Technical What could this be...? Repair..?
Discussion in 'Traditional Hot Rods' started by soonrodder, Sep 20, 2020.
  1. soonrodder
    soonrodder
    from germany
    Hi all,
    I got a 1953 Mercury engine from a friend. He told me it rund very fine.
    I cleaned it and found out it was redone sometime ago. 0,04 over.
    Than I found the scar on this valve ...
    What can it be ...?
    The area around looks rougher as the rest of the surface ..
    Any ideas..? ....opinions...?
    Thanks a lot in advance
  2. Looks like a casting flaw to me. Also looks like you have a couple of cracks....between the bolt hole and the coolant hole, and from the valve seat to the cylinder wall......
  3. Fitty Toomuch
    Fitty Toomuch
    from WVa
    Your friend got you to haul off his heavy s**** iron, looks to me.
    The crack would need repaired and figure putting in exhaust seats.
  4. Yes,,,,, the crack between the bolt hole is nothing to be worried about .
    The crack from the valve seat aiming to the cylinder needs attention.
    It can be repaired and a new seat installed,,,,no problem.
    But,,,,it definitely needs to be fixed .
    Tommy
  5. soonrodder
    soonrodder
    from germany
    Hi together,
    and thank you all.
    Sounds not very good.
