Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Working on how to stop the oil leaking from around the dip stick flange on the sump without jacking the engine (8BA) off the mounts and removing the sump.
  2. Mike Miller
    Mike Miller
    That was the plan.
    Tickety Boo likes this.
  3. jeepster
    jeepster
    from wisconsin
    Used this stuff to cover that stuff. IMG_1158.jpeg IMG_1159.jpeg IMG_1160.jpeg
  4. jimmy six
    jimmy six
    Well known engine shop is willing to machine my Arias/Howard GMC 12 port for o-rings… I included the centering plate, stainless wire and plate guide dowels. Will be nice to start ***embly on the 14-1 engine. Now I need to get a steel cam roughed in…..getting a lot tougher today to get one of those done than I ever would have thought.. IMG_6505.jpeg
    lumpy 63, mad mikey, pila38 and 10 others like this.
  5. oldiron 440
    oldiron 440
    I built one like that for work only shorter so I could sit on a rolling work seat. It was probably twice the size and made from 5/8” plate with no casters so I moved it with a forklift. Probably my favorite work space.
  6. choptop40
    choptop40
    Fake lake pipes didnt agree with me...gone....upon closer inspection looks like a mediocre custom job... View attachment 6083158 CC5861D3-D145-4BBF-A959-C22872D27CD9.jpeg 703C26CE-E2F1-4BD5-BCC1-740028B3977A.jpeg A24EB8EE-E959-4CDB-948D-A1E61F51A476.jpeg B99CA3CB-AF6B-4640-80D3-8912BB0F50DC.jpeg
    mad mikey, pila38, swade41 and 2 others like this.
  7. choptop40
    choptop40
  8. choptop40
    choptop40
  9. hrm2k
    hrm2k
    Still beating on my roadster pickup. Finally getting all the needed pieces for the rear brakes. Things will move fast after that
    lumpy 63, enloe, 61Cruiser and 8 others like this.
  10. choptop40
    choptop40
    ....Remembered to mention I used this to heat up the Bondo / fibergl*** filler and s****ed off the filler with a putty knife, then a quick wire brush and done....no dust ....no grinding .....got this in the Hamb garage tips thread.... Screenshot 2024-06-03 6.39.22 AM.png
    enloe, mad mikey and pila38 like this.
  11. choptop40
    choptop40
    With the fake lake pipes removed I can now unbolt the Desoto nose.. ..Gonna be a lot easier to set the 350 back 6-9 inches / fabricate motor and trans mounts and firewall modification with the doghouse removed......
    '28phonebooth, enloe and 61Cruiser like this.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Watched my grandfather in Belgium (dad’s side) strip paint (non topic) with units similar to this. IMG_2810.jpeg
    lumpy 63, Tickety Boo, pila38 and 5 others like this.
  13. farna
    farna
    Putting a 2003 Duratec four in my 61 Rambler convertible. Had to rebuild the front suspension, and got side tracked making a disc brake bracket for Honda Accord front and rear discs. Was looking for a rear disc caliper that would be easy to use with park brakes, ran across the Honda (99-2012). Since it had the right bolt pattern (5x114.3mm.... 5x4.5") I figured why not try the front brakes as well? So now I'm making and selling front brake brackets for AMCs...
    Tickety Boo, enloe and hrm2k like this.
    I've created a dilemma through my own stupidity. I decided to ***emble my 351W with a p***enger-side water pump discharge, then made a bracket to accommodate it, ***uming the belt wouldn't interfere with the lower hose. And we know what happens when you ***ume. I'm about a half inch wrong in that ***umption, so I've got to come up with a solution that doesn't involve buying another radiator with a driver-side lower hose and a water pump with an outlet on the driver's side. Anybody know of a fitting or hose that does a short detour down before it goes back up to the water pump? I'm not asking for much, just a quick downward U-turn on that hose to avoid the belt. I guess I could go left a little to avoid the belt, too.
    pila38 and enloe like this.
