Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The suspension isn’t under full compression so the panhard arm looks like it’s in a bind at the housing. IMG_3943.jpeg
    porkshop, mad mikey and Dick Stevens like this.
  2. mad mikey
    mad mikey
    Sorry to hear Dana, I know you will overcome this set back.
  3. enloe
    enloe
    from east , tn.
    Put the engine and transmission in the Corvette today IMG_0460.jpeg IMG_0461.jpeg IMG_0462.jpeg IMG_0464.jpeg IMG_0463.jpeg
    rod1, guthriesmith, alanp561 and 17 others like this.
  4. Sharpone
    Sharpone
    You’ll get it! If it was easy Monkeys would be building hot rods!
    Dan
  5. chevy57dude
    chevy57dude
    @enloe - looking good! The guys in your one pic made me laugh. This is the time of year when some people wear shorts and some are in winter coats! I'd be in the coat category until it's 60 degrees.
    rod1, porkshop, Tickety Boo and 9 others like this.
  6. @enloe It won’t be long and you will be out racing a 413 or XKE!
  7. enloe
    enloe
    from east , tn.
  8. Some detail upholstery work on the 53
    Sharpone, porkshop, 63Biscuit and 3 others like this.
  9. verno30
    verno30
    Hey guys. Thanks for weighing in. There is a 3/4" heim on both sides of the panhard bar. I did not build the ch***is; someone had started this project prior to me buying it. Still physics are physics.
    Given that, I am not worried, nor do I see a potential for bind in its current layout. There is not much vertical movement of the suspension. Once the body is on and the car is at curb weight, the initial drive will be the tell-all. If I have to build a new panhard bar, so be it. Those are small potatoes.
    The rear wheels are 15x10 Halibrands. The tires are 285/70-15 BFG's
  10. milwscruffy
    milwscruffy
    Helping a buddy take out the 30 year old 402 and replacing it with a fresh 427 on his 29 Dodge. 484947925_10226914207270395_2439567440735823741_n.jpg 485097223_10226914207950412_2255451083509089944_n.jpg
  11. BJR
    BJR
    Why would they put the mount on the rear end housing horizontal instead of vertical. It makes no sense since the rear end moves up and down. It can't help but bind. Bad engineering.
    alanp561 and porkshop like this.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Maybe this will ease your anxiety. Multiply the offset you see here by the length of the track bar. IMG_3944.jpeg
  13. Clydesdale
    Clydesdale
    I always ***umed the movement in a heim joint in that plane was mainly for misalignment not active movement or load.
    Too fine a margin of error to bottoming out and levering the threaded section off the joint for my tastes.
  14. alanp561
    alanp561
    My Newport wiper kit got here yesterday afternoon. With a lot of help from my daughter Alyn, my ever-patient gofer, it's in, wired up and working. Man, those things are quiet.
  15. saltflats
    saltflats
    from Missouri
    Sunday went to a good friends to lend a hand installing the fenders on his MGA and help him celebrate his birthday.
    rod1, guthriesmith, porkshop and 18 others like this.
  16. Stock Racer
    Stock Racer
    Installing urethane body mounts on my 62 Biscayne. Of course two of the eight spun the cage nuts. They were no match for my cut-off wheel, lol.
  17. enloe
    enloe
    from east , tn.
  18. High test 63
    High test 63
    I see you stepped up for the secondary bases Anthony!
    How do the carb bases line up to the intake?
    By the way, your flange welding mods look good!
    porkshop, enloe, 427 sleeper and 3 others like this.
  19. deathrowdave
    deathrowdave
    from NKy
    Only thing that’s not to my liking is the square head pipe plug . Square plugs are for plumbers , hex plugs are for hot rods . Just my 2 cents
    porkshop, enloe, 427 sleeper and 2 others like this.
  20. There’s a reason only 3 bolts are in the bases.
    One hole is just enough off to cause an issue. Probably less than a 32nd
    Thanks. The flange looks ok. Hasn’t had the gasket surface milled yet though.
    It’s getting replaced. I don’t like em either.
    porkshop, enloe, 427 sleeper and 4 others like this.
  21. 51504bat
    51504bat
    porkshop, Sharpone and saltflats like this.
  22. saltflats
    saltflats
    from Missouri
    Visited the 62 Biscayne project again today. Didn't get much done as we seem to find that anything we get started on we don't have all the bets to pull it off. I did get the cam plug in and the pilot bushing replaced.
    This has been my tool of choice for many years.
    rod1, chevy57dude, 61Cruiser and 9 others like this.
  23. I'm just beginning wiring, using a Rebel Wire 9+3. First I've done what I'm sure of what I'm doing. Next comes the things I think I know what I'm doing. After that, I'm wandering into the wilderness and keeping the tech line number at Rebel Wire close by. I've been studying several wiring diagrams in hopes of figuring out the rest of the rat's nest.
    61Cruiser, porkshop, Sharpone and 4 others like this.
  24. swade41
    swade41
    from Buffalo,NY
    I used that kit in my Henry J, compared to Painless the Rebel instructions are lacking, I referenced my Painless instructions to get through it though.
    osage orange, porkshop and Sharpone like this.
  25. swade41
    swade41
    from Buffalo,NY
    I've been working on the backside of the 57 truck fenders, this thing must of lived on a gravel road because it's sure full of dirt.
    I trimmed the double panels and crevices with Eastwood's rust converter then gave it a coat of Por-15 primer, tomorrow it'll get a satin black topcoat.
  26. 51504bat
    51504bat
    I've wired 2 cars using a Rebel 9+3 kit. First time was in my '39/pu with my former boss/mentor (RIP Ron. Really miss you) ***isting and the install was flawless. The second was in my '54 Ranch Wagon that I did myself. Wiring isn't really in my wheel house but I was able to complete the job with only a couple of calls to tech support. I can't say enough good things about Rebel's tech support. YRMV,
  27. dana barlow
    dana barlow
    from Miami Fla.
    Another little update;
    Y-block Ford V8{ all Y-blocks Ford 239,272,292,312 have same set up.}
    Found the gasket,under the timing chain cover to block,were water pump feeds the block on both the right n left, had failed on right side<Ford designed a weep grove around the block water feed from water pump =So was leaking out weep grove,just above fuel pump bose in timing chain cover. I'm guessing do the real bad over heat n movement that made happen! Hope this is the last prob. Plan on driving again,next week.
    Y-Ford front pulley has to come off*,too remove ,clean and replace gaskets n cover.< That was a much bigger job,do to not owning a puller made for Ford Y. I got it off,but it took almost 3 hours. Making my own Y type puller,an addingg to design a few times,before it worked.
    At least when I drained n checked oil=zero water was in oil< I'll replace with new oil anyway n filter { High zink}.
    Time for a nap. 83 yo, go go is thin n short.
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    this better???
    Paul, rod1, mad mikey and 12 others like this.
  29. Adriatic Machine
    Adriatic Machine
    Made some simple standoffs to attach adel clamps to hang the fuel line, as I have done with the brake lines. I took this route because the ch***is was built with randomly convenient 5/16” holes in a few places, so I took advantage of them. I get a lot of satisfaction out of making hardware:)
    Tim, jazz1, das858 and 22 others like this.
