Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. enloe
    enloe
    from east , tn.
  2. rob-redm
    rob-redm
    ARM 1.jpg since my 51 Chevy.. was missing the covers for the bottom of the armrest .. I found this pair of covers on E**y.. cleaned up the chrome pulls for the ashtrays... sand the covers, and the ashtrays the other night... Just need to paint them now .. and them back in the car.... found a replacement horn ring for the car since the top of mine was broken off
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
  4. 6 inch rear drop springs are on the way
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Taped it up with full sun light upon it. Now I gotta wait for surface temp to come down a bit so I can paint it. IMG_6251.jpeg
  6. Thought that was a festavus tree
  7. Zax
    Zax
    Looks good Alan. Personally I have never bothered with adding insulation to the kick panel area in any of my cars. That area just doesn't seem to get very hot.
  8. Bandit Billy
    Bandit Billy
    That would require a feat of strength.
  9. Sharpone
    Sharpone
    Man haven’t seen that show in a while
    Dan
  10. patsurf
    patsurf
    all cars run on used parts--junk yard quote
  11. choptop40
    choptop40
    Just got a Husky compressor..body work starts again soon after 3 years , sandblast trunklid , get ready for paint in September ... Screenshot 2026-08-07 9.44.06 PM.png 49 dodge getting primed.png
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
  13. deathrowdave
    deathrowdave
    from NKy
    Im trying to determine how to measure and bend a simple roll bar behind the seats of the Tiger . Sounds simple , but I will bet I will destroy 3 lengths of tubing before I call it good to go
  14. patsurf
    patsurf
    start w/emt!
  15. saltflats
    saltflats
    from Missouri
    That stuff is a black art. Start with a center line then adjust the second bend.
  16. theHIGHLANDER
    theHIGHLANDER
    Small tubing is your friend. So is aluminum tig wire, the bigger stuff. Take a 1/4 or 5/16 fuel/brake line and bend it on the bender you'll use for the roll bar. That's your inner radius you can use to mark the tube at the shoe of the bender. Big aluminum tig wire is nice because it'd be easy to re-use for the next bend. Try to see the promised land in straight lines 1st, deduct for the radii, start bending. Best I got for now, if I can help or coach in any way don't hesitate. We'll speak of notches as well. A straight cut and quick touch up with a grinder makes a perfect notch. Tube is already round.
  17. squirrel
    The first one I did...I made a full size pattern from some old thin wood panel, and held it on the bender to see where everything would end up. Mark where the tube is on the bender for the first bend, so you can see where the bend ends up being.
  18. DDDenny
    Masonite (1/4") works great for patterns!
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Still need that first bent to pull a pattern and reference point.
  20. saltflats
    saltflats
    from Missouri
    That is the way I learned. Put a center mark on the tube measure over to start your first bend. Then now you have a reference point to know how much you gain from the bend. I do all the measuring from the center of the tube.
    Okie Pete, porkshop, Sharpone and 3 others like this.
  21. DDDenny
    I had Art Morrison bend some custom 2x3 rails for the "back half" I built for my Nova.
    I made a Masonite pattern that I painstakingly fit to the contours of the rear floorpan, it turned out perfect but as a friend that is a car builder says "looks easy"!
    Good outcomes require good attention to detail.
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Not roll cage scale but same concept. Don’t have solid wire pattern pic but this is the one try result. You can see reference markings. IMG_6229.jpeg
    Okie Pete, porkshop, Sharpone and 5 others like this.
  23. saltflats
    saltflats
    from Missouri
    I have lots count of how many times I made the bend on the wrong side of the mark.
  24. theHIGHLANDER
    theHIGHLANDER
    That sux du'nit? I always like the challenge of custom bars. A bracket racer 8pt is cake. Custom F/C cage in moly from scratch in a door car, those were fun. Built abuse cages for the OEMs to test product. Just because, we painted em in the interior colors as we went. Gray, tan, little **** like that is fun too.
