what brackets needed to connect 700r tv cable to a 2 barrel 94 carb?
Discussion in 'The Hokey Ass Message Board' started by j_johnson, Feb 26, 2012.
  1. j_johnson
    j_johnson
    from Iowa
    What would i need to connect a tv cable and throttle cable to a 94 carb to maintain correct geometry? Surely someone has done this before. The parts stores don't have a clue. Pictures or places to buy would be great. Thanks
  2. askotto
    askotto
    from Peralta NM
    Check BOWTIE OVERDRIVES in AZ. They have just what you need in addition to adapters for many other carbs. YOU MUST HAVE THE CORRECT GEOMETRY as the TV controls everything in the 700R4 unlike the turbo 350 where it only controls the kickdown function. The adapter screws to the 94's linkage with a cam to give the correct pull ratio.
    Adjust the cable at full throttle, engine off of course! It should pull tight just when it reach's full throttle. Adjust in small increments to get the shift timing and firmness just right. Don't let it "get away" with shifting too early or too soft. This setting can cause damage to the trans clutch's in the higher gears. Have fun!
  3. j_johnson
    j_johnson
    from Iowa
    Thanks.i checked it out all I found was a kit for 2 barrel rochesters. Will the adapter work on a ford 94?
  4. BigDrag
    BigDrag
    from Milwaukee
    I'd be interisted in knowing the exact pull of a stock set up. From wide open to idle, what is the travel?
    I have a simmilar issue but nobody makes a "kit" the Meteors and I need to make my own hookup.
  5. tomcurnow
    tomcurnow
    from Los Angles
    Doing the same with an old 8 stack Hilborn , now with EFI, does the rotation ratio change ( like a cam shape) or is it constant. Thanks
  6. river1
    river1
  7. treb11
    treb11
