what cap will fit a moon tank?
Discussion in 'The Hokey Ass Message Board' started by dannyego, May 7, 2009.
  1. dannyego
    dannyego
    I recently picked up a moon tank sans gas cap. Where can I get a cap that would fit it other than paying $100 through mooneyes to get one? The threads are on the inside which is opposite of any cap I have seen.
  2. Little Wing
    Little Wing
    from Northeast
    Look at a military surplus place
  3. dannyego
    dannyego
    What exactly should I be looking for it in?
  4. Kerry
    Kerry
    Fork up the $$$ for the tri bar spinner from Moon. It's very cool and worth it IMO.
  5. rick finch
    rick finch
    What Kerry said x2!!!
  6. dannyego
    dannyego
    Will it fit? Its an original 60's 8 inch tank. Are all the sizes standard? I would hate to spend the money and have it not fit.
  7. Little Wing
    Little Wing
    from Northeast
    They did make an early tri bar in 2 versions 1 was for the built in hand pump,,other was a regular. You would have to check to see if the still mke the inner thread ones
  8. Kerry
    Kerry
  9. lurker mick
    lurker mick
    Before you order that spinner style cap, call Moon and make sure the cap will fit an inside threaded tank. The new ones are for outside threaded tanks.
    I don't believe they still make one that fits an early tank.
    Mick
  10. dannyego
    dannyego
    I called Moon. They are not sure if it will work and told me some would call me back. So while I am waiting does anyone have one of these caps that could maybe let me know?
  11. dannyego
    dannyego
    Well Mooneyes called me back and I am out of luck.. They stopped making caps that would fit that in 1969. I need some ideas here boys. What could I use???
  12. lurker mick
    lurker mick
    My early Moon cap does not fit the later Mooneyes tanks. (male/female threads difference)
    I don't know for sure when they started to make the different threaded tanks. Possibly when the company was sold and became "Mooneyes"
    Mick
  13. RichFox
    RichFox
    I cut mine out on the lathe. Single pointed the threads. made it out of br***. Maybe aluminum would have been better. Lighter anyway
  14. fridaynitedrags
    fridaynitedrags
  15. 94hoghead
    94hoghead
    If you find a cap that will work Let me know. I'm in the same boat.
    94
  16. Kerry
    Kerry
    Wow, The tank I got had some pretty significant road rash but it did have the spinner cap. I'm really glad now.
  17. Big Russ
    Big Russ
    Lads I made a spinner using a Cragar spinner cap & the bung from a 44 gallon drum.
  18. dullchrome
    dullchrome
    from SoCal
    I live down the road from Moon. Sell me your tanks and I will walk them into the shop to get caps.
  19. dannyego
    dannyego
    moon does not have caps to fit the 60's tanks. I am going to try a marine store. It looks like a marine cap may work.
  20. Fwiw, my Moon cap, circa late 50's has a double eared cap much like a factory gas tank cap.
  21. enjenjo
    enjenjo
    from swanton oh
    60s International big truck caps will fit. Mase of br***.
  22. dannyego
    dannyego
    I just found a 60's international one on Ebay with a buy it now that looked like it should work. Ill let you all know once I get it. It was only $20 shipped and it doesnt look like it would look out of place on the tank.
  23. dannyego
    dannyego
    International cap does not work, at least not the one I got. Back to the drawing board.
  24. Have you seen the caps with internal threads that come with aftermarket tanks for hot rods?
    I'm not sure of the size, but it appears to be 2" with fine threads.
    Measure the OD of your tank filler tube/bung.
    Get yourself a thread gauge - not too expensive, a little bit more than a good quality feeler gauge - and measure the thread count.
    Once you have that information you could probably find one at the tank suppliers.
    It seems to be a fairly common size.
    P&J and similar would be good places to contact as well.
    I'm fairly sure the re-pro Deuce tanks use the same size cap.
  25. dentprone
    dentprone
    How close is the outside diameter of the cap threads to the inside of the tank threads? If there is enough meat on the cap, it can be turned down/threaded if I know the thread in the tank. PM me if you can't find anything.
  26. dannyego
    dannyego
    its actually 1/4" too small. I need 2/4" fine thread. I just got back from NAPA and they do not have anything in there catalogs even for big trucks. the closest they have is 2 1/8". I didnt realize what a pin in the *** this was going to be. Next time I will buy one with a cap:mad:
  27. Mopar34
    Mopar34
    I liked RichFox's idea, especially since you don't seem to be having much luck finding a ready made unit. Maybe he can make you one. Or PM Brianangus, I do know that Brian is a machinist and has made specialty parts on his lathe before. Might be worth a try, at least you might discover an estimated cost for such a build. You will have to know a lot of spec details in order to get something machined.
    Good luck, and you're right, sometimes bargains ain't bargains.:eek::D
  28. KeithDyer
    KeithDyer
    Any chance that a large diameter AN type fitting might fit.
    Not sure of the AN style nomenclature but it will have hex top, o-ring provision, and fit in a female thread.
    A lot of the early California stuff was based on military surplus.
    Buff off the blue anodize and go from there.
    Or get a piece of aluminum and whittle away everything that not look like a Moon tank cap.
    K
  29. Little Wing
    Little Wing
    from Northeast
    The old ones are Military style threaded caps,,Check for old Military fuel caps,,some old Semis used teh same style caps
  30. 5wcoupehunter
    5wcoupehunter
    from FLORIDA
    this one fits mine.
