Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. fastcar1953
    fastcar1953
  2. 210superair
    210superair
    from Michigan
    Wellllll.... The damn flathead had carb issues two weeks ago when I started it, idling high. Smelled like gas. I didn't have time so this morning was the first opportunity to get to it. Fiddled with the carb all morning and finally got it right. Car running better than it ever has. Smooth as hell at 500rpm idle. Drive it local a bit, decide it's fixed, drive it an hour to meet my wife and kid at his baseball tournament. Standing in the parking lot having a beer with coach, look down at the car, rear right drag link is laying on the ground.... Damnit. Sheared bolt thru the leaf spring.
    Nothing a rachet strap can't fix! Lol. Strapped it up tight and made it home fine.
    Gotta replace the leaf spring bolt and she'll be fine
    5w Jen, mad mikey, Oneball and 5 others like this.
  3. patsurf
    patsurf
    the coach shouldn't drink on duty!
  4. kls50
    kls50
    Finally got the steering box out. It's toast. I have two other boxes I bought about 5 years ago and one is in great shape. Adjusted the sector screw and checked the pull with a spring scale and is smooth and has zero play in the wheel. Then I measured the shaft. Too long so I guess it is out of a 1951 Ford car and won't work. I think the 1951 Ford shaft is longer to accommodate for the built-in turn signal switch. Let me know if I wrong. Anyway, here's some pics of my mess. Sorry for the pics quality.
    saltflats, 5w Jen, mad mikey and 4 others like this.
  5. 210superair
    210superair
    from Michigan
    Got lucky. Bolt wasn't sheared, just lost the nut. Managed to finagle it back in and had nuts and washers laying around that worked perfectly. In hindsight that nut has probably been gone a while and I just didn't notice, and the bolt finally wiggled loose enough to drop the bar. Eh well. Car is driving awesome now and got the carb right finally. Cruises like a dream....
    saltflats, 5w Jen, mad mikey and 7 others like this.
  6. kls50
    kls50
    Today I cleaned a spot off of my work bench to work on my 1950 Ford car steering box. I found the other box I bought 5 years ago and compared the gears/parts from it to my other box I pulled last week. I can actually see the wear on the gears compared to the other the one. The shaft is the same length I need! I took this box apart 3 years ago to (check it out). I should have left it alone. Anyway, I am in the process of cleaning the parts and then re***embly and check. I might get lucky! DSC01352.JPG
    saltflats, 5w Jen, alanp561 and 7 others like this.
  7. hrm2k
    hrm2k
    I opened 2 boxes today that I have been waiting to open. You’ve seen the new gears, wheel and tires, roll cage, and intercooler. My face hurts from smiling. 66mm Garrett turbos.
  8. Paul
    Paul
    Editor
    took the badges and the Endurashine off a pair of Edelbrocks
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    saltflats, SS327, Sharpone and 4 others like this.
  10. Paul
    Paul
    Editor
    first I tried aluminum wheel cleaner, the etching kind. it did ok but not great. very splotchy.
    then I tried soda blasting but all I have is a gun with soda reservoir that did good for about two square inches before needing to be refilled.
    skipped the oven cleaner and went straight to the big gun.
    muriatic acid.
    painted the exterior with a small brush, let it cook for about five minutes then gave it a bath in a baking soda and water solution.
    then back in the ultrasonic cleaner with hot water and dish soap followed by a clean hot water rinse and blow dry with compressed air. and finally gave it all a light coat of WD40.
    all this dis***embled of course.
    probably would have bead blasted it but my cabinet is full of pretty aggressive aluminum oxide and I wanted it smooth.
    I'm sure there are more effective and easier ways and if I ever do it again I may try one.
    but I got the finish I was after, a relatively consistent dull medium dark grey not unlike zink.
  11. hrm2k
    hrm2k
    @Paul , those carbs look great. Sort of the same sheen as new Stromberg Carbs. A lot of work to get that look.
