COE What chassis are you using under your COE's
Discussion in 'Off Topic Hot Rods & Customs' started by moparron426, May 16, 2009.
  1. pistinbroke
    pistinbroke
    Looking for info or build pic's of COE's turned into four door cabs or streched cabs. I have been gathering parts for mine (38 Ford) for a couple of years now and am getting ready to light the torchs. General thought it to make it into a tilt deck crew cab. I want to be able to haul the family as well as the hot rod.... So far I have gathered a ***mins engine, an F350 super duty frame, original sheet metal, ect. Looking for ****** options as well.
  2. Hi Pistinbroke :)
    Below is a the link to my web site where you will find a few dual cab conversion pics.
    Just go to the overseas section and start looking.
    The Web site address is a new address as I have just changed it from the previous web site address as I couldn't upload files to it anymore.
    That's my excuse anyway.
    http://coetrucks.t35.com/Index.a.html
    Seeya
    Bill
  3. pistinbroke
    pistinbroke
    Hey thanks for the reply Bill. I have been to your site in the past (not for a while though) and have found it full of insperation!!! It's a great site, thanks for putting it together!!!
  4. rustynuts 1939 coe
    rustynuts 1939 coe
    does anybody know of a brake master cylinder that is firewall mounted left to right maybe early dodge van , building a 1939 ford coe
  5. Metaltwister
    Metaltwister
    That is exactly what Im using... This unit is out of q mid 70's handicap van. little tight but not bad.
  6. DEZEL INGEN
    DEZEL INGEN
    what did the dog do wrong?? she didnt have to go after those keys did she?
  7. Donnda
    Donnda
    You guys that are going with the engine under the hood. What kind of leg room do you think you will end up with? Can you get the cab low enough to look right? The guys that put the engine behind the cab usually are building a ramp truck and its no problem. Lets see some of the interiors of the engine under the cab.
  8. DEZEL INGEN
    DEZEL INGEN
    Metaltwister, the air box looks good and great access to the filter.
  9. DEZEL INGEN
    DEZEL INGEN
    Donnda, not sure if this is helpfull with your build,
    heres a 4btta ***mins (that are a bit taller than most v8s) that i moved back under the seat area. do to clearances its gonna be dry sumped.
    [​IMG][​IMG][​IMG]
    and as to ride height look. 5"clearance at lowest.
    again dont know if these would be helpful in what your trying to think thru, but if ya have the time heres a link to some build photos. luck to ya. gw http://s344.photobucket.com/albums/p348/Dezel_Ingen/coe/?start=160
  10. rustynuts 1939 coe
    rustynuts 1939 coe
    using gm one ton dually ch***is front clip and four x six square tube for frame, custom fabricated rear half. narrowed dually rear axle with air bags .05 gm truck rack and pinion
  11. Ray Hill
    Ray Hill
    I'm building a 53 Dodge COE, using the stock frame. The suspension is off a 92, 3/4 T, GMC van for front and the rear off a 75, 3/4 T, Chevy pick up.
  12. DEZEL INGEN
    DEZEL INGEN
    look n forward to build photos.
  13. Donnda
    Donnda
    Yeah Ray, Some pictures please !!!!!!!!!!!!!!!!
  14. gentrys51
    gentrys51
    from kansas
    my 50 gmc is on a 50 chevy half ton frame with jaguar suspension with a 50 chevy 1 ton 9foot bed. it worked perfectly
  15. scottm1
    scottm1
    My 48 Ford COE hauler is on a 93 Dodge 1 ton frame/ch***is stretched 9 feet. It wasn't what I intended to use in the beginning, but after I realized it was the correct measurements and I already had it, I went ahead and used it. It actually worked pretty good once I solved the steering box angle problem.
  16. Lowriders Art Gallery
    from Montana
    Planning on using a 75 Ford motorhome 1 ton ch***is under my 54 Ford Coe. Don't know how it will work with a 460 in the stock location. These cabs seem to be a little bit bigger than the 40's cabs.
  17. punkinjr123
    punkinjr123
    going with older motorhome. stripped body.plan to use 1950 ford coe body with sleeper with flatbed. thats my winter project
  18. jernlee
    jernlee
    I am running my 55 ford coe on a 1972 chevy 1/2 ton longbed frame
  19. gjcat56
    gjcat56
    Lowriders, I think the motor will set better with the frame your using, but the steering is a rear steer which could be a problem. I`m using the 88 F450 ch***ie and the motor sits back about 4" , but its a front steer which will work better in these cabs. I`m thinking of grafting the axles onto the OEM frame which will give me mor room to fit what ever motor I decide to stuff in there.
  20. Get Your RadioActive
    I have my 51 Ford on a 92 Dodge 3500 frame with the 5.9l diesel up front, coving all the bases because the car hauler part will have my 49 pick-up ontop.
  21. Roger Walling
    Roger Walling
    My 41 Ford COE has been fitted onto a 84 Chev van. Fits good, 10' 6" pick up bed with tandem axels.
    Still photo handycapped!
  22. mad-cad
    mad-cad
    for my 56 LCF I'm going with a 1995 gmc crewcab dually 4x4 ch***is.I'm hoping I can turn down the torsion bars on the front end and get the truck lower and still have 4x4 for up in the mountains here.
  23. 62Panhead
    62Panhead
    Just find & stripped a 1985 GMC crew cab dually with a running 454 for the '49 Ford COE. I'm going to go with the engine behind the cab. Plans are to make a car/bike hauler. Been lurking around here for quite awhile and I am very impressed with all the knowledge and the willingness to share all the cool ideas. I have built a few custom bikes, but this will be my first truck project. Please be patient if I ask some rookie questions.
  24. pex
    pex
    from alberta
    don't ever be afraid to ask, if we don't know we'll make something up.(just kidding) ask, there's lots of experience on here. the bike building will help.
  25. Donnda
    Donnda
    Hey, I'm real good at making up something ................ it's the reason I do everything 3 or 4 times
  26. iwanaflattie
    iwanaflattie
    hello i have a 51 ford coe and dont know if i should use an 88 gmc 1500 or a mid 70s chevy custom deluxe dually frame.
    I want the pick up look.
    thanks
  27. buggy5872
    buggy5872
    Using a 2003 GMC W4500 HD ch***is and running gear. I am basically taking the GMC cab off and putting my 57 body (stretched to a crew cab)on it and using a 58 fleetside bed with cut down stepside fenders for dually fenders. Plan on using all the electronics. It will think it is still the 03 GMC and be able to be serviced at any truck stop if any problems arise on the highway. Plan on towing a big 5th wheel camper.
  28. kooscoe
    kooscoe
    Hello buggy5872,
    Is de 57 A LCF truck? Love to see pic's from your build.
    Greetings Koos
  29. godspeedbear
    godspeedbear
    from golden
    I'm using a '79 coachman ch***is.. The same as a 1 ton gmc van
  30. buggy5872
    buggy5872
