Technical What causes an engine to fail?
Discussion in 'The Hokey Ass Message Board' started by 57JoeFoMoPar, Apr 26, 2016.
  1. 57JoeFoMoPar
    57JoeFoMoPar
    I drive to work about an hour and a half in each direction, so I have a lot of time to think. Today's musing was, "What specifically causes an engine to fail?" Or more specifically, what is the difference between an engine that can perform at high performance, for extended periods of time, and just a regular-***, stock running engine? Obviously, the quality of components plays a significant role. It goes without saying that a forged steel crank is stronger than a cast crank. But that can't be it, and I don't accept that if the people on the ***embly line were slapping together engines in m*** with race components that they'd be strong enough to handle the rigors of compe***ion. In other words, if Yates and some random GM worker were both given the components of a NASCAR Chevy R07 engine, when ***embled, would they both equally be able to run 10,000 RPM for 500 miles? My guess is no. So I'd like to hear from some people who are spe******ts. What is it that specifically that causes engines to break?
  2. squirrel
    In real life? Lack of maintenance...
    stimpy, i.rant, volvobrynk and 4 others like this.
  3. wbrw32
    wbrw32
    A heavy right foot has broken many
    volvobrynk likes this.
  4. Jalopy Joker
    Jalopy Joker
    push rod exiting the side of the block
  5. Atwater Mike
    Atwater Mike
    Mechanic failure
    falcongeorge and Bandit Billy like this.
  6. dana barlow
    dana barlow
    from Miami Fla.
    Over heating is mostly #1,but the list is big.
  7. woodhawg
    woodhawg
    You have too long of a commute and too much time to think.
    clem, firstinsteele, 54fierro and 5 others like this.
  8. Flat Six Fix
    Flat Six Fix
    Poor or no maintenance, dirty oil, lack of oil, overheating, dirty fluids.
    Pushing it beyond maximum limits for an extended period of time, again = overheating, oil issues, are possible....
    clem likes this.
  9. 57JoeFoMoPar
    57JoeFoMoPar
    I totally agree, but this is only the beginning of the answer. Specifically, what about hard driving causes engine failure. Inability to manage heat and breakdown of oil viscosity? If yes, then could a palliative measure be to use a high volume pump in conjunction with a increased capacity oil pan?
  10. RmK57
    RmK57
    Cold engine starts are the worst thing you can do to any engine. It won't cause the motor to fail right away, just wear out quicker then fail.
  11. Larry T
    Larry T
    As far as why a race engine will last for 500 angry miles and a stocker won't, it's got to do with the development work that is done before the race engine is built, money (lots of it), attention to detail.
    I'm guessing there isn't a single OEM over the counter part in a Nascar engine.
    Most street engine failures that I've seen are caused by abuse and neglect (oil changes etc. But some are just worn out.
  12. Dirty oil = water jet cutter, cutting thru all that iron.
  13. pitman
    pitman
    I agree w/Dana re: overheating. Or lube issues.
    Then, if you look at higher output loads, my first guess would be wear-over time.
    Rare, at least in the SBC world, have I seen fatigue fails. Any neglect like not cleaning out a block prior to ***y, or re-torquing heads, rocker quality, stud pinning reqd. for higher valve spring strengths, can bring the Big Ooopps. :oops:
  14. RmK57
    RmK57
    True, considering that Ford and Toyota haven't built a pushrod engine in over 20 years.
  15. Yep that's it right there. ^^^ more than any other reason.
    An ***embly line engine should actually be more consistent than a one off engine. Look at it this way, the fella that checks the crank does it day in and day out with the same numbers and the same tool everyday, the fella that torques the heads is a head torque guy and he torques them day in and day out everyday. All the engines are identical and every component comes down the line identical day in and day out everyday.
    Now a one off engine is just that one off. No consistency there at all and lots of room for a mistake. usually the same guy tat torques the crank is the guy that ground it and he is the same guy that measures the cylinder clearance and torques the heads. In the world of engine ***embly he would be considered a jack of all trades as opposed to the ***embly line guy who does one thing and hopefully does it well.
  16. Mike_B
    Mike_B
    And using straight 30, 40, or 50 weight makes wear at start-up worse. Or even 20w-50. That's because lower viscosity oil, like 5w-30 or 10w-40, flows better on cold start-ups and gets pumped to bearings and valve train sooner. Only after warm-up do you need 30 or 40 weight. I'm not sure when you'd ever need straight 50 or 20w-50 except for intentionally loose clearances or to compensate for worn bearings.
  17. 57JoeFoMoPar
    57JoeFoMoPar
    That's a great point. The ***embly line engine is actually strong. Amazing how the average car engine now can last 200,000 with just basic maintenance.
