Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. s55mercury66
    s55mercury66
    from SW Wyoming
    I have so many distractions going on at home I've decided to mark everything that HAS been torqued with a paint pen. Having a fan clutch/water pump pulley come loose has been the worst so far, so I'll count myself fortunate. Now to come up with a B.S. tale about factory paint markings.....
  2. bchctybob, alanp561, lumpy 63 and 8 others like this.
  3. 57 Fargo
    57 Fargo
    Just adding some pictures of my stupidity, the rod nuts were laying in the pan, I definitely forgot to torque them. Out comes the motor to either put a crank in it or swap engines.
  4. Dave Mc
    Dave Mc
    57 Fargo>Just adding some pictures of my stupidity, the rod nuts were laying in the pan, I definitely forgot to torque them. Out comes the motor to either put a crank in it or swap engines.
    Don't be too hard on yourself, you are not alone in the Mistake Department. Just have to correct it. and smile about it after.
    das858, lumpy 63, 427 sleeper and 2 others like this.
  5. Kinda hard to hit the like ****on brother, almost seems like an insult! I feel your pain :rolleyes:
  6. I'm temporarily broke for a few more months so I've been doing those little things that don't cost anything and measuring stuff that just leads to uncertainty and doubt. Case in point: I rebuilt the AOD this spring and installed it in the 29AA frame to check fitment. while it was in, with torque converter, I laid the flexplate up against it to ensure the old FMX flex plate (164-tooth) will couple the 351W to the AOD. Seemed to fit like a glove . . . if you are using OJ's glove as a point of reference. Seems that there is about an .063 inch gap between the sideways torque converter studs, or the flexplate is warped that much. Now I could probably shim with .031 washers behind the two studs. Or perhaps tightening the flexplate to the crankshaft might pull it flat. Or maybe the term "flexplate" is appropriate reference, acknowledging that there is a certain amount of flex built into the thing to accommodate slight differences in flatness. I dunno. I'll probably commandeer the kitchen countertop and measure the flexplate differences at each torque converter hole to see if it is the flexplate or the coverter that is off. Meanwhile, what else should I consider, or am I worrying about nothing?
  7. 427 sleeper
    427 sleeper
    Dude... lay off of yourself. You're not the first one here to do it, and damn sure won't be the last. Fact is, most of us have ****ed Up worse, and will be Damned if we admit it. UNLESS we get a good laugh out of it!!! LMAO!!! Just embrace it and tell a good Friggin' story! :D:rolleyes::oops::cool:;):confused:
  8. 57 Fargo
    57 Fargo
    Oh hell that’s just my stupid humor. I’m good, motors out and that piston is out, didn’t hurt the block so another piston and rod and crank and back together it goes.
  9. 65pacecar
    65pacecar
    from KY, AZ
    Restoring a Huntington Beach, California Chysler Plymouth Chrome License plate bracket.
    Bill's Auto Works likes this.
  10. choptop4
    choptop4
    Working on a yard sale.
  11. 427 sleeper
    427 sleeper
    Don't sell your yard, Man! You'll NEVER get your money back!!! LOL!!! :p
    Wanderlust likes this.
  12. alanp561
    alanp561
    It's obvious that I missed something somewhere. @nobby , what is that beautiful cammer engine?
    lothiandon1940 likes this.
  13. nobby
    nobby
    its a quad cam flathead
    with a nv4500 truck transmission
  14. Greg Rogers
    Greg Rogers
    I never see yard sales like that around here!
  15. lumpy 63
    lumpy 63
    20231003_150144.jpg 20231003_152346.jpg 20231003_152623.jpg It was a big day on the Falcon project:D
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
  17. lumpy 63
    lumpy 63
    Still need to put a small flare on it so trim will probably have to go...
    Truckdoctor Andy and chevy57dude like this.
  18. 1pickup
    1pickup
    Like an idiot, I took on a rust repair job on a '59 Ford. LR 1/4 is the worst of it. He wants to leave the patina on the upper half, so just doing the bottom. As I was walking to the house & turned around, I liked what I saw, so took this pic. Feels good to spend my time doing this, and not working for "the man" anymore. But, I should be working on MY junk.
  19. atch
    atch
  20. lumpy 63
    lumpy 63
    I just marked it , the boy cut it out. I'm much older and uglier:eek:
  21. lumpy 63
    lumpy 63
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
  23. oj
    oj
    This one showed up today for some work
  24. nobby
    nobby
  25. swade41
    swade41
    from Buffalo,NY
    I spent way to many hrs cleaning that left over black crinkle paint out of the fins and letters on these valve covers I'm putting together for the blower motor.
    What a pain in the ****, but now they're ready to start the polishing process whenever I get to it.
    20230511_095146.jpg Screenshot_20231009_185058_Gallery.jpg 20231009_172121.jpg
    I bought this ***ortment of br*** brushes for the Dremil tool
    The top ones fit in-between the fins great but they come apart fast and stick all into your clothes and skin, I had like a thousand of those little needles stuck in me, damn porcupine.
    The middle one worked the best since the longer it was used the smaller it twisted together and you could really get into the tight spaces.
    I also cut some 80 grit paper into a 2 inch square and put that onto the cutoff wheel attachment, trying anything and everything.
    I really thought the new blast cabinet would've stripped it right of but that was some tough stuff.
  26. atch
    atch
    One of the smartest things I've ever done in/for my shop was to buy a leather apron. iirc it came from Amazon and was around $30. No more wires stuck in me or my clothes.
  27. swade41
    swade41
    from Buffalo,NY
    I was thinking about one of these !
    enloe, bchctybob, scotty t and 9 others like this.
  28. swade41
    swade41
    from Buffalo,NY
    Today I blasted the tank bracket in preparation to clear it, but ..... I did not like the flat gray look it left and wasn't about to clear over that.
    So I started the process of sanding it to see how it shines up, not sure of the direction I'm going yet, might end up with paint on it.
  29. mohr hp
    mohr hp
    from Georgia
    He did well. I've spent way too much time cutting stuff with a Zizz wheel, and personally, the 90 degree angle die grinders are a whole lot easier to control. So much so that I gave my straight grinder away.
