Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. LOU WELLS
    LOU WELLS
    from IDAHO
  2. LOU WELLS
    LOU WELLS
    from IDAHO
  3. 57 Fargo
    57 Fargo
  4. Stock Racer
    Stock Racer
    Well... Since my Plymouth is not a tow vehicle and since I'm shooting for period correct from the 60's, I don't look at it as a step back. A step back in time, yes, but that's what I'm after.
    I have never had a car quit on me because of a points style distributor. Electronic/HEI, several times.
  5. I get it...Traditional site, traditional cars/trucks!
    I have nothing against building your car to be period correct & think it is pretty cool to go the extra mile to make them exactly the way they were built back then.
    2 of my 14 (57 T-Bird & 55 Nash Amb Custom Lemans) are currently points cars & will stay that way as they are far from high horsepower cars. Several others came with points but won't be when I am done building them & of course anything I am building for high RPM & most consistent H.P. will definitely get an HEI or MSD 6A just common sense.
    My comment was just teasing Mark a bit for his comment about points being the "best" ignition system which of course it is not, but it is traditional for the site.
    God Bless
    Bill
    https://www.jalopyjournal.com/forum...ar-transport-hauling-open-or-enclosed.614419/
  6. 5w Jen
    5w Jen
    from Sweden
    We set up the Chrysler 392 block with aluminum side plates to get bolt holes vertical for drilling and tapping, see pic. It's set up on a huge flat stone table. Checking the flat milled part with an indicator.
    Hopefully we can borrow the milling machine tuesday evening coming week.
  7. Sharpone
    Sharpone
    I love the precision work you’re doing.
    Dan
  8. mad mikey
    mad mikey
    Will be redoing my trunk area to match the upholstery I did last winter inside the coupe. Have a few other trick up my sleeve for the up coming season as well.;) WIN_20250306_17_09_20_Pro.jpg
  9. Black_Sheep
    Black_Sheep
    After an evening of trial and error I came to the conclusion that my mom’s old Viking sewing machine was not up to the task of doing upholstery. I ordered a real basic Consew straight s***ch, walking foot machine. No regrets, it seems to handle vinyl and 1/2” sew foam with ease. After familiarizing myself with the machine I made a small test piece to see how much length I’ll lose per pleat. The 2” pleats I laid out consistently shrunk to 1 7/8” so I’ll have to take that into consideration when I finally start on my inserts. For now, more practice… IMG_0191.jpeg
  10. Black_Sheep
    Black_Sheep
  11. Dick Stevens
    Dick Stevens
  12. Black_Sheep
    Black_Sheep
    Thanks for the positive reinforcement, this actually was my first time sewing anything with a machine. I've been binge watching YouTube videos to learn some basic techniques, I just need a little more practice before I try to tackle the truck.
  13. Almostdone
    Almostdone
    I like the ‘Hippies use side door’ sign.
    John
  14. Blues4U
    Blues4U
    from So Cal
    Continuing the project of fixing up an old 32 grill shell for my Model A pickup. After finishing up the block sanding I got some color on the shell.
    Here's a base coat I applied first:
    Followed by some metallic blue and topped off with a 2k clear:
    Then after considering my options for the grill insert I decided to paint the vertical bars black, so I first polished up the outer frame and the bezel around the crank hole, then I taped it all off and sprayed it with some flat black.
    Now here's the insert set into the shell, I still need some hardware to secure the insert in place.
    And I have to confess, I screwed up. I ***umed the clear coat, after 24 hours, was hard enough to handle. I wanted the inside of the shell black, not blue, so when you look through the grill, as in that pic above, it's black behind the grill. So I masked everything off and shot the black, but when I pulled the masking off I found that it had marred the clear coat. Arrrrggggg!!!! Damn! Well, if I get lucky it will all sand out when I color sand it, but I will have to allow the hardener in the 2k clear to fully cure, that may take a couple of weeks? You can see the marring in this photo:
  15. Black_Sheep
    Black_Sheep
    More practice pieces, trying inside corners on the speaker box wraps and working on running straight lines. Triangles on top and diamonds on the bottom. There’s some weird puckers and wavy lines but I’m learning from the mistakes…
  16. 5w Jen
    5w Jen
    from Sweden
    Drilled and tapped two holes in the 392 block yesterday evening, see pic. It's a bit slow but we are using 3 tapps, first, middle and finish tap.
  17. Black_Sheep
    Black_Sheep
    Trying tuck and roll…
    Back side
  18. mad mikey
    mad mikey
    I can't really work on anything.:mad: 4 degrees and a major snow storm coming. Damn I hate winter. Takes to long o heat up he shop at these temps.:(
  19. saltflats
    saltflats
    from Missouri
    I'm lucky that my shop is in my ba*****t, so it's nice and warm.
  20. Only a half inch of snow overnight but it's started up again around 10 this morning and it is way too cold to make any headway pulling down the hotrod's transmission in the unheated garage. Feeding the birds and working on another walking stick in MY heated ba*****t.
  21. Black_Sheep
    Black_Sheep
    Today I worked on kick panels. The daytime high was -15 F but it’s a balmy 65 degrees in the shop…
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
  23. Bandit Billy
    Bandit Billy
    What product did you use. Looks very sano.
  24. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Rustoleum 2X Satin Black.
  25. patsurf
    patsurf
    did you thin it extra?
    Bill's Auto Works and porkshop like this.
  26. Johnny Gee
    Johnny Gee
    from Downey, Ca
  27. patsurf
    patsurf
  28. 2deuces64, mad mikey, Blues4U and 3 others like this.
  29. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
  30. guthriesmith
    guthriesmith
    I’m mainly working on my OT pickup right now but need to get back to putting a y-block together for the 56 or spring will show up before I am ready.
