what clutch and pressure plate assy to use
Discussion in 'The Hokey Ass Message Board' started by rattrodjohnny, Jul 7, 2013.
  1. rattrodjohnny
    rattrodjohnny
    I have a 27 5 window with a 1947 ford flathead hooked to a 1940 3 speed. what clutch and pressure plate assy will give the best service? thanks, Johnny
  2. Jalopy Joker
    Jalopy Joker
    rrjohnny - need to eliminate the rr part to get any help around here.
  3. stainlesssteelrat
    stainlesssteelrat
    from ms
    kanters sells parts for em.. well..every part..and MAC's too.. ought look there.. these people fear change more than muslims do, no help from here man. lol
  4. 19Fordy
    19Fordy
  5. 40FordGuy
    40FordGuy
    I'd go with a stock 40 thru 48 Ford pressure plate and disc.
    4TTRUK
  6. robH
    robH
    The 47 engine originally came with a flywheel that takes the 10-in clutch. A 40, I believe, originally came with a 9-in flywheel & clutch. So, it depends on which flywheel is there. If you are looking for opinion, I'd choose the 9-in, only because I'm biased. I've got two cars, one each 9-in & 10-in. Both work ok. Your call. JMO
  7. DICK SPADARO
    DICK SPADARO
    The pressure plate and disc will depend upon the size of the flywheel pressure plate bolt pattern. If your engine came from a truck most likely it has an 11" pressure plate bolt pattern. If your engine came from a car it most likely has a 10" bolt pattern pressure plate. The 11" clutch is a little big for that light car so hope that you have a 10"' car plate. Stock parts are sufficient for your application and can be purchased at any of the old Ford car parts suppliers.
  8. 1971BB427
    1971BB427
    from Oregon
    Guess there are good folks who can still help, even if the user name isn't traditional. ;)
