Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. saltflats
    saltflats
    from Missouri
    Got this P/O 9.3 third member ***embled for this car.
    Go's in this car.
    Going down Springfield way Friday to install it.
    enloe, guthriesmith, RMR&C and 11 others like this.
  2. I’ve only been able to work on small (under10 lbs) projects for a while but i’ve gotten a few things accomplished for my cough chevelle cough cough. And a couple small things for my Studebaker
    enloe, mad mikey, chevy57dude and 5 others like this.
  3. lumpy 63
    lumpy 63
    We can just say it's a 64 Shovell so Mark doesn't bust your chops:cool: Ultra rare factory big block:p
  4. It does have an aluminum grill and the key on the dash:rolleyes:
    enloe, Bandit Billy, lumpy 63 and 2 others like this.
  5. If you need a column with a switch, I have a couple. You can have the steering wheel also.
    enloe, scotty t and 427 sleeper like this.
  6. NOOOOOOO:)
  7. Do you still want these high back seats from the 90's? I know you really liked them :p
  8. LOU WELLS
    LOU WELLS
    from IDAHO
    New ISKY Street Grind Cam In The Fordy...(Spring Fever)... 21248487_1892237281100544_3801638008269377160_o.jpg
  9. chevy57dude
    chevy57dude
    Fixed the rusted out hinge area on the '55 hood and got it swinging on the car. Then discovered the hinge spring is broken.. Little progress.
  10. I have a brand new 57 spring, is it the same? I'll send it your way tmrw if it is.
    enloe, chryslerfan55 and chevy57dude like this.
  11. Come to think of it, I have a brand new 57 gas pedal also. At least I think I do. And some other bits and pieces from my 57 Chevy experience, I'll send them all to you!!! :D
  12. chevy57dude
    chevy57dude
    Thanks, Lloyd, the 55 spring is different. I do appreciate it!
  13. Still want it though? I've got your address on the box you sent the valve covers in.
    enloe and chevy57dude like this.
  14. chevy57dude
    chevy57dude
    No,I actually just liquidated all my surplus 57 stuff. Someone else could use it, though.
  15. OK big guy :cool:
  16. chevy57dude
    chevy57dude
  17. 1971BB427
    1971BB427
    from Oregon
    Finished up the installation of new front leaf spring packs for my '39 Chev coupe front axle. Fabricated a couple new lower shock mounts to make the shocks work again, and avoid buying 2" longer shocks.
    Then with my leftover time I dug out my old Mood gas pedal and made up a floor bracket, and installed that also.
    Just about done with my winter upgrades list, so last thing is to roll it outside, and climb underneath for a good cleaning.
  18. Loaded up a 292 Y in the bus that originally came out of the bus to use as a mock up engine for my Mercury
    Lloyd's paint & glass likes this.
  19. I finished up a collision job today, another happy customer, had plans to climb under my car to measure the drive shaft, and it hit me, that's not the correct transmission lol, Ashley said, and I quote, "well change the transmission and then measure it".... she's such a good helper. :rolleyes::D
  20. Tickety Boo
    Tickety Boo
    from Wisconsin
    Got the ladder bar cross member glued in the 56 g***er frame today, also the cage mounts in place.
  21. saltflats
    saltflats
    from Missouri
    Well it was yesterday
    Installing that chunk.
  22. I love that ****ing car man! Bad-----------***
  23. saltflats
    saltflats
    from Missouri
    I tried to buy that car but was just a little short and just couldn't justify the extra moneys. My good friend Russ bought it and it will be go in his collections of X frame Chevy 409 powered race cars.
  24. dreracecar
    dreracecar
    from so-cal
  25. swade41
    swade41
    from Buffalo,NY
    Setup new universal fuel sender in the new fuel cell for the Henry J, hopefully it's somewhat accurate.
    I lost the Allen wrench while working on my lap, looked in my pockets, the floor, my waist ban area, pockets again, pants cuff.
    It wasn't until I took it off my lap and put it on the table to notice where it was lol
    Later I took it back apart to figure out how to get rid of that tail, since it wouldn't fit in the hole in the cell or allow the gasket to slip on...duh
  26. NASTY 1
    NASTY 1
    305574337_5700514320006620_8585122826180424096_n.jpg 409" powered 9N Ford tractor
    enloe, skooch, juan motime and 14 others like this.
  27. fastcar1953
    fastcar1953
    Still gathering parts for my street brawler truck. So far I have the big block and th400. Blower on its way. Rear wheels and metal for frame. Today I drug home a cab and ***le. 40 Chevy. IMG_20230318_141750.jpg IMG_20230318_141736.jpg
    enloe, chryslerfan55, RMR&C and 11 others like this.
  28. It’s not much but it’s the biggest job I've been able to do since early November. Ran a drill bit through the stud holes to open them up a bit then installed new studs
  29. walter
    walter
    Changed oil in the roadster. Went to the parts store to get a filter and was told the filter wasn't for an engine but was for a hydraulic system. I didn't bother to explain. I just purchased and left the building!
  30. lumpy 63
    lumpy 63
    Glad to see you back in the garage Scotty! Now get on it , you got **** to build!
