Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. atch
    atch
    Is that unusual?
  2. Bandit Billy
    Bandit Billy
    Like my old friend Dean used to say "You're not drunk if you can lie on the floor without holding on"
    61Cruiser, BJR, mad mikey and 7 others like this.
  3. fastcar1953
    fastcar1953
    Happy Holidays to all you nuts. Glad your back Lloyd. I'm still working on heating my shop.
  4. spanners
    spanners
    I don't have to do that down here in the Riverina area of N.S.W., Australia. Just had a couple of days around 107.6 F and the temperature in the shipping container I keep my racecar in hit 49 C or 120.2 F.
  5. fastcar1953
    fastcar1953
    Must be nice. It's starting to get in the 20's f here. Snow will be here soon. I would take hot over cold anytime.
  6. Today I dragged the 57 Pontiac out of the back room, vacuumed off the cob webs & took a bunch of pictures of it. Since I bought "Stubby" I don't need to build my own G***er, so it will be up for sale on here & FB Marketplace after Christmas along with the Speedway straight axle kit & rebuilt/re-plated tri-power setup.
    God Bless & Merry Christmas
    Bill
    https://www.jalopyjournal.com/forum...ar-transport-hauling-open-or-enclosed.614419/
  7. lumpy 63
    lumpy 63
  8. saltflats
    saltflats
    from Missouri
    Opened an early Christmas present for the race car. Now maybe this thing won't run 295 degrees. :)
  9. atch
    atch
    Is that aluminum or painted?
  10. saltflats
    saltflats
    from Missouri
  11. 67drake
    67drake
    from Muscoda WI
    IMG_0184.jpeg IMG_0181.jpeg IMG_0183.jpeg Started cleaning and painting engine parts this week. Noticed while in the parts washer that the oil pan was dented in on the bottom. Looks like the oil pump pickup was really close, or touching,as I could see some witness marks inside the pan.
    I took a 2x4 and sledgehammer to straighten it out best I could by eye. I’ll check clearance to the sump on ***embly.
    Before and after pics. I wonder if this contributed to the low oil pressure I saw on this engine?
  12. Greg Rogers
    Greg Rogers
    Salt, that is a real interesting radiator!
    Bill's Auto Works likes this.
  13. saltflats
    saltflats
    from Missouri
    Some of the bigger core radiators need to be notched for steering box clearance on a 62 Bel Air.
  14. Hey Lumpy, a 351w? Looks interesting. The FE is my favorite Ford, but the Windsors are darn good engines. What is yours destined for?
  15. atch
    atch
    That's a beautiful radiator.
  16. vtwhead
    vtwhead
    Years ago I upgraded my manual steering on my 64 biscayne and then found out I needed a notched radiator to clear the box. An unpleasant surprise since I had to retire my 4 core new desert cooler which I still have in inventory:rolleyes:
  17. lumpy 63
    lumpy 63
    Yes its a 351w , its getting a set of aluminum heads and going in my friend Marc's 61? unibody shortbed.
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Love those trucks.
  19. saltflats
    saltflats
    from Missouri
    I had one to try in the car and wouldn't clear the manual box that is in the car. :confused:
  20. norms30a
    norms30a
  21. saltflats
    saltflats
    from Missouri
    Thanks Mike. To nice for my stuff. :D
  22. nobby
    nobby
    changed the engine for an earlier style fits much better
    starter on the other side
    oil pan has a rear bowl and clears the drag links
    cast exhaust manifolds are hugger so the column is much further away that the other one
    motor mounts more forwards
    the stock floor ' WILL FIT WITH NO GOOBERING'
    this engine was never released with a manual transmission, it is a ford cologne engine -
    had its DEBUT IN 1964 so it is HAMBTASTIC
    so you have to scour the planet for a mt75 v6 gearbox, in the uk they only existed in v6 vans in two wheel drive layout- in europe they exist but are rare now so you have to make a hybrid using the almost able to find 4 wheel drive cologne v6 case
    so now you have to do it yourself and take a 2wd rear tail from a ford van or the rarer earlier cars and STINK OF USED TRANSMISSION FLUID for two weeks
    upswept cast headers, stock aluminican il pan with the bowl REALLY far back, look at the space for the drag link why dontcha!!
    can get the pulley almost in the flathead position, with the stock firewall
    when they were first launched they were cable clutch, in their evolution they co to a hydraulic slave, you grind away the two struts and mount a slave there adn use the stock oem transit van fork
    IMG_20231223_183538.jpg got to sink the rear down into the x member and make a ring of some sorts, shifter from van sits on tail, no s10 t5 tail required compact box 22 inches long - small ish diameter 240mm or 9.5 inch clutch is v860 size, so.... the stock floor will go in!!
    exhaust manifolds hug and dump JUST WHERE YOU WANT to aim towards the holes in x member
    need the stock firewall back now FFS
    out with the new, in with the old!!!
    start with the hard to find 4wd box v6 cologne
    find a 2wd tail
    It is really quite a compact drive train, starter really helps being on this side rhd. there was too much going on with the starter drivers side, manifold, BIG saginaw 800 and the engine mount in there.
    have to nibble and the centre x a bit, but realistically it wants up and over stiffening like a 41 onwards frame, do not have to split the wish - bone - bonus
  23. saltflats
    saltflats
    from Missouri
    Interesting, guess I should look up the history on that one.
  24. 29 Model A s
    29 Model A s
    I rebuilt the NH carb on my 26 T rpu, changed the oil, new plugs, added fresh gas and fuel stable (to the empty tank), and charged the battery. The last time I worked on it was about 2years ago but it only turned over 4 times and started up. I probably did all this because I feel guilty for not finishing it and planning to start a new 29 A sedan banger project in the next few weeks.
  25. fastcar1953
    fastcar1953
    Heat is on. Second lift is up. Still working on ceiling.
    Found this while I was cleaning. IMG_20231224_181626073.jpg IMG_20231224_181525589.jpg IMG_20231224_181549239.jpg
  26. hotrodderhaag
    hotrodderhaag
    I’m working on a 29 roadster body im impatiently awaiting its arrival .. hand delivered from North Dakota down to North Carolina.. going on a stock a ch***is and running gear , with a few speed parts. A set of 18” wires are coming with the body. .. kind of a “ early dry lakes” car. IMG_3452.jpeg IMG_4699.jpeg
  27. Jkmar73
    Jkmar73
    from Tulare, CA
    Readjusted the rockers after break in. Adjusted timing and idle. Did drive the car out of the garage for the first time. Only about 15 feet. Would have went farther if I had a steering wheel on the car.
  28. Wrapped up this early, power pack headed 283 on Christmas eve.....ready for some fire ! 410830233_174620602374884_4570870959700166664_n.jpg
    Merry Christmas !!
    choptop4, Voh, 1pickup and 21 others like this.
  29. Frames
    Frames
    Building a flathead to sell. ***embling sprint car ch***is for my museum. Building a 32 roadst 2023-11-30 09.58.18.jpg 2023-12-02 16.10.52-1.jpg 2023-12-23 14.15.17-1.jpg er for my 9 year old grandson.
    ffr1222k, 61Cruiser, scotty t and 5 others like this.
  30. Johnny Gee
    Johnny Gee
    from Downey, Ca