  15. choptop40
    choptop40
    Copper plumbing elbows..45 and 90 degree.....they make a shortie for tight spaces...use with a short cut length of hose...go around.....solved many a oops I thought I had clearance moments...
  16. Thanks for the suggestion! Hotrodding 101. I'll get with my favorite plumbing supplier soon.
  17. atch
    atch
    These probably wouldn't flow enough water but they are available. From Honest Charley's for one. They are made for flathead Ford engines so there would be two of them on a vehicle.
  18. 57 Fargo
    57 Fargo
    IMG_5601.jpeg Just driving the little car to work. I’m really starting to like it.
    67drake, Tickety Boo, das858 and 4 others like this.
  19. Thanks, Mike. I'm open to all solutions and this looks like a good candidate, too. I hope someday to drive my '29AA to Columbia where my son is a pediatrician. That's my dream, but hurdles keep getting in the way.
    chevyfordman and 427 sleeper like this.
  20. Bandit Billy
    Bandit Billy
    Great pic! I had the same drip. Removed the pan, drilled the rivets, welded nuts inside the pan, made a gasket and bolted it on. It is probable that I will never replace that gasket in my lifetime, but someone may thank me later.
  21. Stock Racer
    Stock Racer
    Not sure you have the room but this is what I did. I cut up two hoses from NAPA and used a metal tube from Summit. IMG_4745.jpg IMG_4746.jpg IMG_4780.jpg
  22. RockyMtnWay
    RockyMtnWay
    Starting to fix/remedy things on the 53 that just bug the **** out of me.
    First…someone hacked the dash and put a super tacky clock in the hole. Hole was probably for something else at one point, but that cheesy clock gotsta go.
    Sorry no before pic, but couldn’t bring myself to snap one.
    Here’s the clock, the patch and the temporary coating til I get around to proper skim and paint.
    Gotta love that creative clock mounting bracket o_O:eek:
    Edit: So looks like the deluxe cabs came with AM radios and the control was mounted in that location. My truck is not a deluxe cab, so radio might have been a dealer upgrade or owner upgrade. Huh, learned something new.
    pila38 likes this.
  23. choptop40
    choptop40
    Cut off the p***enger fake lake pipe… slow but steady progress ..Rockers were nice underneath.. image.jpg image.jpg
  24. swade41
    swade41
    from Buffalo,NY
    I'm working out ideas for a rear tube bumper, tomorrow I'm going to swing by the Metal Supermarket place and see if they have what I need.
    I was looking at ordering it on line but shipping prices are ridiculous.
  25. pila38
    pila38
    Mine fell apart again.
  26. SuperDuperDoughnut
    SuperDuperDoughnut
    Pedal extensions for a short friend with a Austin Healey 3000.
    rod1, saltflats, pila38 and 5 others like this.
  27. HOTRODNORSKIE
    HOTRODNORSKIE
    It's been real slow at work these days so I sanded and polished my intake there beats playing ony phone. Before and after shots. 20240511_150413.jpg 20240608_141259.jpg
  28. pila38
    pila38
    Cleaning, painting, adjusting steering, new ubolts, plumbing the shocks:
    IMG_4881.jpeg IMG_4882.jpeg IMG_4883.jpeg IMG_4884.jpeg IMG_4885.jpeg IMG_4886.jpeg IMG_4887.jpeg IMG_4888.jpeg IMG_4889.jpeg IMG_4890.jpeg IMG_4891.jpeg IMG_4893.jpeg
  29. tarheelrodr
    tarheelrodr
    Fitting Mack Products wood bed kit in my 34 Ford pickup. PXL_20240602_190718953_Original.jpeg PXL_20240602_194536641_Original.jpeg PXL_20240604_221902449.MP_Original.jpeg
  30. lumpy 63
    lumpy 63
    Broke in the cam on the dirty virgin now I gotta put the inner springs back in.
