Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. lumpy 63
    lumpy 63
    Yeah , it's not like mid 70s nova and Camaro 6 cylinder cars are laying around like they used to be...
  2. The 250 stuff would need modified. The 292 block is a good bit taller.
    But I’ve only seen one PS set up on a gm 6 in the s**** yard in the past 10 years.
    mad mikey and lumpy 63 like this.
  3. Nice and clean, James! I'm still so thankful for your help during my rebuild of the AOD. It's taken me a while to get it installed along with the 351W, but I'm closing in on hooking up stuff, wiring it up over the winter and then a start up, running in and adjusting the transmission this spring. Keep us posted on your run in.
    mad mikey, saltflats and lumpy 63 like this.
  4. Mr48chev
    I put out the word that I was looking for a cab to replace the one on my 48 that just has too many issues to deal with so I can put my truck back together and a local rodder gave me this one. It's real solid but I'll have a number of farm truck dings to deal with and get plenty of dent removal practice. Kind of back to my roots when I first put the 48 together to go to the 73 street rod nationals. cab 3.jpg
    Tim, mad mikey, RMcCulley and 16 others like this.
  5. PS bracket mocked up. Might wait to finish when I get the engine in the truck
  6. saltflats
    saltflats
    from Missouri
    Finally got this one ****oned up short of needing a new pan.
  7. Stock Racer
    Stock Racer
    Still thrashing on the floor of my 62 Biscayne
    Okie Pete, Tim, mad mikey and 12 others like this.
  8. Got it all figured out.
    A couple adel clamps on the fuel line and paint the air cleaner and mounts we built IMG_3787.jpeg
  9. enloe
    enloe
    from east , tn.
    I just finished replacing all my fluorescent lights with 55,000 lumens of LED lights IMG_9819.jpeg
  10. choptop40
    choptop40
    Decided to use original gauge opening and fit the gauges..Now the speedo opening is next.. db7d5e61-4761-4e2b-8037-25ddcf7e2de4.jpg
  11. Paul
    Paul
    Editor
    pulled some parts out of the corners and tried to make a plan.
    this is more of a distraction than actual progress, but maybe one day it'll make some noise.
    neilswheels, Okie Pete, Tim and 18 others like this.
  12. Paul
    Paul
    Editor
    also just sent off the first Hurst style mounts for the '49-'63 Cadillac engines.
    now I've got early Olds, Chrysler hemi and the Cad mounts
    Okie Pete, Tim, mad mikey and 5 others like this.
  13. lumpy 63
    lumpy 63
    20241214_164138.jpg Pontiac is getting closer, I used some aluminum cleaner on the valve covers but I think I need to get some gl*** bead for the sand blaster.
  14. HOTRODPRIMER
    HOTRODPRIMER
    Makes a huge difference doesn't it? HRP
  15. Kosmos55
    Kosmos55
    Rough grille setup. Now the front matches the back. Kinda.
  16. enloe
    enloe
    from east , tn.
    Yes it does. we will probably never drop anything because we can see where it goes:)
    mad mikey and 427 sleeper like this.
  17. swade41
    swade41
    from Buffalo,NY
    I got out the aftermarket cross sills for the 57 p/u to compare to the originals which have a couple pinholes, of course there were only 2 of the 8 metal pads that stop the sills from spreading.
    And of course the new ones are wider than the originals so I couldn't rob those, but I had some 16 guage to make some.
    Tomorrow the bed goes back on for some tire clearance measuring
  18. pila38
    pila38
    Time to build an engine!
    IMG_5543.jpeg IMG_5544.jpeg IMG_5559.jpeg IMG_0024.jpeg IMG_0025.jpeg IMG_0026.jpeg
  19. saltflats
    saltflats
    from Missouri
    Went to town to revisit this project, the plan was to get the rear end mounted back under the car and ran short on 2 bolt's for the upper trailing arms. We had added the 4th upper arm and just didn't cover that base.
  20. patsurf
    patsurf
    do you have smokey looking over your shoulder?-sinister!
  21. saltflats
    saltflats
    from Missouri
    No I was the only one in charge on the gig.
    mad mikey and osage orange like this.
  22. Mitchell Rish
    Mitchell Rish
    from Houston MS
  23. cavman
    cavman
    I've been playing with this for the last year or so.
  24. lumpy 63
    lumpy 63
    20241218_101403.jpg Using my lunch break to work on Pontiac valve covers
  25. seb fontana
    seb fontana
    from ct
    Updating my HF Sand Blaster with a Tacoma kit..
    saltflats, mad mikey and lumpy 63 like this.
  26. chevy57dude
    chevy57dude
    @cavman - love the straight rods on that Hurst!
    mad mikey, 427 sleeper and cavman like this.
  27. saltflats
    saltflats
    from Missouri
  28. lumpy 63
    lumpy 63
    20241218_190006.jpg Exceptionally nice attention to detail with the mid mounts.
  29. cavman
    cavman
    Yup, just an old 65 truck block with 425 Horse internals +.030
    mad mikey, pila38, lumpy 63 and 4 others like this.
  30. saltflats
    saltflats
    from Missouri
    I got the best of a 12.22 in the quarter with a standard bore truck 409 with the 425 HP parts and a Isky cam. The factory rods always had me nerviest. I had turned that engine 7,200 RPMs a few times.
