what bolt pattern? 1953 International
Discussion in 'The Hokey Ass Message Board' started by unclescooby, Jan 14, 2006.
  1. unclescooby
    unclescooby
    from indy
    I need to pick up my pickup! It's a 1953 International. It's a nice truck with a clean ***le that I bought locally for cheap. It's been sitting for a long time though and I thought I'd take some wheels and tires to go get it (about an hour away). I forgot to measure the bolt pattern for the wheels and the feller I got it from does know and I'm not sure I'd trust the measurement from someone who doesn't know how to measure them. Anyone know for sure?
  2. unclescooby
    unclescooby
    from indy
    Help! Anyone? I'm planning to go in the morning. Is there a place to look this up?
  3. Kustm52
    Kustm52
    Hard to tell from the picture..is it a 3/4 ton? If so, not sure..if it is 1/2 ton it should be 5 on 4 1/2.. small ford pattern.
    Edit...it does look like 3/4 ton beadlock wheels..so I have no idea. Could be 8-lug...
    Brian
  4. unclescooby
    unclescooby
    from indy
    Thanks! It's a model 120 which I just found out is a 3/4 ton. Still the same?
  5. G V Gordon
    G V Gordon
    from Enid OK
    Unk, It looks like it has split rims on the back. Probably a 3/4 ton. If your lucky it will take the standard eight bolt 3/4 ton pattern. If it is like the old Metro van I had it is an oddball wide six bolt pattern. Best I can do.
    GV
  6. unclescooby
    unclescooby
    from indy
    Yep, I looked up the 120 on the web. It's a 3/4 for sure. Another thing that is for sure is that I don't have any of those rims! Guess I'll be dismounting those and getting some new tires. I actually kinda dig the big knobbys on it. Good farm truck. That's what it was. Few hundred bucks locally with a straight six and four speed. Nice solid truck with a clear ***le. One of those things you don't need but can't p*** on for that price.
  7. enjenjo
    enjenjo
    from swanton oh
    If it is 8 lug, Chevy 3/4 ton wheels will fit. But I think you will find they are 6 lug in an 8" circle.
  8. pool
    pool
    Try checking out oldihc.org it is an all I-H website they've got all the info you need. Good luck with your project. Pool
  9. red58
    red58
    also look out for the fact that the lugs on one side or the other [I forget which] are reverse threaded - don't break any!! :eek: :D
  10. Bruce A. Frank
    Bruce A. Frank
    This is very old so the information will only help the next guy looking, but the 6 lug International is a 7.25" pattern! Uncommon, but you can get wheels to fit, if you want to go tubeless rather than use the split rims, at http://www.stocktonwheel.com/heavy_duty.html
