Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. fastcar1953
    fastcar1953
    Saw the weiner mobile today and hauled a dinosaur home. 438216901_7863529370337947_5323759789493670367_n.jpg 438253204_7863655213658696_5926710847518766799_n.jpg
    skooch, scotty t, enloe and 13 others like this.
  2. swade41
    swade41
    from Buffalo,NY
    enloe, guthriesmith and fastcar1953 like this.
  3. swade41
    swade41
    from Buffalo,NY
  4. 57 Fargo
    57 Fargo
    Drove the Barracuda down the highway, put a whole 4 miles on it. Adjusted shift linkage and it now stays in reverse. Speedometer doesn’t work though….
  5. Balljoint
    Balljoint
    Brake lights, tail lights and turn signals that refuse to work, but on a rare occasion they do for a few minutes. Suspect a ground issue but it will have to wait until next week.
    mad mikey and chryslerfan55 like this.
  6. chevyfordman
    chevyfordman
  7. swade41
    swade41
    from Buffalo,NY
    Right on, it looks mean too
    Here's Fred Bear's reply about your Willys
  8. lumpy 63
    lumpy 63
    20240425_083252.jpg Picked this up today.
  9. 26 T Ford RPU
    26 T Ford RPU
    Oh goodie, another Willys Coupe thread! JW
  10. lumpy 63
    lumpy 63
    44145.jpeg Also came home with a very odd 1968 427...appears to be never cracked open code IB police 385hp 427 . I've heard about cop motors never actually seen one:cool:
  11. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Finished rebuilding the headers on the blower motor. They had cut them off to go into another car. And the install was never finished. I am slowly undoing many things they did.Also working on converting my cal custom scoop to a real deal functioning injector hat. Lol IMG_2179.jpeg
  12. squirrel
    I think I took apart a big block once that hadn't been apart before...it had silver paint on each side of the cork valve cover gaskets. Along with other clues. This was a very long time ago, though.
  13. swade41
    swade41
    from Buffalo,NY
    I spent way to long today sneaking up on the fit of the fender lower dog leg on the Henry J.
    The collector ended up right where that fender piece attached so I had to cut around it, just roughed in for now.
    The upper mount is still good but I totally cut off the lower mount hole on the fender and a small portion of the cowl where it attached. My plan is to make a mount that bolts to the collector flange since the engine is solid mounted, should work out fine.
  14. Today was school day. Little Truckdoctor has a John Deere round fender with a Kohler that hasn’t run in 3-4 years. I realize that part is probably O/T, but the point of my post isn’t. I taught him how to diagnose a non running engine. We checked for spark, of which there was none. Next, he learned how to diagnose a no spark condition on a point type ignition system. I explained how ignition points control the coil saturation and what happens when they open and close and how when points get a bad connection across them what happens. Then he learned how to check point operation with a test light. Next, he dressed the points with a point file. We checked and adjusted the gap and he was rewarded with a running Kohler K-181. After he got it running, then I taught him about the blown cylinder head gasket and the chirping noise they sometimes make. It was a good day for teaching and learning.
  15. atch
    atch
    Good on you Andy. Your son is a very fortunate young man.
  16. 26 T Ford RPU
    26 T Ford RPU
    Getting the fuel and PCV lines made on Jeep engine in the Belly Tank. JW
  17. TA DAD
    TA DAD
    from NC
  18. saltflats
    saltflats
    from Missouri
    Rebuilt the carburetor on one of my friends race car. Installed and dialed in, should be ready to go to the track next weekend for the start of are new tracks points series.
  19. pila38
    pila38
    IMG_4771.jpeg IMG_4772.jpeg IMG_4773.jpeg IMG_4774.jpeg IMG_4775.jpeg IMG_4776.jpeg IMG_4777.jpeg IMG_4778.jpeg IMG_4779.jpeg IMG_4780.jpeg IMG_4781.jpeg Rolled it out to get a suntan today.
  20. enloe
    enloe
    from east , tn.
    Went to the first local cruise in today. I am getting a new radiator for the wagon this week. The pushrods for the Corvette are supposed to be here this week. We will see how that goes.
    I messed my shoulder up Monday and wound up in the ER. the joint looks good but i believe that I have to some stuff in it. I have a MRI Tuesday and go back to the doctor the following week.
    We will see how things go.
  21. Truckdoctor Andy and enloe like this.
  22. saltflats
    saltflats
    from Missouri
    Enloe hope all goes well.
  23. I’m up to no good. Well i’ve been tinkering on these ole things now i’m working on a couple cold adult beverages 392D063A-D76C-4257-8AAB-63BEE7C49AF0.jpeg 56EF52B0-D33A-449E-9AC0-FFF9ECAB564E.jpeg
  24. enloe
    enloe
    from east , tn.
    Thanks I appreciate it. I have earned all of the aches and pains and injuries. I competed for too many years doing powerlifting and strongman stuff. Now I am reaping the rewards:).
  25. saltflats
    saltflats
    from Missouri
    Nice place Scotty. I did a frame up on a 70 LS6 for a customer, I sure had fun banging the gears on that rock crusher trying it out. Cam went flat on that one. That was the first I found out about the change in motor oil.
  26. lumpy 63
    lumpy 63
    I hope that pile 0 **** on the rack ain't dripping anything nasty on the Vette:p
  27. I have a wide ratio “ rock crusher” for the unmentionable car:D i love the grain truck whine
  28. Nothing left to drip:p you built the mill for it, is it gonna drip?
  29. lumpy 63
    lumpy 63
    You prolly should paint it ... Cortez silver would look good
  30. lumpy 63
    lumpy 63
    :p
    It probably will cause you screwed the pan and covers on .....:p
