Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. lo c dan
    lo c dan
    To be used, I think they'll do
  2. Sharpone
    Sharpone
    You need a build thread for this thang!!
    Dan
    Okie Pete, porkshop and lo c dan like this.
  3. hrm2k
    hrm2k
    Nice !!!!!
    Sharpone and lo c dan like this.
  4. deathrowdave
    deathrowdave
    from NKy
    Okie Pete and Sharpone like this.
  5. Rusty Heaps
    Rusty Heaps
    IMG_3990.jpeg Hoping this engine I dragged home is a good one for a heart transplant for the ‘52 Buick Special Riviera. I’ll dig into it when time allows. Also doing a complete brake system replacement. I had a donor car for the engine and transmission but it became the one I posted in the custom Buick thread. This project has been on mothballs way too long.
  6. D-Russ
    D-Russ
  7. squirrel
    went to the grocery store in the Edsel, didn't get too far. There's something wrong with the fuel system, I haven't figured it out yet. But since my wife watches so many shows about driving old cars, she suggested I fix it this way to get home, and of course it worked.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
  9. 67drake
    67drake
    from Muscoda WI
    She’s a keeper!
    ffr1222k, porkshop, Sharpone and 6 others like this.
  10. impala4speed
    impala4speed
    I've used that method a time or two myself. :cool:
    porkshop, Sharpone, Okie Pete and 3 others like this.
  11. deathrowdave
    deathrowdave
    from NKy
    I had a Bud ,drove his A sedan for years on 2 5 gallon plastic gas cans sitting in rear seat area . Safety first is the only way !
  12. Greg Rogers
    Greg Rogers
    I drove my 56 with a gas tank on the p***enger floor all the way from Hersey PA to Michigan- made it- no smoking....
  13. HOTRODNORSKIE
    HOTRODNORSKIE
    Got the Hurst finally working on the M21 turned out that the 69 and later the 3,4 arm faces in not out everything works like it should. Measured the hydraulic though out bearing won't need to shim. 20260725_142941.jpg
  14. Okie Pete, Sharpone and lo c dan like this.
  15. Bandit Billy
    Bandit Billy
    I promised my SIL I would fix her car this summer…so I made good. Hood was peeling after a rock chip. I stripped the hood with a razor blade and heat gun. DA’d the primer off. Epoxy primer, then base (white), Pearl and clear coat. Did the front bumper while I was at it as it was rock chipped and parking lot damaged.
    My first Pearl. You never forget your first time.
  16. Sharpone
    Sharpone
    Turned out nice!
    Dan
  17. Bandit Billy
    Bandit Billy
    I was at a cruise-in the other day and a nice young Flathead owner noticed my oil breather cap was nearly off…again! He said he has the same one (OTB Gear) and he made a spring to go over top to secure it. I had some time on my hands today while waiting for some o-rings to fix my pressure washer so I can clean my shop after a recent paint job, so I came up with a fix for that breather cap.
    I had some chrome bales from a GM master cylinder lying around and a piece of copper s**** from a house project so I got creative.
    The ribs in the cap made a perfect place for the bale to ride. The copper plate is cut to mimic the breather but with two tabs that I carefully designed do the cap would not sit cattywampus on my Flathead. Had to knock out a gasket as the old one didn’t come off in one piece.
    shouldn’t come off now. Fun little project. To R&R the cap you just have to rotate the cap slightly and walk the bale on and off.
    Now, back to garage cleaning.
  18. hrm2k
    hrm2k
    Of course it is a stock Corvair !!!!!
    Didn't they all have intercoolers and big tires ? :rolleyes:
  19. 67drake
    67drake
    from Muscoda WI
    IMG_0568.jpeg IMG_0566.jpeg Blazing hot here in Wisconsin yesterday, by Wisconsin standards anyway. Figured I’d work in the cool shop.
    Getting rattles and clunks from the back of the ‘55 Catalina occasionally, as well as the drivers side sitting lower than the p***enger by a little over 1/2”, I crawled under to look it over.
    Looks like all the spring eye bushings and shackle to frame are shot. Now a rear suspension tear down planned for the offseason. Looks like parts are still available- bonus.
  20. saltflats
    saltflats
    from Missouri
    Today was the last load out of Rodney's shop in Springfield.
    Rodney was killed in an accident and had several people's projects going at his shop. I feel for the people with these cars in different stages of rebuild. This could be a opportunity for someone to get into rebuilding these old X frame cars. Rodney had a lot of purpose built fixtures to do these cars.
    This is something I could do but am finally enjoying retirement and now only working on my cars with an occasional helping of friends.
    osage orange, porkshop, rod1 and 8 others like this.
  21. Sharpone
    Sharpone
    Replacing all the tie rod end, ball joint etc boots, also installing poly bushings. I did find a bad pitman arm, lower ball joint drivers side, upper ball joint p*** side. Pretty much ruined the pitman arm puller, it spread and the threads are getting bad. Made a cut in line with the splines - nothing made a cut about 90* from first cut nothing. Pounded wedges in the cuts and the pie shaped piece popped still wouldn’t budge. Really hard to get to but I made another slice about 180 from the first one finally it came about 1/2 way off it broke in two. Oh I installed the puller last night torqued up and sprayed with kroil, usually works NOT this time. Got the drivers side stuff painted waiting on ball joints and will install bushings and boots tomorrow and paint p*** side stuff.
    Dan
    GuyW, osage orange, porkshop and 5 others like this.
  22. saltflats
    saltflats
    from Missouri
    I had a steering box that wouldn't give up the pitman arm one time. It was a fail had to get another to move on.
    osage orange, porkshop, enloe and 2 others like this.
  23. Sharpone
    Sharpone
    Yeh they can be a bear, this is worst I’ve ever had.
    Dan
  24. gimpyshotrods
    gimpyshotrods
    Of all things, I am working on a Mercedes Roadster.
    I gotta eat.
    osage orange, porkshop, rod1 and 4 others like this.
  25. patsurf
    patsurf
    what year ?
    Sharpone and porkshop like this.
  26. rusty1
    rusty1
    should be workin on this, but have a friend interested in buying it, we'll see what happens,...32 DeSoto 3 window .. edit: now for sale in cl***ifieds
  27. choptop4
    choptop4
    20260728_095417.jpg 20260728_094630.jpg been in the rafters for 40 years. We have a grandson now. So he will have the coolest ride on the block ! Me with my wheels. 20260409_163952.jpg
  28. 51504bat
    51504bat
    Glad to hear you're able to be out and about so to speak after your accident.
  29. LOU WELLS
    LOU WELLS
    from IDAHO
    DSCN1968.JPG Gathering Memorabilia In The Shop Corner...
