What Chevy rear to use for 53 Chevy pick-up
Discussion in 'The Hokey Ass Message Board' started by 1955 F-100 guy, Nov 13, 2011.
  1. 1953-55 F-100 guy
    1953-55 F-100 guy
    from NE Pa
    Doing a 53 Chevy pick-up and want to know which 10 bolt Chevy rear with drum brakes--chevy 5 X 4 3/4'' bolt pattern-- using 15'' X 8'' rims-- ECI rear leaf spring kit-- what rears had these gears 3:30-40-50' S -- must be 60'' outside drum to outside drum--going to use 350 engine--with 700R trans - thinking of a 55-56-57 Chevy rear-- PM me with info- Thanks
  2. nwbhotrod
    nwbhotrod
    from wash state
    Why does it have to be a Chevy. why not 9IN Ford mors gears easyer to narrow more avable and a better rear end
  3. rusty1
    rusty1
    full-size GM's from the mid 70's - mid 80's will work but are coil sprung,(some are small bolt pattern wheels, some are 5 on 5) you'll need to remove the brackets. ...2nd generation Camaro/F-bird also work....and S-10 4 wh. drive rears.
  4. hotrodchevy
    hotrodchevy
    ya what he said unles you want with 6lug
  5. butterboy
    butterboy
    I used late 70's half ton Chevy truck rear in mine. Six bolt lugs. Cheap to rebuild and if I remeber it was 3/4 of an inch narrower then the stock rearend. Tucks the stock rims nice.
  6. lawman
    lawman
    My Grandson and I used a 99 Chevy Blazer 4X4 on our 51 chevy 1/2 frame.Worked very nice.We are using slicks with 15X8 rims. You may have to use longer lugs and wheel spacers as we had to cut the sides of the bed to clear tires.Hope tis helps you.
  7. Sonny48
    Sonny48
    from Mo.
    I used a 74 nova in my 48...and it worked well. Also put the spring mounts up inside the frame to lower it.
  8. lawman
    lawman
  9. jcmarz
    jcmarz
    from Chino, Ca
    No need to put ****py Ford parts in your Chevy. That would be a step backwards. Keep it all G.M. My friend used a S10 rear end and ****** on his 49 Chevy truck.
  10. lawman
    lawman
  11. treb11
    treb11
    55 - 62 chevy p***enger car, and it has the same BP if you swap p***enger 50-54 p***enger drums onto the front spindles.
  12. 53sled
    53sled
    from KCMO
  13. mj40's
    mj40's
    x2 for late 60's or early 70's Nova or Camaro
  14. the-rodster
    the-rodster
  15. Papa Tom
    Papa Tom
    i used a 67 chevelle in my 53
  16. jedsled
    jedsled
    hey the 3rd gen camaro is the rite width?
  17. chopt top kid
    chopt top kid
    The 60's era Chevy II 10 bolts measure 60" wms to wms w/5 on 4 3/4" dbc. I used one from a '67 wagon... I always thought the '68 and later Nova's and Camaro's were a little wider but I never measured one... They all had leaf springs(or spring)...
  18. vinnymac44
    vinnymac44
    from W. Oregon
    77 camero, 61.5 " and 5 on 4.75
  19. pottsie454
    pottsie454
    I used a 2nd gen Camaro.. Its great for regular offset wheels. Plus late you can find an 8.5.. a lot stronger. Only beef is the spring purchase are not in the right location and the gears **** in those years. Also, avoid a triangulated 4 link setup. I put one in mine and I am still not sure its going to stay located... but I am going to give it a shot.
    http://www.jalopyjournal.com/forum/showthread.php?t=642930
    Also, on the nova note, I personally think they are to narrow. I had to use 1.5inch spacers for any wheel I wanted to put under there.
  20. the-rodster
    the-rodster
    Yes.
    You need something very close to 62 inches wide.
    3rd gen camaro is 62.5 inches.
    They're readily available, good gearing choices, just cut all the coil mount stuff off, and go.
    Rich
  21. the-rodster
    the-rodster
  22. jedsled
    jedsled
    thanks rodster when you measure to find 62" where are you going to out side of drum to drum?
  23. the-rodster
    the-rodster
    Yep, wheel mounting surface (WMS)
    Rich
  24. Leevon
    Leevon
    from Nixa, MO
    '79 firebird 3.42, posi, 8.5 10 bolt I got for $200 worked great for me:
