Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. saltflats
    saltflats
    from Missouri
    I found a new in the box Hobart spool gun for cheap on the market place that is compatible with my Hobart welder.
    Haven't had the chance to try it out yet.
  2. snoc653
    snoc653
    from Iowa
    The college had a new wire welder that would aluminum. I took the opportunity to repair a cracked plate of t6061 with it. One of the aviation techs said it would always be cracked or weak and wouldn’t p***. Aviation grade inspection. I gave him both plates (one for each side of the boat stern) and told him to tell me which plate was repaired and where. He even had their instructor use the testing the do on propellers and the couldn’t find the repair. Part of the key is knowing what you are welding and using the correct wire. Those plates are for my go fast boat.
  3. . My former place of employment is now an aluminum repair facility. TIGs aren’t allowed to be used in new cars due to frying computers.
    All they use are spool guns when welding. (Most is rivet bonding
    When I was there we used a regular mig, no spool. Horrible set up. Plus I don’t think our small machines were powerful enough at the time.
    The test welds these guys do each year are impressive for wire
    This was my test weld today
    didn’t have a stainless brush. Cleaned off with a scuff pad.
    So should improve with proper cleaning. But not bad for doing this the first time with a spool.
  4. gimpyshotrods
    gimpyshotrods
    Vaguely.
    I have two surgeries scheduled for Friday.
    swade41, chevy57dude, Oneball and 4 others like this.
  5. Just watched a couple videos. Learned a lot on how to clean it up. Some is cleaning the part. The other could be the shielding gas. I’m using 100% like I should but that doesn’t mean the gas is being delivered correctly by the spool gun.
    I’ll bring a stainless brush tomorrow and try again.
    Play with gas flow
    Wonder if this cast piece needs pre heated any?
  6. deathrowdave
    deathrowdave
    from NKy
    The stove bolt Chebbies are pretty thin structured for frames . Nothing more than sheet metal framed into a top hat .
  7. deathrowdave
    deathrowdave
    from NKy
    I have a Lincoln 200 amp 100 % duty cycle mig. A buddy gave me a 30amp Milker spool gun . I have lots of hours , maki’s a 24 v spool work on 12 v operating system on a Lincoln machine
  8. -Brent-
    -Brent-
    I ordered this bullseye pick and few days back, it was at the house when I came home so I barely ate dinner and took the box straight into the shop to test it out.
    After 90 mins or so I worked out a bunch of dings and dents at the top of this quarter. I didn't get a good before pic.
    There's a little more fine tuning. I just need some practice before I can do that... hahaha. I'm not "fine tuning capable" just yet.
    In my opinion, this is one of those tools that pays for itself straight away. It made the task much easier.
  9. snoc653
    snoc653
    from Iowa
    My Systimatics MP175 will supposedly mig 3/8 aluminum using 3/64 aluminum wire. I won’t buy the aluminum wire or spool guides for it until I feel I need to weld with it.
    edit. Just saw the stainless wire brush comment. Make sure the brush you use on aluminum has never been used on anything other than aluminum. There will always be residual material left if used on something else and it will mess with the weld.
  10. saltflats
    saltflats
    from Missouri
    I hear that the wire needs to be touching the base to start. Purging the gas flow is always done before a weld that needs it.
  11. Sharpone
    Sharpone
    When you think it’s clean enough clean some more, an excellent instructor told me that. My welds with a spool gun improved a great deal after I started super cleaning. Like @snoc653 says don’t let your new SS brush touch anything else, change to new brush after awhile also.
    Dan
  12. pila38
    pila38
    Waiting on a box of parts, and can’t go much further with anything until it gets here:
    So I dragged the transmission out to start cleaning it up, also need to put a rear seal in it. Not doing anything else to the trans and praying to the car gods it will survive. I bought it off Craigslist years ago, it’s got to be good, right?
  13. 51504bat
    51504bat
    Hang in there. Hopefully you'll be in PT in no time.
  14. mad mikey
    mad mikey
    As I posted before, I am making my bare bones race interior more showy and comfy if you will. Here are a few pictures. The floor is all but done. Roll and pleat marine grade vinyl. Kill Matt was first, then I made templates for the upholstery board, then wrapped. the panels on the floor are all removable for cleaning or whatever. Next up is finish making my seat brackets well, pretty, and fab up new gas pedal linkage, also making some custom padding for the cage that will be red metal flake type vinyl material and thin foam. I even put some nice black insulation, foam on the inside of the fire wall. Not to bad for a dumb *** that has never done upholstery before. More to come.... WIN_20250306_17_10_33_Pro.jpg WIN_20250306_17_09_50_Pro.jpg WIN_20250306_17_09_20_Pro.jpg WIN_20250306_17_08_32_Pro.jpg WIN_20250306_17_10_33_Pro.jpg WIN_20250306_17_09_50_Pro.jpg WIN_20250306_17_09_20_Pro.jpg WIN_20250306_17_08_32_Pro.jpg
  15. chevy57dude
    chevy57dude
  16. Bandit Billy
    Bandit Billy
    @mad mikey , looks nice. nothing wrong with some creature comforts inside. Hell, even a coffin has a nice interior :cool:
    Years ago a local racer with more money than brains, had a wicked 69 Camaro drag car, mostly gl***, weighed nothing. he wanted a full 69 deluxe interior, no seats but rugs, door panels, dash pad, etc. It really did make the car a lot nicer to look at.
    Nice work!
  17. mad mikey
    mad mikey
    Thanks Billy, It is taking longer then I thought, but moving toward the finish line now, just in time for spring.
  18. pila38
    pila38
    Whoooooowheeee! That’s some baller stuff there! Very nice
  19. J. A. Miller
    J. A. Miller
    from Central NY
    A guy tried to sell me a coffin one time, I said that's the last thing I need. :rolleyes::D
  20. gene-koning
    gene-koning
    Looking pretty good. That should reduce the noise level inside of the car a bunch.
    You are a brave man installing a white floor in the hot rod though.
  21. swade41
    swade41
    from Buffalo,NY
    Didn't you feel guilty adding all that weight. Lol
  22. High test 63
    High test 63
    Anthony, are you going to use rochester or Stromberg carbs on that intake?
  23. Rochester
    Got a couple from you
    Debating buying the base kits or modify the factory ones
  24. swade41
    swade41
    from Buffalo,NY
    I still want to know why you can't idle on all 3 carbs ? All my 2x4 combos idle on both carbs and you'd be able to keep fresh fuel in all 3 carbs.
  25. Oneball
    Oneball
    I’m working on banging my head against a wall. Everything I touch this week turns to ****.
    The front bearing in my generator has started squealing so I got it out and apart to replace it and promptly dropped the commutator, ******ing the insulation.
    So I bit the bullet and ordered a refurbed one, which arrived with a damaged terminal so I thought I’d try and fix it and promptly sheared the case bolt. :mad:
    Okie Pete, pila38, 61Cruiser and 7 others like this.
  26. Just needed some motivation to finish up this 283.
    plan to gently fly cut the gasket surface then start cleaning all this up. Polish the valve covers. Possibly the intake
    Plans are to paint the engine red
    Wife says to leave the inside fins in the covers natural. I kinda agree
  27. These are nos cal custom air cleaner tops, breather and oil cap. I’ve got both was wondering which to run. I kinda like the breather better.
    Might find some finned air cleaners. Who knows.
    These cleaned up ok but aren’t perfect. Been in a shelf for 50 years or so.
    I guess the old road draft tube cleared the intake back in the day
    will have to clearance it if I use this but the valve covers have a PCV spot so this will probably get a plug
    the 55/56 distributor clears the intake unlike the later version did.
    I almost hate to open this up :)
    Only spot to hook up the PCV
    too small?
  28. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Took my long time friend and cl***mate from 76 to the Car and Truck Shop. He’s currently post op and can’t drive. He caught me researching. Turns out I found him an original floor shift steering column (65 El Camino) over a ****py Ididit unit. For less money as well! Not a lost trip since all he really went for was weather stripping related stuff. IMG_2994.jpeg IMG_2992.jpeg
  29. snoc653
    snoc653
    from Iowa
    I wish we still had shops like this around here.
