What Cars had master cylinders mounted on the firewall?
Discussion in 'The Hokey Ass Message Board' started by jnunez1955, Jul 25, 2010.
  1. jnunez1955
    jnunez1955
    im trying to build a traditional 40's hot rod....and is curious of what 40's cars had the master cylinder mounted to the firewall...so i can buy parts from that car/truck.
    I know most cars, the master cyclinder was mounted under the car...im not to fond of the idea because of things i read about brake pressure problems....and i will be dealing with clearence issues as well.
    any pictures and info, will be greatly appreciated.
  2. 39 All Ford
    39 All Ford
    from Benton AR
    New ones.
    :D
  3. JohnEvans
    JohnEvans
    from Phoenix AZ
    Nothing in the 40s that I can recall. 52 up Ford cars were the first pretty sure.
  4. 49ratfink
    49ratfink
    55-57 Chevys have a firewall mounted master cylinder/pedal ***embly that is adaptable to other cars
  5. Aviator
    Aviator
    '60-64 or maybe mid Chev PU trucks has a very popular and adaptable style. Check with Kanter Auto on the internet.
  6. wetatt4u
    wetatt4u
    I was going for 1955 and up .
  7. patrick66
    patrick66
    Depends on the make of car. Hudson and Nash remained under the floor through the end of each in 1957. GM started in 1955, and Ford was '52.
    I can not think of a car built in the '40s that actually did have a firewall-mounted brake master cylinder from the factory.
  8. jnunez1955
    jnunez1955
  9. 62rebel
    62rebel
    i can understand your desire to look traditional for an era, but some of the things that were done then were done because they didn't have a second option to work with. even when the M/C's were firewall mounted, it wasn't until the late sixties that they had dual reservoirs, to seperate the braking circuits for safety/proportioning....
    if you're building a 30's car/truck, you can mount the M/C sideways or reversed under the cowl and get away from the undercar setup.
    MG's and Triumphs had combination M/C and clutch setups that mounted above the pedals; they could be setup under the cowl.
    just offering some ideas.
  10. Atwater Mike
    Atwater Mike
    Fords from '52 had a superb system, removable shaft, excellent bushings, solid pedals.
    (we used to use Chevy swing pedals for Bootleg-Hurst shifters, the brake pedal welded to a Corvette 3-speed linkage, looked like a 'painted Hurst'!)
    Seriously, the Ford bracket will sandwich the firewall between the master cyl and the bracket, and the rear of the bracket attaches to the dash! Talk about solidifying a dash/firewall/steering column! Good setup. Clutch linkage will require a bellcrank. Also Ford stuff.
