I'm running and s10 rear in my 1954 chevy and I want to run steel wheels I'm looking for a 15 inch rim 5 on 4.75 bolt and a 6 inch back spacing I need it to look like the pic below,(not one with punch cut holes all around.) Anyone have these or know what car I could pull them off of or any other ideas? -spencer
not with 6 inches of backspace. you'll need custom ones made, otherwise you're stuck with 4wd mini-blazer rims...
The 54 Chevy wheels will have the pattern your looking for..and most chevy wheels will also be 5 on 4.75..but not a 6" B.S. why so deep? and what do you intend to have as your over all width of your wheel?Heck the original 53-54 chevy wheels were only 6" wide total. if you need 6" of back spacing..your probably going to have to make them..or have them made
That picture you posted looks identical to the spare I run on my '67 Impala. I think I got it from my friend's S-10 blazer. Pretty sure there's a Chevy Astro van parked at my apts too that has the same wheel on it.
guessing a 4x4 s10 rear....otherwise , he'd be looking for a shallow backspaced wheel.....unless ..... never seen any 4x4 s10 wheels with the normal center....always seem to have the little holes...
I was only going by that because, i was told the the stock s1o wheels will work and thats the dimensions they are. I guess if I have a narower rim I will have less back spacing? anyway anyone have any other ideas on what rims will work, im running 15inch 670 biasply
astro's have a 5" pattern...thought the same thing when i had my astro van...hard way to find out after you buy the trick wheels...
Do yourself a favor. Borrow a standard rim off a camaro/chevelle/vette/early impala/2wd S10. Put it on your car and see how the backspace works out. Now you have some kind of ballpark figure as to what will clear your fenders. Good luck
