Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. 427 sleeper
    427 sleeper
    That's ridiculous!!! Condiments and beer mixed together... WTF? :eek:
  2. saltflats
    saltflats
    from Missouri
    I know, just not right. Good thing I have the old trusty backup.
  3. atch
    atch
  4. saltflats
    saltflats
    from Missouri
    Thanks Mike, think we are good. My buddy Nathan just up the road has freezer space.
  5. enloe
    enloe
    from east , tn.
    Ethan and I went to help @alanp561 put a transmission in his Ford
  6. alanp561
    alanp561
    Yes, they did and I've not enjoyed myself like that in a long time. It was a real pleasure working with a father and son who enjoy each other's company and also know which way the wrenches turn. They're good people and I thank them for their help.
  7. enloe
    enloe
    from east , tn.
    We had a great time. Ethan said anytime.
    Even though we didn’t understand anything about how to take the transmission out.
    Sharpone, porkshop, saltflats and 6 others like this.
  8. alanp561
    alanp561
    Henry Ford's idea was to drop the rear end and roll it back, and that's what we did on the '48. but pulling the engine and trans together is a heck of a lot simpler. That's what I did on the '46 Merc to get this transmission. I'm just really glad you guys were there with me on the '48.
    Sharpone, porkshop, Zax and 7 others like this.
  9. 5w Jen
    5w Jen
    from Sweden
    Cleaning out the Chrysler 354 for our 33-34 Ford frame project. We'll remove the frost plugs this week. It looks like 6 cylinders are honed to .010, 2 are .020 o_O Hope we can get all eight to .030.
  10. Stock Racer
    Stock Racer
    Painted my firewall so I can set the engine in.
  11. -Brent-
    -Brent-
  12. -Brent-
    -Brent-
    Got tires for the front runners and I had to mount them immediately. Now, back to picking away at the little stuff.
  13. saltflats
    saltflats
    from Missouri
    Made a good start at shaping the frame rail for my g***er project being I have my NSS 62 Chevy Belair back on track.
    Lot more to go on this but progress is progress.
  14. Sandcrab
    Sandcrab
    I narrowed a '32 Chevy dash for the Ruby and had to change the instrument cutouts so I engine turned some stainless with a Cratex abrasive stick and cut for the gages.
  15. I successfully figured out and wired my hazard switch so that it flashes the front turn signals, rear brake lights and cab clearance lights (3) without backfeeding into the headlight circuit, the brake light circuit and the turn signal circuit. Fout diodes coming out of the hazard switch did the trick. One to the left turn indicator, one to the right turn indicator, one to the cab lights and one to the brake lights. You'd think that front turn signals and rear lights would be on the same circuit. It wasn't working out that way so I sent flasher current to the downstream side of the brake light switch. All's good.
    Then there's the bad. Finally concluded that the Datcon tachometer was junk. Bit the bullet, went online and ordered a Autometer in-dash tachometer. All other (5) gauges are Datcon, but the Autometer blends in.
    What's the winter checklist look like?
    Finish the emergency brake 1/4-inch rod and linkage
    Gl***
    Seatbelts
    Roof, felt header, cab marker lights installed and wired
    Bending 18-gauge sheetmetal into an express bed, tailgate
    First opportunity come spring:
    Remove transmission, find and eliminate the leak
    Begin process of ***ling, inspecting, insuring and licensing
    Drive, drive, drive.
  16. Great engine turning. You nailed it!
    porkshop and Sharpone like this.
  17. Sandcrab
    Sandcrab
    Thanks Osage. I spent a couple hours on trial runs trying to cobble together a
    G code program for the CNC mill but just quit and did it manually. Although that was with the help of the DRO on the J head.
  18. rusty_bits
    rusty_bits
    Okie Pete, BigRRR, 5w Jen and 9 others like this.
  19. HOTRODNORSKIE
    HOTRODNORSKIE
    Mounted the heads on the rocket went on to install my Magurk rocker ***embly then this happened wrong angle looks to be a set from a 371 or 394So I gave Tony a call and he sent me a whole lot of goodness now it's full roller. got lucky looks like the push rods will work now to do a final pattern check on the chevy valves 20251108_111906.jpg 20251108_111906.jpg 20251115_134656.jpg 20251115_134528.jpg
  20. Bandit Billy
    Bandit Billy
    They don't get that hot. You are correct, no mar in the ceramic coating. Weird. I chopped up a bunch of extra Ford rods, welded them back up and had them ceramic coated as well. They are the reason I used 1.75" exhaust pipe.
  21. deathrowdave
    deathrowdave
    from NKy
    What am I working on ? Divorce after 23 years
  22. 57 Fargo
    57 Fargo
    Sorry to hear that man, I’ve been through it.
  23. Sharpone
    Sharpone
    Sorry that ****s
    Dan
  24. Bandit Billy
    Bandit Billy
    Metric or Standard? I hear the Metric ones can be rough.
    porkshop and deathrowdave like this.
  25. Dick Stevens
    Dick Stevens
  26. mopacltd
    mopacltd
    Been there. Nothing about it is pretty!
    porkshop, deathrowdave and Sharpone like this.
  27. swade41
    swade41
    from Buffalo,NY
    Good luck, hopefully it's civil, I've been through that a couple times. Well, the second technically wasn't a divorce since we never married (learned from first), just lived together for 15, but life is much better now.
  28. -Brent-
    -Brent-
    I'm polishing a pair of these for chrome prep and realizing I'm not qualified for this job at the same time. Hahaha.
    chevyfordman, rod1, porkshop and 13 others like this.
  29. hang in there Dave, there's life at the other end.
  30. saltflats
    saltflats
    from Missouri
    Been there done that, came out with the cloths on my back. Hang in there.
