Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. chevy57dude
    chevy57dude
    Looking at the quarter window angle, it's a '68 or _69
  2. 1pickup
    1pickup
    Pretty sure it's '63 Rambler American, but I'm no expert.
  3. alanp561
    alanp561
    Look, there's your missing 10 mm socket!!
  4. 1pickup
    1pickup
    No 10mm sockets were harmed during this project, because there is none used! And, that's where I seem to keep my tools lately - on the floor. Was tearing a Nailhead down, right next to this, and that's why the torch - removing broken bolts, and the tools laying around.
    alanp561 and guthriesmith like this.
  5. 67drake
    67drake
    from Muscoda WI
    Well, I think I posted Thursday I was going to “throw this together”. Well, it took 2 nights of my spare time, and this AM. Now to run out and buy some media to use in it. IMG_0159.jpeg
  6. blue 49
    blue 49
    from Iowa
    A dollop of it on the underside of the tool your co-worker is about to grab was always a hoot.
    Gary
    26 T Ford RPU likes this.
  7. lumpy 63
    lumpy 63
    Jeez , not like you haven't had anything to do lately:p
  8. Voh
    Voh
    1947 Ford Panel kingpins. Anticipated them to be tough, but not this bad, being they were so sloppy.
    Also looks like I need to work on cleaning stuff up in the shop.
  9. 51504bat
    51504bat
    67drake likes this.
  10. saltflats
    saltflats
    from Missouri
    I have been getting ready for old age and have been converting are pantry into a laundry closet so we won't have to use the stairs to do laundry, and it opens up a wall in my ba*****t so now I can relocate my tool box in a more out of the way place. :)
    Guess I need to put on my plumbers hat now.
  11. My room is reserved for 2024 :D:cool: it would be a good time to get a ton of guys from here to show up in Bowling Green!!!! Pregame for Lloydfest 24 :cool:
  12. Moving heavy *** toolboxes into the new shop lol, had to get guys from the firehouse to come lift!!! Man, I used to be stronger :rolleyes: 20231218_114716.jpg
  13. 67drake
    67drake
    from Muscoda WI
  14. squirrel
    Checking the truck for cooling system integrity. To see if there was some reason other than neglect for the black coolant. No yellow, no bubbles, so I guess it's ok.
    I got the brakes working, and the fuel system working, it has a new plate and insurance, so time for a longer test drive...all the way to Bisbee. With some flushing stuff in the cooling system.
  15. Bandit Billy
    Bandit Billy
    I'm working on growing some new skin on my digits after sanding this cheese grater.
  16. Mike VV
    Mike VV
    from SoCal
    Working on a 1959 Vauxhall, Victor.
    Been turned into a street legal drag racer by the previous owner, many years ago.
    Currently going through some necessary upkeep changes/fixes and some "performance" upgrades.
    Looking to make it into a 9 second street car !?
    Sorry, can't post any photos yet, per the HAMB rules makers. That's one of my...changes, a different (more HAMB friendly) set of wheels.
    Mike
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    The odometer on the 56 had stopped working, I removed the speedometer and removed the bezel so I could take it apart, there was some misalignment in the odometer so I carefully adjusted one of its supports and it is working again, just have to put it back in the car
    D2EA1B54-4318-4DE9-8CC8-71D5DAE6B5A7.jpeg E7D7427C-E3E2-4316-B367-7B98814CC803.jpeg 4527A858-9F60-4C5B-8716-BA27E90BA261.jpeg DA4BB930-2800-49F0-886A-190E7D8AC1F3.jpeg C3A9D2FE-B4E6-4C3C-8B87-2C8AC4EFFFF8.jpeg 0C7B50B9-E263-438A-8AA3-9054A2FD6ECC.jpeg
  18. mgtstumpy
    mgtstumpy
    I parked the 35 Chevy and 46 Olds up as I'm off travelling again through the USA for a few months in early 2024. I crammed in quite a few small but time consuming things in before I pulled the covers over both cars.
    Finally fitted all new side gl*** into Olds with new window run channels, 1/4 gl*** seals, verticals, window fuzzies etc. Accidentally broke a 1/4 gl*** in the process and was fortunate to have a replacement cut locally within days. I had to replace all the side window sash channels as they were rusted. I then ran out of semi-tubular rivets for 1/4 gl*** pivot installation and had to wait a few days but eventually managed to track them down. These are hollow and are peened over to clear setting rubber allowing gl*** to slide into vent frame without interference. I'll use these to also hold the OEM garnish mold clips to window run channels.
