Technical What brake booster to use ??
Discussion in 'The Hokey Ass Message Board' started by 48coupe, Nov 1, 2016.
  1. I have a '74 Ford 2wd pu w/disc brakes in front. It stops OK but I would prefer a booster. Is there a certain yr. of Ford that I can use the brake booster on this trk. ? I used a kit from Summit on my '62 Galaxie and that was close to a nightmare to get it mounted & working. If another Ford donor isn't the answer what do you recomend ?
    Thanks for any info.
  2. gimpyshotrods
    gimpyshotrods
    If it were me, I would swap in the booster from a 1974 Ford pickup.
    I hear that they are a bolt-in. ;)
  3. gimpyshotrods
    gimpyshotrods
    Oh, and you will need the power brake master cylinder to go with that.
  4. Jalopy Joker
    Jalopy Joker
    good advice from gimpyhotrods - don't forget, cut off here is '65
