What cars/trucks do I need to look for to find 5 on 5 steel wheels?
Discussion in 'The Hokey Ass Message Board' started by SwitchBlade327, May 7, 2006.
  1. SwitchBlade327
    SwitchBlade327
    I'm getting sick of just asking around, and I have no idea what to look for. No time to roam the yard with a tape measure. The cragars on the wagon don't have the proper backspacing and the tires rub in the back when I have it dropped. I need new tires (like two weeks ago!) but don't want to put new ones on and tear up the whites on them. I want to try to find some wheels tomorrow, but need to know some specific vehicles to look for. Can anyone cook me up a list?
    Sorry if this post is a little ran together, I'm tired and my fingers are all cramped up from wetsanding!
  2. Early Buick Olds Pontiacs -50s 60-s
    70s 80s same cars......Wagons usually and 1/2 ton Chevy and GMC pickups
    & Geo Tracker
  3. chiefbobber
    chiefbobber
    from NH
    Right off the top of my head I'd have to say. That's GM big pattern. Vans, Trucks, Wagons, Caddys, Buick rivs. so on so forth. Whats your wagon?
  4. oldskool55
    oldskool55
    from socal
    these are 5 on 5 i got them off a mid 70s full sized buick. buick made them on through the 80s and early 90s
  5. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    I think Merc 55-61 was 5x5
  6. KingpinOlds
    KingpinOlds
    Check out this link-http://www.teufert.net/wheels/bolt-pat.htm
    Rick
  7. prime mover
    prime mover
    thats right but most will be 14's. look for 70's and 80's chevy trucks, full size vans(1/2 ton), 60's and 70's cadillac and buick.and some late 70's lincoln/t-bird.
  8. SwitchBlade327
    SwitchBlade327
    Thanks for the info guys, that website kingpin olds posted is the ticket! Thanks Rick!
  9. 302GMC
    302GMC
    from Idaho
    If the wheels are for the '64 Buick, the center hole in Buicks is bigger than all the other factory equipment 5 on 5 wheels you'll find, so you'll have some clearancing work to do ... most have no alignment pin holes, either, if the '64 still uses them.
    302
  10. SwitchBlade327
    SwitchBlade327
    Shit, i didn't think about the center holes! I had to do that with some wheels on my old car and that sucked! I can't remember if the locating pins are still there or not.....
  11. briggs&strattonChev
    briggs&strattonChev
    73-current gm 1/2 ton 2wd pickups at least, maybe all the way back to 67
  12. Kustm52
    Kustm52
    Center holes will have to be enlarged unless you find buick wheels.. no locating pins on the '64. I'd look for a set of the stock buick chrome wheels.. or if nothing else you should be able to find a set of steelies from a mid '70s electra or something....
    Brian
  13. wannabewannabe
    wannabewannabe
    Late model Caprices, Roadmasters, and Fleetwoods got em too.
  14. primered_69
    primered_69
    1971 - 1998 chevy trucks had the 5 on 5 - however the rally that came on these trucks will not hold a center hub cap but will handle a full hubcap. Most rallys were 15x8. Nonrally were usually 15x7.
    Most of the Chevy vans of this vintage were 15x7.
  15. Relay
    Relay
    If you're just looking for a quick set of stealies, here's what i did i just went downtown to a used tire and wheel shop bargained with the guy and got a set of stock 5x5 wheels with tires for a hundred bucks. i use them to roll my 53' around as im working on it.
