what carbs to use on 2x4 caddy
Discussion in 'The Hokey Ass Message Board' started by carlitos way, Feb 9, 2012.
  1. carlitos way
    carlitos way
    first thank you guys here on this site for past help.i want to put dual carbs on my 53 Caddy pickup it has the stock 331. i bought an dual quad intake from a 55 eldorado but i need the carbs. i was thinking of used the new edelbrock carbs but don't know what size.also i was thinking of using an aluminum intake that i saw on ebay it takes two 2 barrel carbs stormbergs i think. Let me know guys I will be posting pics soon thanks again carlos Smith in Tucson AZ
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    They came with both Carter WCFBs and Rochester 4GCs. You won't be bolting Edelbrocks to it without some adapter plates.
  3. carlitos way
    carlitos way
    did one carb have a chock or both carbs
  4. bwas
    bwas
    they came with carter wcfb's and only the rear came with a choke. "correct" ones cost a mint, but you can find wcfb's and epoxy the front choke shaft holes and they will work fine. they are about 380 cfm apiece, so you'll need a bit of cam to run right
  5. carbking
    carbking
    The Edmonds 2 x 4 probably has the early "square" (it isn't quite) bolt pattern. If so it would take 1952~1955 four-barrel carbs. These would include in alphabetical order:
    (1) Carter SOME WCFB's
    (2) Holley 2140 and 4000
    (3) Rochester SOME 4GC's
    (4) Stromberg 4A
    I would probably suggest the Strombergs
    The 2 x 2 setup can run a number of different carbs if the owner wishes. We have set up several that used two of the original Carter WCD 595s carbs.
    Jon.
  6. falconsprint63
    falconsprint63
    from Mayberry
    edelbrock 500's are the closest off the shelf carb you'll find as I recall. I had one, once, that had 2 holley 600's on it. looked like crab and they barely fit--not sure if it would have even run.
    as mentioned above the correct one's are spendy--from what I recall one was like 490 and one was 505 or something odd like that.
    FWIW, it's also my understanding that they need to be run as a direct setup (running 2 barells from each carb initially then opeing they other two), not not a progressive 2-4-6-8 deal.
  7. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Although the WCFBs that came on Chevrolet and Chrysler dual quad setups used one choke, the Cadillac setup had chokes in both carburetors. That's not to say that you have to set yours up the same way, but that's how it was from the factory.
  8. M.Edell
    M.Edell
    I ran 2 500 CFM Edelbrock on my Weiand 2x4 Caddy.I like to pull the "Edelbrock" metal tag off the front of the carbs.
  9. stock Cad is going to want less CFM. a slight cam and raised compression and those 500's will smoke the tires
  10. M.Edell
    M.Edell
    Good point, I should have mentioned that my 2x4 Caddy was punched out to 354 CID,Jahns Pistons, healthy Cam, headers, etc. Made lots of Torque! I am considering building another Caddy for my 34 and pulling the flathead for something else.
  11. M:)arkus you had the king of Cads, I've owned 5 cars with 331's looking forward to someday go 365-390. but every 331 has been totally reliable and great performers. always went with dual quads my current 331 in a 54 GMC has the 58 tri-power. still not on the road yet...48hemi/noname
  12. swissmike
    swissmike
    How much CFM did the single two barrel flow on a stock early 331? How much performance can be gained by using a bigger carb or multiple carbs on a otherwise stock engine?
  13. M.Edell
    M.Edell
    Just bolting a stock cast Iron 4V Intake with an Edelbrock carb would show a great improvement in performance.I wouldnt go too crazy on multi carbs and intake on a stock engine, you will hurt the performance more than improve it.
  14. M.Edell
    M.Edell
    Ive been seriously thinking about selling the new flatty for the 34 and doing a 390..
  15. carlitos way
    carlitos way
    this is what i have now stock intake with a edelbrock carb now.i don't want to change the engine to much maybe just a new cam if that will work with the dual fours ,if not i may just put a dual 2 barrel intake with stormbergs. ijust want a hot rod look.finned valve covers and valley cover.
  16. M.Edell
    M.Edell
    I was actually replying to swissmike, but Two dual carbs on a stock 4 bbl intake would be cool or a stock dual quad with 4 carbs inline.
  17. swissmike
    swissmike
    Got a stock rebuilt 331 that I am thinking of putting a repop 2x2 Offenhauser with 94's on it or just go with the stock 2 barrel for a early 50s style custom.
  18. carlitos way
    carlitos way
    who sells the repop 2x2 offenhauser,valve covers and vally cover ?
  19. swissmike
    swissmike
    Vintagespeed.com sells the 2x2 Offenhauser intakes drilled for either 3 or 4 bolt carbs.