    Today, we bolted the intercooler to the mounts we had made . Monday we cut the headers and mount some turbos. Until then, enjoy this birds eye view
  12. 67drake
    67drake
    from Muscoda WI
    Is mounting new hubcaps technically “working on” something? Regardless, I bought these ‘56 Olds caps off of member Shamus, to replace the original’55 Pontiac caps, IMG_0149.jpeg IMG_0148.jpeg and finally got to take the car out of the shop today. Going to take it and actually do deliveries in it today for our pizza restaurant.
  13. kls50
    kls50
    That counts in my book!
  14. Okie Pete
    Okie Pete
    IMG_0216.jpeg IMG_0222.jpeg Saw this article in a magazine so I started making one for the shop .
  15. Sharpone
    Sharpone
    That car is beautiful
    Dan
  16. 67drake
    67drake
    from Muscoda WI
    Thanks!
    Coolest pizza IMG_0156.jpeg IMG_0155.jpeg delivery vehicle around IMO!
    61Cruiser, alanp561, swade41 and 16 others like this.
  17. Congratulations, you won Round 1. Now only 15 more to go!
    porkshop, Okie Pete and Sharpone like this.
  18. patsurf
    patsurf
    well,would be 11 in this case-but one is all that's needed!
  19. Your odds are improving!
    Bandit Billy, porkshop and Sharpone like this.
  20. Sharpone
    Sharpone
    IMG_4260.jpeg IMG_4261.jpeg Repurposing a cart again I bought at an auction for a $1. Last purpose was a down and dirty engine test stand.
    Now I’ll make a welding cart for MiG, stick and oxy/acetylene maybe put some hangers on for grinders and what not.
    Dan
    67drake, GuyW, Bandit Billy and 5 others like this.
  21. Sharpone
    Sharpone
    Oh I scavenged the tubing from a give away exercise machine. I used a bunch of the 2” tubing on the Dart exhaust.
    Dan
  22. :). It’s a 6
    But gonna use another head
  23. hrm2k
    hrm2k
    **** is getting real. The headers that came with the turbo kit had 2 3/4 V band connection. It needed to be 3 inches, and we are ****ing hot rodders so we are changing the output to 3 inches . it sure makes the area look different
  24. Bandit Billy
    Bandit Billy
    Is there a target or projected HP on this project? Inquiring minds really want to know.
    saltflats, porkshop and Sharpone like this.
  25. rob-redm
    rob-redm
    just a lot of small things on the 51 Chevy 2dr Styleline Deluxe I bought... removed the pinstripes . removed some silly
    stickers off the gl*** and on the third member.. waiting for the correct out side mirrors... so I can take 69 camaro ones off... knocking the "older " guy stuff of it as I go.. lol
    saltflats, enloe and porkshop like this.
  26. rusty_bits
    rusty_bits
    Maxwest_Astro_8R_05262026_083845.jpg Maxwest_Astro_8R_06272026_124113.jpg An office/coffee/beer room, in the corner of the shop. Maxwest_Astro_8R_05262026_083845.jpg Maxwest_Astro_8R_05262026_083845.jpg
  27. Sharpone
    Sharpone
    A big gl*** of ice water
    It’s 90 - 80 in the garage
    That’s 90 degrees and 80% humidity.
    Doesn’t help that I’m welding and not Cali style with flip flops and shorts I have my FR gear on.
    Oh and when chipping slag keep your mouth shut:eek:
    Dan
  28. Robdski
    Robdski
    My attempt at a firewall.
    Pay no attention to the flow checks, I came up with Lacquer and Enamel. I have a lot to learn using this new fangled material.
    I was going for the “clueless, backyard builder” look. I’m pretty sure I nailed it.
  29. saltflats
    saltflats
    from Missouri
    I would say your attempt came out really nice.
    enloe, 427 sleeper, Robdski and 2 others like this.
