the carb angles on my Austin g***er's tunnel ram. I set the engine in the frame rails low to keep the crankshaft centerline below 24", but also dropped the tailshaft on the trans to help keep driveline angles at less. The carbs have to set sideways on the old 70's Holley Pro Dominator, so I have kept the float levels lower to not flood the engine from the angles.
    Wanted to put carb wedges in for years, but wedges aren't made to correct side to side, just front to rear. I have had them sitting around all that time, so today I experimented with some carb spacers to simulate a carb, and used gaskets to figure out how to modify the wedges.
    I marked the wedges with a felt pen, and used my bandsaw to cut the holes out into slots that allowed them to be mounted sideways. Pulled my carbs, and put gaskets below and above the wedges turned sideways. Slid the wedges on, and remounted the carbs. Had to so some minor linkage adjustments, and reset float levels, but it worked to level the carbs!
    Took it for a spin, and it doesn't run out of gas now on a long hard pull. Used to die when I shut down at the end of a 1/8th mile run.
    Almostdone, rod1, enloe and 9 others like this.
  4. squirrel
    I ran 650s sideways on the blower in my 55 for a long time, they were at quite an angle, never had any issues with it. Good to see you're happy with it now
  5. fastcar1953
    fastcar1953
    Dreaming of putting a blower under the hat. 437409807_7849571758400375_6711169903449104434_n.jpg
  6. Duster418
    Duster418
    Here’s what I’m working on. 418 stroker build. Have about 4 pounds of welding rod in the runners so they could be opened enough for head ports. Excited for this engine combo.
  7. 3 students came to school today to wrap up some projects for a contest this week.
    This is one of em
    Almostdone, enloe, saltflats and 18 others like this.
  8. deathrowdave
    deathrowdave
    from NKy
    That’s a tough one on 37 - 39 Chebby . Should be a hole in the top of the frame rail that’s damn near dead nuts
    guthriesmith likes this.
  9. I swapped from an Edelbrock to a Holley carb on the 56 belair after the brake swap.
  10. guthriesmith
    guthriesmith
    I’ve made that same swap a few times. I know Holleys way better than I know Edelbrocks and would much rather run the Holley. :cool:
  11. I’m learning holleys now @lumpy 63 is my mentor
    enloe, Tickety Boo, mad mikey and 5 others like this.
  12. swade41
    swade41
    from Buffalo,NY
    mad mikey, loudbang and guthriesmith like this.
  13. swade41
    swade41
    from Buffalo,NY
    I'm pretty sure you nailed the stance, tire size and engine choice, it already looks bad ***.
  14. swade41
    swade41
    from Buffalo,NY
  15. lumpy 63
    lumpy 63
    Do you need the spacers? the edelbrock heads should have a higher lip and with a thick gasket I would think the MT covers would clear especially without a girdle.
  16. swade41
    swade41
    from Buffalo,NY
    I had the spacers and I didn't trim the drippers so naturally I thought the combo would work, the spacers would also make the rear breather clear the throttle linkage bracket.
    I ordered a pair of Ansen spacers that are thinner around the bolt hole and edges, should be here next week. Hopefully they'll work or I'll have to remove the drippers and clearance that throttle bracket.
    enloe, Tickety Boo, mad mikey and 6 others like this.
  17. 0ldracer
    0ldracer
    Here you go HOTRODPOWELL.....A couple of the guys you mentioned!! Fred Dave MAS.jpg
    rod1, enloe, mad mikey and 11 others like this.
  18. Duster418
    Duster418
    How do you like the prodominator inatke? What rpm do you spin it? Looks good
    Tickety Boo and mad mikey like this.
  19. 57 Fargo
    57 Fargo
    Finally got the barracuda out in the light of day…
    Still have some little stuff to finish, jumps out of reverse, but doesn’t go all the way into reverse to start with. Put hubcaps on it, finish the headlight trim rings. Etc.
  20. Looks like a cool ride and a great car for Lloydfest!
  21. swade41
    swade41
    from Buffalo,NY
    mad mikey likes this.
  22. 1934coupe
    1934coupe
    That's a pretty serious Willys! Any pictures of it from the day? Good luck with it, I know a little about getting old drag cars back to what they were. It's a lot of work but worth every minute espesially when someone comes by and says "I remember this car, I saw it race at..."
    Pat
  23. mad mikey
    mad mikey
    Here is the injector hat on my 2x4 blower set up. I fabricated a adapter plate and a frame to fit inside it which I modified a K&N filter to reside in the frame. Made linkage, and it works great. I always wanted one and received it at Christmas. I can't afford Mechanical Injection, and this is a street car primarily now, so I don't wish to hear any flaming. WIN_20240424_15_57_48_Pro.jpg WIN_20240424_15_58_26_Pro.jpg WIN_20240424_15_59_41_Pro.jpg
  24. squirrel
    loaded up Plan II....it's going to a new home tomorrow
  25. 427 sleeper
    427 sleeper
    I just can't like this post...
    As much as I'd like to...
    I hate change...
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    I bet that car kicked and screamed and dragged its feet the whole time you were putting it on a trailer....
  27. 427 sleeper
    427 sleeper
    Wouldn't be surprised if it was trying to gouge somebody's eye's out... :eek:
    scotty t, enloe and Moriarity like this.
  28. deathrowdave
    deathrowdave
    from NKy
    What am I working on ? Recovering from double hernia surgery . Open cut , tough goin for 2 weeks so far . If anyone wants to settle up with me now is the time !
    scotty t, enloe, saltflats and 5 others like this.
  29. swade41
    swade41
    from Buffalo,NY
    I jumped back over on the Henry J today, took my gas pedal out and shortened the middle of the short arm 1/4 of an inch and welded it back together.
    On the previous test drive it didn't want to fully return to idle, it had a slight hangup and kept it at 1400 rpm unless you lifted it with your toe then it easily went back to idle.
    All seems like it's good now, I'll see on the next test drive, also added that roll pin in the middle to keep it from sliding left/right.
    pila38, saltflats, loudbang and 9 others like this.
  30. fastcar1953
    fastcar1953
    Seeing what a blower might look like on my truck. 437409807_7849571758400375_6711169903449104434_n.jpg