    Fitting the rear roll up windows was a PITA, each taking 3hrs to install! Workshop manual indicates it's a quick job, Wrong! No shortcuts here as new window roller bushings I had fabricated need to precisely fit into frame mechanism, no adjustment whatsoever! Nothing else GM or other was even close however the lift springs are identical to 46 Chevy so I replaced them as well as the lock springs as well. 338425060_1273749779897949_6670670015948690767_n.jpg
    Also replaced fuzzies on all side garnish molds. Hopefully I won't have any noise from rattling gl*** or wind with all new seals etc.
    Also installed my NOS S/S vent shades as well and fitted all the side window stainless. Doors still require adjustment. I'll do this and install door locks etc. NOS S/S fender gravel shields are next to be installed,
    I kept all the old window run channels, fuzzies etc as templates when cutting, bending new channels.
    I had some powder coated steel wheels made by Wheelsmith with my NOS hubcaps modified to fit. The S/S wheel trims from Wheelsmith should work out for that OEM look. I just need some new tyres now.
    I dropped the front fenders, hood, door caps, boot s****er spears, gravel shields (F&R) and miscellaneous other parts off to painter so everything can be finally painted and be ready for final body ***embly when I return home. As the car has a 125"WB, front and rear bars won't be fitted due to space restrictions in shed.
  19. swade41
    swade41
    from Buffalo,NY
    Still farting around with the wiring on the 41, right after I wired in those dash lights I was complaining about costing $50 bucks for 4, I found the missing lights.
    I can't find the bracket that holds a light behind the dash that shines out of that slot above the 4 holes, so making a bracket is next on the list.
    While looking for outside Christmas lights in the ba*****t, that I couldn't find, I did find a missing box of die-cast I packed up 21 years ago before the move into this house.
  20. patsurf
    patsurf
    all those hard launches finally tweaked the dash enough to dislodge the odo........
  21. Bandit Billy
    Bandit Billy
  22. patsurf
    patsurf
    i don't see ink in there--maybe only pencil!
    Bandit Billy likes this.
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    My Mom uses ink, I use pencil.....
    Lloyd's paint & glass likes this.
  24. Bandit Billy
    Bandit Billy
    Pencil is traditional.
  25. Bandit Billy
    Bandit Billy
    I bought the NYT games online so could game but I wouldn't have to read the dribble they print in the paper. I like the Friday and Saturday; my wife likes the rest. I have done 1994 thru 1997 and current date back to 2017. I am an addict. For those that enjoy a good cerebral work out, old puzzles will make you think on several plains. For example, a 1997 puzzle the other day asked for a Seattle pro team, it was Sonics. They haven't been there since 2006. Yeah, fun times.
    The HAMB should have a daily traditional crossword puzzle. Hmmm. DIZZY, CARBY, RIMS, TAPPET...Could be fun.
  26. 57 Fargo
    57 Fargo
    Billy I have car related ones at work somewhere, someone thought maybe for students, more stock mechanical stuff related I believe, after the holidays I’ll try to remember to find them.
  27. Moriarity
    Moriarity
    SUPER MODERATOR
    So, I was going to put the instrument panel back in the 56 but I couldn’t do it, the upholstery material had shrunk and cracked and it looked shabby
    So, I took it back apart and removed the white vinyl
    BFBB16F3-0CEF-4FDA-A92F-76E654C4298F.jpeg 6856B2B5-3074-4519-861F-B79F08DDD9B8.jpeg EB3FFB12-624B-4366-8289-C51EC203040A.jpeg 4D8F7224-A564-4D96-A6AF-E1516882C6C7.jpeg
    See those aluminum grommets they used for the blinker and high beam indicators? I tried to remove them without ruining them but they were rivet peened on the back and I tried to straighten and remove em but they got bent up. I ended up removing the mandrels from som 3/16 pop rivets and drilled them out to match what was there
    86D5B7F4-0FC4-46CE-887F-E9A27651C82C.jpeg DA70067A-9909-4E57-A500-A43EF9967911.jpeg
    I cut out and contact glued on some new white vinyl material
    I then riveted the new grommets
    C9838B45-9969-4426-AF7A-1EDD67E27BD6.jpeg 6416B35B-0899-44A7-B7B1-91DFB5ABE987.jpeg 6416B35B-0899-44A7-B7B1-91DFB5ABE987.jpeg
    Back together
    Before
    after
  28. -Brent-
    -Brent-
    I'm so pleased with this, I wanted to share it.
    A pal built an off-set header that resembles the 1960s Hedman on the other side. This clears my steering box and allows access to the spark plugs, mounting holes and such.
  29. mad mikey
    mad mikey
  30. pirate
    pirate
    from Alabama
    I typically run out of eraser before pencil!
