Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Greg Rogers
    Greg Rogers
    Your cars don't get along well with rear wheel bearings, huh, Jim?
    chryslerfan55 and squirrel like this.
  2. saltflats
    saltflats
    from Missouri
    Over the weekend it was ride along to the 34/409 Shootout at Tri State Raceway in Earlville IA. Did a little coaching to a couple drivers and got them in the 10 second bracket.
    Today was lift moving day. Relocated 3 lifts to 3 different places.
    20241008_131041.jpg 20241008_134603.jpg 20241008_150039.jpg 20241008_154954.jpg 20241008_163513.jpg
  3. saltflats
    saltflats
    from Missouri
    These are the two cars I was coaching for the weekend.
  4. Anthony, it looks like you used up your luck today!! Good job!
  5. lumpy 63
    lumpy 63
    20241008_172228.jpg A little preliminary t******* on the Tempest floor and the T400 has a place to go. Started measuring up engine mounts also.
  6. choptop40
    choptop40
    5597b6c3-b6f2-4a72-b570-1cbadae015b7.jpg Engine installed in and steering column fitted..Got lucky , everything cleared..Engine / trans / steering/ firewall and now long water pump pulley setup will fit
  7. atch
    atch
    Anthony,
    What Andy said. If you got one of those easi-outs to actually work you're a better man than me.
  8. snoc653
    snoc653
    from Iowa
    Sounds like a very productive weekend. Good work. I can't wait to get the car together and get it down a track. At this point, I'd take 14s though 10s are a very respectable goal. It is always good to see people hitting their goals. If you need more space for those 4 posts, I can make room in the shop. Or I should say, they would make room in my shop allowing me to double park stuff.
  9. atch
    atch
    Last week Sherry and I started east in Clarence for a trip to PA, NY, Canada, MI, etc. Got almost to Ohio when Clarence balked. Fried the coil and cap in the HEI. Rode a rollback to a garage and they fixed it. Or so we thought. Made it less than ten miles when same thing happened. Came home Friday on a rollback. Yeah; seven hours in a rollback. I've been pretty disgusted and haven't even gone to the shop for anything other than to take out the suitcases and cooler.
    I think I'll head out there today and change out the HEI (was never my idea to install that thing in the first place) for an original GM points type distributor. First I'll see if I can source made in the USA points, rotor, and cap.
  10. jwilson645
    jwilson645
    from Alabama
    A few more bits on the 55 GMC.
    Caddy/Olds air cleaner.
    15x6 steel wheels with some mock up tires in 215/70/15 to check fit/look before ordering the wide whites.
  11. vtwhead
    vtwhead
    JW, do you recall what your rims are from as I have to convert my 16s over to 15s nex̌t year.
  12. Found out why we had a rocker arm noise
    piece was laying below it.
  13. jwilson645
    jwilson645
    from Alabama
    They are Wheel Vintiques series 62. They have outside hubcap nubs.
    Wish I had gone with series 12 in a 16" because the stock GMC caps I found after I bought the wheels won't fit and I had to use a 1" spacer to clear the disc brakes I put on frony.
  14. You wouldn't need a cab corner for that beast would you? I have a new one that I've had for 15 years! I'd be happy to give it to somebody, pretty sure it's a left side.
  15. jwilson645
    jwilson645
    from Alabama
    I appreciate the offer but I have both sides already.
  16. squirrel
    Tempest... Hmm.. Meltdown Drags 2017
  17. lumpy 63
    lumpy 63
    20241009_164527.jpg 20241009_164500.jpg Fabbed up engine mount brackets today.
  18. swade41
    swade41
    from Buffalo,NY
    What are the headers from ?
  19. onetrickpony
    onetrickpony
    from Texas
    Shot some paint today. Got some dust and a couple of small runs but nothing that can't be fixed.
  20. swade41
    swade41
    from Buffalo,NY
    I had a friend make up some Champion stickers for me, since the company no longer sells merchandise, and put them on my footstool.
    I took the scoop off the car and had it sandblasted in preparation for a magnesium look powdercoat that never happened, I wanted to do the scoop and aluminum slots but just couldn't find the right color. So years later I re-polished the scoop to use on the footstool and now with the stickers it looks like it did back when it was on the Henry J.
    I also started the bodywork process on the front clip of the 41, something I put off prior so I could just drive it, now it's time because I plan on driving it again next summer after a 5 year hiatus.
  21. ALLDONE
    ALLDONE
    stripping the 50 ocho...putting the new tires and wheels tomorrow....
    IMG_3547[9100].jpg IMG_3548[9101].jpg IMG_3554[9107].jpg IMG_3555[9106].jpg IMG_3556[9105].jpg IMG_3557[9104].jpg IMG_3558[9108].jpg IMG_3566[9110].jpg IMG_3567[9111].jpg IMG_3582[9115].jpg IMG_3583[9114].jpg
  22. deathrowdave
    deathrowdave
    from NKy
    Man I have had good and mostly bad luck using that type of extractor . Good Job my friend
  23. jwilson645
    jwilson645
    from Alabama
    Not sure. That whole set up came out of my friend's dad's 57 chevy truck. I'll see if he knows.
    *edit* He does not know the application but they fit perfectly.
    chryslerfan55 and swade41 like this.
  24. Super clean
    .060 over
    Plans are to reseal, valve stem o rings and lap the valves
  25. This bbc was in the srap bin
    dome pistons but was a 2 bolt with cast crank.
    Never hurts to look.
    Pulled a 69 dated 325/350 hp 396 intake out of the pile once.
  26. IMG_4342.jpeg Smaller convertible top retrim and rebuild stuff.
  27. Greg Rogers
    Greg Rogers
    Sorry to hear of your troubles, Mike. I wanted to meet you at truckstock.
  28. lumpy 63
    lumpy 63
    20241010_202654.jpg What am I working on? Beat and tired after a long day at work.. pouring over a ragged 1962 HRM article about an AFX Tempest. A couple of cold beers and it's time to hit the sack.
  29. chevyfordman
    chevyfordman
    I got to save a rear main cap by installing a helicoil on a 327. Someone used too short a bolt and broke out some of the cap. IMG_2573.jpeg