  25. HOTRODNORSKIE
    HOTRODNORSKIE
    Had a m***ive brain fart on the 303 McLeod hydraulic bearing way to much air gap so out came the muncie and ordered a 2.225 piston installed that with one shim and reinstalled the transmission air gap at .110 with in specs. 20260809_160334.jpg
  26. Sharpone
    Sharpone
    I tell what really ****s is when you’ve made 2 or 3 bends on a piece perfectly then the final bend is 180* out :eek:
    Dan
  27. Sharpone
    Sharpone
    Get one of these
    https://duckduckgo.com/y.js?ad_domain=amazon.com&ad_provider=bing&ad_type=prad&click_metadata=BTcE5sqSciEy38T4nu8BKPqNob2jd9fgdfyOG3A%2DcoWSxrLODEAN1Vs1hw%2DwrdoV7uOtMMuF2ZEh3kv11Jj3ynmbARORLbPbQ5TXjfR_0f0q0D_Mu8CO%2D2%2Dpwv4xK8MIdTJbNEic8NQafH_jHA%2Dp10sURP2FWfyaacofAxeMuY0.9f8aKjItO6TudYpxmR**xA&eddgt=O%2DvQ78f_TyMNkyvxonyofQ%3D%3D&rut=9cd0a84837dd0bf5b98b244489b20b5831f8216e6eeb2734170fd5faed06c7a6&u3=https%3A%2F%2Fwww.bing.com%2Faclick%3Fld%3De8GSHL6Zxhzjm**ySNif4DCDVUCUxT842tdozsrCLPH2WSR2kzV7r4DYF8tP_g1zhJCvUEWAQ_f9YA62InZDPneXOk9ATZ8eRvdgLtFPCBMgarw5v2wgXkFLr7iyTZzLojdBkKFc0sFERPSYli7WLxR__xanAtGxw7dgLZtkaItHlvZgtU6NgdNTaKeco2kS9r1leEGBOvs4jQirPrE_IDkVWHO0anCVosz_KJvFfUqCipOCXur_AaUyYZjYVk9lrbF2iMWD7iAkBec5uUsvSo6Huxvc12eUbtoNmq4dhFfB3a0HNrenblP2GU0lo7Vea1cuxsGS7s5EksY6ueRl9rToS7G0T8H7Jm9mjdTdYyCsM9Pp%2DcMjEjCWq4YWb5rr84BGz2b_UthAyimt30uvrhPsHyvqchGaBycADwO1uQQ2aZSjxbqRETFAMS_oGS6s1OJlmuUWAOEoMinNTOw9sijchhFqFSILM4lklZzTx_YoSf9QH2ydwx6KXBYmW%2DBbqTebU6Z0A4%2DSdb2I2qQl6cluOO6lEJOGd39MRium2Ff8Fn%2Dtic5xyH9mWJNQgERSOgKAFkv6kHL%2DZ4NfLqQdccdb3p5HysmrauiXNA2NcsTy8LaLdQVwwFHqiUyey2lAXh0y7IP5PBS%2DQ9Cr5aWXfyvlWzVoNm8uXsUUEESTo3MRpy0geTz48jhnEZwmXMv5wcwuyas0MEFkL0hHPNEGuOveY9iRiqDYt5GQTQcGJ3BVd0oFSks4385Ak2pwQLZVg4MwdoNJ84_DxFBQ1Cph61jKAOad8%26u%3DaHR0cHMlM2ElMmYlMmZ3d3cuYW1hem9uLmNvbSUyZlVnbHlzLUVsZWN0cmljYWwtUmVmZXJlbmNlcy1DaGFybGVzLU1pbGxlciUyZmRwJTJmMTI4NDI3NTkxNCUyZnJlZiUzZGFzY19kZl8xMjg0Mjc1OTE0JTNmdGFnJTNkYmluZ3Nob3BwaW5nYS0yMCUyNmxpbmtDb2RlJTNkZGYwJTI2aHZhZGlkJTNkODA1Mzk0MzY1OTUzNzglMjZodm5ldHclM2RvJTI2aHZxbXQlM2RlJTI2aHZibXQlM2RiZSUyNmh2ZGV2JTNkYyUyNmh2bG9jaW50JTNkJTI2aHZsb2NwaHklM2Q5MTczMyUyNmh2dGFyZ2lkJTNkcGxhLTQ1ODQxMzg5MTk4NjUzMTUlMjZwc2MlM2QxJTI2aHZvY2lqaWQlM2Q1NjM3NTA5Mzk5NjU1MDI2NDYxLTEyODQyNzU5MTQtJTI2aHZleHBsbiUzZDA%26rlid%3D9999ac293f651c9b1b68c651cc681b25&vqd=4-101181888500645698740853402813667217934&iurl=%7B1%7DIG%3D32DEEEC088594A4DBB9D54320B47BF4E%26CID%3D05C55BDCEC3566561FD34C6CED6A6760%26ID%3DDevEx%2C5050.1 IMG_4364.jpeg
    Okie Pete, 67drake, hrm2k and 3 others like this.
  28. hrm2k
    hrm2k
    Finished up the TIG welding on the headers and downpipes. I hit it with some polishing compound since everything is stainless steel. Also hit the hot pipe / exhaust on the p***enger side. IMG_7197.jpeg
  29. 6 inch springs in the rear
    hope it settles down a good bit.