  18. slack
    slack
    Apples to oranges.
    Heat+stress=metal fatigue-->failure
  19. 57JoeFoMoPar
    57JoeFoMoPar
    True enough, and the thinner oil also allows less parasitic loss and has less stress on the oil pump drive.
    I have a 454 in my pickup truck that has 184K on the clock, and I run 20w50 in that, which has helped keep oil pressure at a more appropriate level with the wider bearing space
  20. DDDenny
    Talking pre roller cams, break-in procerure (or lack of) plays a big part.
  21. bobss396
    bobss396
    Something on the inside that wants to get out does it for me.
  22. Blues4U
    Blues4U
    from So Cal
    Dana nailed it. Overheating is the #1 cause of engine failure. #2 would be contamination, which pretty much is because of poor maintenance as Squirrel posted. Dirt is the #1 contaminant, but coolant contamination of the engine oil has killed many engines. So has fuel dilution, though it's not as common, but it happens (more common on diesel engines because of the lower volatility). Over extended oil drain intervals. Incorrect oil or poor quality oil, or even running low on oil, these are all maintenance issues. But there are myriad causes for engine failure, from improper ***embly procedures (improper clearances, improper torqueing of fasteners - too tight or too loose, incorrect parts, etc) to exceeding the performance limits, i.e. over revving, or lugging; to metal fatigue (every part has a life span of x number of cycles it will withstand before failing, eventually every part will fail). Some forged or cast parts fail prematurely because of impurities in the metal, what are called "inclusions". A list of every possible cause of failure would be a long list.
  23. Look at it this way in the later '60s both FoMoCo and GM had a 302 that was a general screamer. Both engines were ***embly line motors, both ran best above 4K and preferred to be running in the 6-7K range and both motors were good for 100,000 miles with general maintenance. I have actually run one of each from the Lake of the Ozarks to Dodge City about 450 miles give or take, ran them hard, played while I was there and ran them back. Went to work on Monday.
    Take any motor no matter who screws it together and flinch at maintenance and it will fail. Run it out of oil or without water, or gas fouled oil and it is doomed from the time that you got it.
    arkiehotrods, slack and volvobrynk like this.
  24. squirrel
    And overheating is almost always caused by lack of maintenance....
  25. HOTRODPRIMER
    HOTRODPRIMER
    Neglect when it comes to maintenance,not checking or changing the oiling on a regular basis, overheating because the radiator is low. HRP
  26. Mr48chev
    Overheating is probably the number one reason for engine failure.
    lack of proper periodic maintenance is probably number two with dirty oil, dirty filters and actually running out of oil.
    Lack of preventive maintenance is right there too. Who's daily commuter rig with 5 years and over 100K has had all it's belts and hoses changed lately? We go over our hot rods with a fine tooth comb before hitting the road most of the time but that get you to work in traffic rig often still has the original belts and hoses after it's ten years old.
    It's funny in a way but the lowest mileage rig in my yard right now is a 92 Dodge Dakota with 95K actual miles on it that has a broken timing belt. I picked it up for pocket change to get the front suspension. The thing even has tow bar brackets on it that show that many of those miles were behind a motorhome as a dingy. Again the result of preventive maintenance killed the engine.
  27. williebill
    williebill
    I can personally guarantee that running with no oil with do it every time. And that adding 5 quarts at the next gas station is a waste of money. It's amazing the noises they make as they slow down right before they grenade.
  28. Black Panther
    Black Panther
    from SoCal
    57Joe....This is a case where knowledge can be a curse. Knowledge/worry used to wear me out on rides in my old cars...I'd be waiting for **** to break. Rarely happened luckily. ***uming you maintain your car and watch your gauges...say **** it. Since it seems I've gotten a little older lately I don't get wound up as often with things I can't control. Get AAA and if it breaks you get it home and fix it....
  29. I drove semi truck. And Maintience plays a big part. however the nut behind the wheel plays a big part. After about a million miles Metal fatuge sets in. A rubber ball will only bounce a certain number of times. My 66 GMC is receiving its Bi Annual oil & filter change today It probably has some where between 4 and 5 thousand miles on the oil & filter. I never mess with the spark plugs since it has electronic ign.I have seen engines ruined by too few oil & filter changes. I have never seen one ruined by two frequent oil changes. I installed a rochester chevy stuff 033.JPG chevy stuff 032.JPG two bbl carb. The holley since I didn't open it up the secondairy the gas turned to varnish.
  30. H380
    H380
    from Louisiana
    FRICTION
    Less = Good
    More = Bad
